Skywalker 168cm FPV plane - Page 533 - RC Groups
Jun 27, 2011, 12:02 PM
Daemon's Avatar
Originally Posted by thekubiaks
There are a few guys that fly with the CG that far back and don't seem to be having issues. The plans call for the CG to be at the front (nose side) of the servo wire channel. It doesn't seem like much, but 30mm is pretty significant in these aircraft. An aft CG, like where yours is located, tends to be less stable and may feel a little "Squirrely"
It's not squirrely at 30mm. It's more neutral on pitch axis but still has some positive
stability unless you put it in a vertical dive. Judge for yourself if any of my
flights looks squirrely. http://www.vimeo.com/user286460/vide...er/sort:newest
or hercdriver's
FPV 2 - Air to Ground.mov (4 min 47 sec)
CG at the servo wire slot is severely nose heavy. It'll fly, but not very efficiently
and will pull up with increase in airspeed which usually means constantly
changing pitch with throttle changes.
Honestly I don't believe it's possible to break the wing "in normal flight" unless there's
some pre-existing flaw in the foam or the bottom of the joiner box isn't glued in
or something. Without a flight video I can't offer any other hypothesis.
I've never seen anything resembling "tail flutter" on the SW.
ian
Jun 27, 2011, 02:29 PM
starzen, mandis, ScooterInVegas and metalfred:
I think you are all right in my faulty prop mounting :P
I honestly didn't think that one through...
After reading your answers I went out in the car to get the plane. I tested it first, and just held my hand behind the prop to feel the wind from it, then I mounted the prop the other way... Oh daaamn!! That was a big difference!
I haven't tried it yet, but I'm hoping to get some time for it tonight
henkvdw: I "fly" it with a 3S 5000mAh Turnigy NanoTech and one 2200mAh NanoTech for video.
Since I noticed that my prop was mounted the wrong way I will not upload a picture of it, but instead I will update y'all after my first successful flight tonight!!
Thank You All for great tips and a very helpful hand
I haven't really posted that much here on rcgroups, but I will definitely post more from now on!!
I will also share videos from my beautiful country for everyone to see!! :P
See you later
-Woodbear-
Jun 27, 2011, 03:20 PM
rsowder's Avatar
Hard Landing
Yesterday I had a friend film my plane as I made a hard landing. He filmed it at 300 fps so you can see how durable this plane is. This plane has had no structural modifications at all and it has over 50 flight hours on it. It's the V2 Skywalker:
Hard Landing (0 min 37 sec)
Jun 27, 2011, 03:28 PM
I should be flying right now!
al1242's Avatar
I always land mine like that, is that a hard landing?
Jun 27, 2011, 04:07 PM
rsowder,
That one of the coolest videos on here. Looked a little hard, but not bad. Sure is some flex in the wings and tail feathers.
Jun 27, 2011, 04:18 PM
rob38's Avatar
jo
Meybe it,s not only a bad wing
Some wings have good foam
And some wings are make from bad foam
Rob
Jun 27, 2011, 04:20 PM
rsowder's Avatar
Originally Posted by rob38
jo
Rob
I think that is a possibility.
Jun 27, 2011, 04:43 PM
My_design's Avatar
At least you were flat. Now throw up a 300fps video of something coming in nose first! That would be something to see!
-B
Jun 27, 2011, 04:47 PM
Daemon's Avatar
My thoughts exactly.
ian
Jun 27, 2011, 04:51 PM
AMA #535918
I wish I always landed that good.
Jun 27, 2011, 05:03 PM
rob38's Avatar
when sky walker v4 have a 5 cm longer
Nose,we can fly whit 1400 gram totall weight
Then every sw landing soft
Rob
Jun 27, 2011, 05:11 PM
Flying low is expensive.
pdiddyg40's Avatar
I am putting together a shopping list for my NIB skywalker. I was originally going to use some $6 servos from HK that i saw on the 1.2ghz FPV thread. They are known to be unphased by FPV noise for 1.2 ghz and don't glitch. However, people here presented the question of "Why use 4 dollar servos on a 500 dollar plane?"
So I looked around and found that ServoCity has HS-81s for around $13 http://www.servocity.com/html/hs-81_micro.html
The $6 servo from HK recommended by the 1.2 thread
http://www.hobbyking.com/hobbyking/s...314&aff=138637
And $9 EMAX servos from Value Hobby, also recommended by the 1.2 thread:
http://www.valuehobby.com/product_de...hp?item_id=104
Anyone have opinions on this? I figure that I'm going to need 4 servos for regular control. Later I'll possibly need 2 more for flaps and/or 2 more for pan/tilt. That's up to 8 servos. Even at $9 a servo, that's over $70. I'm working of a high school student's type of budget so I'm inclined to stay out of the $20 servos.
I'd really like to use extremely high quality stuff, but I don't have the money for it. Would those EMAX servos be a good compromise?
Jun 27, 2011, 05:12 PM
rsowder's Avatar
Well, I could have landed a little harder but that does show the flexibility of these wings.
Jun 27, 2011, 05:15 PM
pdiddyg40's Avatar
Great video. If that was the V2, why is the wing mod all that necessary? That doesn't even have the "new" addditional spar at the dihedral joint. How heavy is your SW? Maybe that makes a difference. If you're flying the non-reinforced V2 with no issues, a V3 shouldn't have many problems, either.
Jun 27, 2011, 05:22 PM
rsowder's Avatar
My planes AUW comes in at just over 2,000 grams. The V3 has an additional spar at the outboard section of the wing, but it does not connect to the main spar. So, it's pretty much window dressing. I think there is a possibility that some are getting wings that could possibly have imperfections in the foam. Maybe some air pockets. That's just speculation on my part as I have not seen a damaged wing in person.
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 04:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 11:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 10:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 12:45 PM
