Apr 19, 2010, 12:37 PM
Tomalak's Avatar
Build Log
Selifun XP
Hello everyone !
May I present to you the " Selifun XP "
Status : maidend, on duty
Wingspan : 100cm
Lenght : 100cm
Motor : BlueBird BLM-12mm 1300kv
Prop : 8x4.3
Power : reduced to 160Watt due motor limits
Lipo : 3S 1500mAh
take off wight : 530g ( overwight to the plan due bigger motor & lipo )
CG : 6,5mm from leading edge
But first : Special Thanks to http://www.jk-modellflug.de.tl for the plans and building tips.
Great page for building fomies! And also this page, the plans and the videos are in german, most of it is easy to understand just while looking at it.
Otherwise just ask here.
Plans for this plane are here : http://www.jk-modellflug.de.tl/Selifun-XP.htm
( Behind "Hier gibt es den Bauplan für den Selifun als Download" )
His build looks far better, but at first, here's mine :
Apr 19, 2010, 01:45 PM
Look really good, and makes me wanna build one. I look forward to see it on a maiden flight. Be sure to have someone with you to film it, and upload it on youtube. Good luck
Apr 19, 2010, 02:21 PM
that looks really nice. i really like the shape of the nose and the bubbly cockpit. looks slightly like an edge.
last time i spent that much time on a full-fuse built up wing plane i didnt have great results...sooooo, good luck on the maiden!
- Jeff
Apr 19, 2010, 04:52 PM
Zen in the art of foam
djacob7's Avatar
Excellent workmanship!
What is GFK weaving?
Apr 20, 2010, 11:27 AM
Tomalak's Avatar
Thanks!
I don't know the correct translation. What about "Glass fibre weaving" ?
I used this for the landing gear, 10 layers.
http://www.conrad.de/ce/de/product/8...archDetail=005
By now i would recomend > 200g/m2 an less layers
Apr 21, 2010, 09:01 AM
djacob7's Avatar
Thanks Tomalak!
Apr 21, 2010, 04:46 PM
Tomalak's Avatar
Two things to add :
First :
What could not be seen : The nose got two air intakes for cooling ( see pic ) and the end of fuse is also open on two places . I hope it will be enough.
Second :
Iwas very suprised of the durability of the wing!
I thouht 4 pieces of 3mm depron with a balsa spar on each side glued together would'nt last long. But combined with this fibre tape ... wow!
Apr 22, 2010, 02:23 PM
Tomalak's Avatar
Sorry folks, there was time, weather but no camera man ...
I maidend
It started, it flew, it landed and it survived
Because I'm still very new to this, so i can't really compare, but in my opinion It goes great ... way betteer then my Mo-109 witch is slightly under-powerd.
I needed only 1/3 throttle to keep it in the air, very good lift ... and therefore 2/3 of pure fun left
Landing wasn't 100%, with light wind from right i missed the street and let it drop into grass with out any damage.
I think it was a good idea to use fibre weaving in the inside to strength fuse and bottom ( pic will follow )
Apr 25, 2010, 07:35 AM
Tomalak's Avatar
Not in the original plan, but i think it makes the plane more durable with only very few extra wight
Apr 29, 2010, 03:15 PM
Tomalak's Avatar
Found a weakness : I lost the tailwheel after landing. Now it is glued back in place and also fixed with tesefilm ... should think about another way of attaching it
May 13, 2010, 11:44 AM
Tomalak's Avatar
Still no one at the camera, but I found a solution
(due this solution quality isn't best )
Link to Selifun XP 4th take off and flight Video
Discussion Windows XP lovers, XP sucks! lakedude Life, The Universe, and Politics 26 Nov 29, 2009 05:49 PM
Question XP-4\XP-4.5 plan? eitanro Hand Launch 10 Mar 07, 2006 10:17 PM
Installed Nero on my Win XP Computer-How Do I disable XP Burning? mrebman Life, The Universe, and Politics 4 Jul 30, 2002 06:35 AM
Windows XP Question - What CD Burning Software will work with Windows XP? mrebman Life, The Universe, and Politics 3 Jan 10, 2002 09:23 PM
