May 19, 2010, 05:55 AM
fast
fmkit's Avatar
my 48" EPP flying wing has payload capacity about 300gram
I'm thinking of converting it into biplane to carry heavier cameras
todays test show the biplane wing completely flyable
http://www.youtube.com/watch?v=2mvbVuFFV4c
May 19, 2010, 07:04 AM
quailbird's Avatar
Cool! I do believe you are an engineer! Can't wait to see the wing you build from this proto type!
May 21, 2010, 07:08 AM
fast
fmkit's Avatar
today we tested new type diversity RX that also know to give priority to one of the transmitters when both RSSI good. When one of multiple pilots sets throttle higher than rest it will have full control of model
Friend of mine flew the plane and without saying a word he will lower or turn off his throttle so I can continue piloting
such setup replaces body box and doubles range of FPV flown planes cause pilot can be miles apart.
here is my AP plane - it folds into bacpack.
Panasonic LS85 held by single screw in it's original mount and can rotate 360
May 21, 2010, 10:52 AM
quailbird's Avatar
Very nice! You always do good work! I'd like to borrow half your knowledge!
May 22, 2010, 06:31 AM
Gaftopher
Gary Mortimer's Avatar
Well done, maybe more people will finally start seeing that they should be using wings ;-)
More wind = more shots more of the time ;-)
May 22, 2010, 08:11 AM
fast
fmkit's Avatar
true, when windy it easier to control flying wing
about noon (3 hours ago) after seeing smoke cloud in my area I flew the AP wing to check it out, look at the smoke and guess how strong the wind was for 20gram brushless pushing Panasonic LS85 and 2200mAh Lipo
May 22, 2010, 08:41 PM
+1 for the $50 board
May 23, 2010, 03:56 AM
Gaftopher
+1 as well, if its coming!
May 24, 2010, 01:25 AM
Where is this board? (And of course the full "destructions")
Ted (UK)
May 25, 2010, 06:51 AM
fast
fmkit's Avatar
Ted (UK)
I ship from Israel.
the stabilizer was much improved since my last post here
now the chip has 2nd PPM input to make diversity or share one plane between two pilots that can be miles apart
I'm working on UI so one can configure the chip without C-compiler just by pushing setup button, theat is servo reversing, aileron/elev swapping and gyro sensivity. The stabilizer will be available in few days.
May 26, 2010, 01:33 PM
fast
fmkit's Avatar
I 've modified the flight controller
better diversity
now digital servos /gyros refresh rate 200Hz
http://www.youtube.com/watch?v=oGixK473uAo
Jun 05, 2010, 01:52 PM
fast
fmkit's Avatar
flew the wing today with 3rd section added as vertical stab
helps a lot wit orientation
a tad uphedral to make it look like mercedes sign ?
Jun 05, 2010, 05:36 PM
quailbird's Avatar
Cool video! It looks like the tail end of a 747 without the plane! Sure is windy there. I watch all your videos. Too good not to!
Jun 05, 2010, 06:07 PM
fast
fmkit's Avatar
I was thinking exact the same - it is flying tail !
the rest is missing
Jun 17, 2010, 12:43 PM
Originally Posted by Breezemont
I would.
I would too.
Build Log Backpack Easystar AP MisterNiceGuy Aerial Photography 44 Mar 06, 2018 12:48 AM
Help! Landing light set up problem highasakite99 DIY Electronics 7 Apr 07, 2010 09:51 AM
Discussion AP: 3 min Drive from Home, Over a Moving Train-When light was Low guyg Aerial Photography 0 Mar 17, 2010 10:54 AM
Discussion portable complete AP system signguy Aerial Photography 37 Oct 26, 2009 07:18 PM
Discussion Backpack FPV AP Folding Wings craigp84 Aerial Photography 6 Feb 11, 2009 09:56 PM
