Apr 12, 2010, 09:55 AM
Question
Custom gas engine standoffs?
Can anyone tell me where I can get custom-made aluminum standoffs: I have a RCGF45 rear carb engine and for the carb to clear the firewall I need 3" 3/4 inch (95.0mm) standoffs. The various RC outlets do not seem to supply them that long. Because of the vibration and toque forces I believe (rightly or wrongly) itís prudent to use single length standoffs rather making up the required length with two standoffs stacked on top of each other. Hence my question about custom made standoff suppliers.
My second question: As I have not seen standoff that long how long becomes too long?
I realise that the conventional solution is to build an engine-mounting box onto the existing firewall but if I can get away with long aluminum standoffs thatís the route I would like to go.
Apr 12, 2010, 10:12 AM
earlwb's Avatar
EastRC http://www.eastrc.org/shop.cgi/page=...D=PUT_SID_HERE
ought to have what you want.
You might also try using aluminum or brass spacers (threaded or unthreaded)
http://www.brass-fasteners.brass-par...-standoffs.htm
Now then http://www.wackerengines.com
One old method is to use long bolts and some extra nuts to thread onto the bolts to set the length and use more nuts to tighten it all down with. If there is too much excess bolt length, you simply cut the extra off.
Apr 12, 2010, 03:36 PM
Or 1" oak dowels. I've done it for 40cc and G62. I use 10-24 or 10-32 all-thread. Havent seen a difference between wood and aluminum.
Edwin
Jun 26, 2012, 07:23 AM
customstandoffs
cmala's Avatar
I realize that this is an old thread but I make custom aluminum standoffs.
http://www.customstandoffs.com
Craig
Engine Standoffs aerografixs Product Announcements 4 Jun 28, 2010 12:21 PM
New Product NEW! Aluminum Standoffs for Brushless Motor and Gas Engine use EAST RC Product Announcements 1 Mar 31, 2010 09:13 AM
Sold Evolution 58cc gas engine with Evolution muffler.the engine only has 30 minutes run t v22chap Aircraft - Fuel - Engines and Accessories (FS/W) 5 Jan 05, 2010 05:30 PM
Discussion Gas Engine Standoffs Lunns Australia 8 Nov 20, 2008 04:54 PM
For Sale =REDUCED=Evolution 45GX 45cc engine, muffler, spinner, prop, standoffs Super_Dave Aircraft - Fuel - Engines and Accessories (FS/W) 2 Sep 22, 2008 10:48 PM
