Apr 29, 2010, 10:15 PM
Gigaah
Are there any chargers that will or can be modified easily to be a CC power supply?
I don't need much in the way of amperage. Cheap is the key. Ideally in the 3v range but i'll take what ever I can get. Im just looking for an adjustable constant current power supply. I thought you guys might know of days gone past unsafe lipo chargers or something current and cheapish that I could get my hands on.
I'm looking to power high wattage LED lights if that help.
Apr 29, 2010, 10:48 PM
I have used commonly available LM317 and LM350 regulators as constant current supplies in the past with fantastic success. National's datasheet has application notes that does a great job of describing how to use the regulator as a constant current source. If current is low enough you may not even need a heatsink.
http://www.datasheetcatalog.org/data...r/DS009061.PDF
Mark
Apr 30, 2010, 06:36 PM
Gigaah
Could you explain or draw up how it together. after reviewing the data sheet I have some idea and do feel safe trying it out but i'm not sure exactly how to wire it and what resistance and wattage resistors are needed
May 01, 2010, 02:15 AM
Another primer...
http://users.telenet.be/davshomepage/current-source.htm
Mark
May 01, 2010, 04:48 AM
Gigaah
got it. Thanks!
Question are there different hitec crystal sizes that will fit in hitec receivers? grfcon Hitec/Multiplex USA 1 Feb 22, 2010 10:50 AM
Discussion Are there any off the shelf cameras that have a video out? Tommygunn Aerial Photography 10 Nov 28, 2009 01:36 PM
Discussion Are there any smoke 'cannisters' that will operate from a switch ? PokerKid Foamy EDFs 1 Sep 27, 2008 07:47 AM
Question Are there Nicad chargers that can handle 50+ cells in series ? Protocooler Batteries and Chargers 4 Nov 09, 2005 08:54 PM
