Mar 01, 2013, 01:00 PM
efflux RC's Avatar
It's a rendering of the nose gear/battery tray assy.
It may look like a photo on your BB.
Latest blog entry: Updated blog - Oct 2017
Mar 04, 2013, 02:45 AM
efflux RC's Avatar
I received some new parts from A.S.
There is also a new Transition Duct with "T" nuts for assy. More on that later.
Mar 04, 2013, 02:57 AM
efflux RC's Avatar
I did some work on the rudder assy tonite.
The rudder servo is a Hi-Tec HS65HB.
I wanted to get it in there with as little cutting as possible. A.S. said He did his similar to this.
I cut a hole in the bottom of the vertical stab, just big enough to get the servo in there with the control arm (Previously centered) and drilled for the 2-56 control rod (.072 dia).
I used a "sharpie" to spread the stab a bit to aid in inserting the servo.
The small hole for the control may need to be opened up a bit later. (for max rudder throw). It still needs a little cleaning up. but this is how mine will be.
The control arm is again a DUBRO 2-56 thd'd on one end, control rod with Kwik link clevis (top quality, spring tempered steel) the servo end has been trimmed a "z" bend added.
I'm gloing to glue the servo in with RTV Silicone on both sides. (Easily removable, in the event that it ever needs to be replaced)
Mar 04, 2013, 04:37 AM
efflux RC's Avatar
Here is the removable Battery Tray assy (easy access for those who may wish to place components under it)
The laser cut parts will have two locating tabs on the aft battery tray former.
Mar 04, 2013, 11:38 AM
Classic jets rule
AIR SALLY's Avatar
looking good
Mar 04, 2013, 02:07 PM
efflux RC's Avatar
Your parts are looking good.
I gotta stay focused on thing.
Hopfully maiden in two weeks.
Mar 04, 2013, 08:30 PM
Classic jets rule
AIR SALLY's Avatar
i used a hs55 servo and it fit behind the the spar.the mount tabs were also removed ,and i used silicon also to mount it . we did some knife edge testing ,but i think we need the c/g moved back to get the most out of it ,plus maybe use the inner hole on the control arm for more deflection.
Mar 04, 2013, 09:29 PM
Never fly an A model anything!
jayb1rdz's Avatar
Or fly faster!!!
Mar 04, 2013, 09:58 PM
efflux RC's Avatar
Rodger,
The inboard control arm hole is the one I now have it in. I also put a longer arm on the servo to increase the throw.
Seems that it should knive edge with the CG in the proper location, with enough throw. I have +/- 30* now.
Oh hey, I just realized that with the stab glued in place, the servo is not going to be removable anyway. A hatch could be cut by those who prefer one.
I still need this info, when you get a chance:
  • The neutral position for the elevator. (the leading edge, with respect to the fuse parting line would be a good reference point)
  • Aileron throws (Hi/low rate...or just high rate if thats what your using)
  • Mid Flap angle
  • Full flap angle
  • CG position
Mar 05, 2013, 12:12 AM
efflux RC's Avatar
Rodger,
I'm about to attach the vertical with 30 min expoxy.
Any comments before it's too late?
Mar 05, 2013, 12:19 AM
Classic jets rule
AIR SALLY's Avatar
yeah line up the parting line of the tail cone with the center afterburner panel line .the pointed nose of the vert under the intake scoop for the after burner need to be slighty left of the parting line ...i thought i marked your fuse.look close there should be a mark of some kind.i used 5min epoxy as it is easier to heat up and remove if ness. but 30 would work too ,just harder to remove if needed.you could put some lighting hole that match the one in the vert so you can open the ab scoop and the air will vent.
Mar 05, 2013, 12:29 AM
efflux RC's Avatar
Yeah, I noticed that the front parting line was off center. I opened up the 3/16 hole for the spar to the side just a touch. (the spar will still be in contact with the rear fuse former).
I'll open up the scoop, and use 5 min epoxy.
Thx
Mar 05, 2013, 02:10 AM
efflux RC's Avatar
a little more work on the vertical......
I added some lightening holes to the fuse. There will be a matching pattern on the stab base
Got the scoop opened up.
There was a bit of a void under the rudder, so I placed some clear tape on the outside and added a thin layer of Epoxy/microballons to the inside, then removed the tape.
Mar 05, 2013, 03:16 AM
Classic jets rule
AIR SALLY's Avatar
very nice work . the hollow spot at the base of the rudder is normal .it will be up to the builder to fill that in if they want . i left mine open ,but i like how you worked it .
Mar 05, 2013, 03:22 PM
Classic jets rule
AIR SALLY's Avatar
i got one of jwings control surfaces cut out and working ,just need to do the other .
i also sent a E-mail to callie at Callie graphics to order some decals for the kits. hope i hear back soon.
For Sale Air Sally T45 (v1) F/G ducts $48.00 jzuniga Aircraft - Electric - Jets (FS/W) 0 Jan 01, 2010 02:36 PM
Sold NIB Sapac T-45 V1 Composit with Air Sally ducts mickydee Aircraft - Electric - Jets (FS/W) 7 Dec 11, 2009 06:57 PM
Sold Phase 3 F-16 w/ Air Sally fiberglass NIB mflander Aircraft - Electric - Jets (FS/W) 6 Nov 27, 2009 03:21 PM
Wanted Air Sally Ducts for BAe Hawk jzuniga Aircraft - Electric - Jets (FS/W) 0 Oct 23, 2009 08:05 PM
Sold E-flite BAE Hawk and Air Sally Ducts bfischer Aircraft - Electric - Jets (FS/W) 3 Jul 25, 2009 03:39 PM
