Apr 23, 2010, 03:05 PM
fast
fmkit's Avatar
Light and portable, backpack-able AP set
After almost 1year break today I flew under 400gram AUW AP flying wing with modded Panasonic LS85 onboard
The camera's power,shutter,focus,and zoom controlled with Wii Nunchuck
powered by servo ubec
here some pictures shot today, it was very windy, thanks to Wii Motionplus MEMS gyros the plane is fly-able in any weather, today we even tried to induce large drag by attached chunk of foam but it flew like nothing happened
All my wings ( thanks Jeff from mwcores.com !) are foldable
drag test:
http://www.youtube.com/watch?v=XJ8G-ybjsAg
Apr 23, 2010, 04:47 PM
quailbird's Avatar
You are truly an amazing pilot. If I tried that with a piece of foam I'd end up with lots of foam. Your wing really flies great. How do you find the c/g when carrying a camera? I bought a Slinger and added 6" in the middle but I'm not sure if that changes the C/G or not.
Apr 23, 2010, 06:57 PM
fast
fmkit's Avatar
without stabilizing electronics the plane is useless, I'd crush within 10seconds after takeoff
here is same clip on vimeo (somewhat better quality) - take closer look at elevons. they never stop moving
with gyros CG doesn't matter that much, +/1" OK
(1 min 16 sec)
Apr 27, 2010, 12:24 PM
fast
fmkit's Avatar
My plane does miracles
anyone ever tried to tow a flag ?
We celebrate Independence Day here in Israel and my flag was above the rest
because of high drag flying 100gr Panasonic LS85 is easier compared to 40gr flag.
Apr 27, 2010, 01:47 PM
Welcome Back MAN
From Ness ziona
**Did you saw my last Posts in this forum??
Guy
Apr 27, 2010, 02:40 PM
fast
fmkit's Avatar
the wing is incredibly stable with the gyros, wing area is comparable to size of the flag but somehow it just flew !
today's video
http://www.youtube.com/watch?v=eUkD-0zvRqo
Apr 27, 2010, 02:59 PM
quailbird's Avatar
How many gyros do you have on it? And how do you have them mounted?
Apr 27, 2010, 03:31 PM
fast
fmkit's Avatar
I used fake Wii MotionPlus (some $10/ea ebay)
it comes with 3-axis gyros but the wing has no rudder so 3rd gyro unused
then I wrote firmware to control the plane with Nunchuck and stabilize the aircraft. What is really special about setup is the way joystick works: further away off center mean less gyro gain so you can do rolls and loops just like sports plane and if the stick moved little the plane holds position.
https://www.rcgroups.com/forums/atta...mentid=3207319
Apr 27, 2010, 05:40 PM
quailbird's Avatar
Wow! That's way over my head! Way to go!
Apr 27, 2010, 06:27 PM
Talontsi96's Avatar
More info on the Wii gyros please... this is quite intriguing....
Apr 28, 2010, 06:40 AM
fast
fmkit's Avatar
I made my own mixer/stabilizer using lowest cost parts.
you don't have to know coding and solder tiny pieces
just use whatever flight controller meant for quadrocopter - configure it for flying wing and enjoy. Gyro, receiver,PID controllers all should be one device
separate mixer and rate gyro won't be as fast and can cause oscillation if outside some narrow speed range. My controller adjust gyro gain automaticaly, there are no pots/trimmers to play with, all wing sizes work the same , plug-n-play.
Apr 28, 2010, 08:18 AM
It all SOUNDS so easy but?????
May 15, 2010, 06:10 AM
fast
fmkit's Avatar
tedrobphoto,
Would you pay $50 for the stabilizer ? that's small board with PPM input, elevon mixer and MotionPlus.
Today was windy so I could hover the wing (under 500g AUW incl.Panasonic LS85)
http://www.youtube.com/watch?v=XGIv47wul4M
May 15, 2010, 09:38 AM
quailbird's Avatar
You do make it look easy. I'd like to have anything that flies like that!
May 16, 2010, 01:33 AM
Originally Posted by fmkit
tedrobphoto,
I would.
Build Log Backpack Easystar AP MisterNiceGuy Aerial Photography 44 Mar 06, 2018 01:48 AM
Help! Landing light set up problem highasakite99 DIY Electronics 7 Apr 07, 2010 09:51 AM
Discussion AP: 3 min Drive from Home, Over a Moving Train-When light was Low guyg Aerial Photography 0 Mar 17, 2010 10:54 AM
Discussion portable complete AP system signguy Aerial Photography 37 Oct 26, 2009 07:18 PM
Discussion Backpack FPV AP Folding Wings craigp84 Aerial Photography 6 Feb 11, 2009 10:56 PM
