Sep 07, 2010, 03:04 PM
ashdec87's Avatar
here's a flight in 20+ mph winds.
A Day At The Farm (6 min 11 sec)
Sep 07, 2010, 03:48 PM
Blu-Core is my friend
Gundy's Avatar
Frightening flight!
Frightening flight!
Nothing strange, just my first true flight under the goggles…
Finally got to do the maiden on my Skywalker II, I took some of the toys with for the first flight. I was very confident in the Skywalker needing very little to fly right. I was correct.
From the moment I put the goggles on it was GREAT! Simple to fly, easy to hold course, I am so hooked!
At one point I decided to take the goggles off and fly by LOS “just to be safe”… but when I looked up where I thought the plane was... I saw nothing… that’s when it got Frightening. Putting the goggles back on I realized everything was just fine. Relaxed and flew back into LOS range, and landed the old fashion way. I will work on landing later.
The Eagle Tree system worked great, once I got calmed down enough to look at it LOL
The radar is nice to see where home is. Now I know what other things I need to put on the screen.
I recorded 3 flights that were perfect… but my Archos 5 internet tablet has decided to make them “copy protected” so they can only be played on the Archos… (Working on getting them back) I will be using my "Piano DVR" from now on.
Later,
Gundy
Sep 07, 2010, 05:24 PM
I love FPV!
Cralis's Avatar
Originally Posted by rsowder
I had a great flight this weekend. Made it on top of the clouds for a while. 30 minute flight condensed into 6.
http://vimeo.com/14749465
Password: sky2
"The local sewer plant" - Man, you'd have been in deep sh_t if you had landed in there!!!
Sep 08, 2010, 02:13 AM
iw28's Avatar
Nice video ! was it in feet or meter?
WHat is your setup?
Sep 08, 2010, 10:54 AM
rsowder's Avatar
WHat is your setup?
Thanks. It was in feet.
Vid is 500mw 900mhz with an 8dbi patch w/antenna tracker and saw filter mod on rx. Cam is the SN555.
RC is the Scherrer 433mhz with long range rx.
Sep 08, 2010, 11:10 AM
iw28's Avatar
thanks for the detail!
was it hard to climb that high with this plane?
Sep 08, 2010, 03:48 PM
EDI PAULO's Avatar
Nice video
are you sure it was in feet, looks high for only 1500feet above the clouds
Sep 08, 2010, 06:13 PM
rsowder's Avatar
Not at all. I was only using half throttle. I'm taking it out to the desert this weekend and plan to climb up to 5 or 6,000 feet.
Sep 08, 2010, 06:15 PM
rsowder's Avatar
Originally Posted by EDI PAULO
Nice video
The clouds here in the morning are pretty low I can't fly above 2,500 feet at that location or I'll be in San Francisco International's airspace
Sep 09, 2010, 11:12 AM
Whats the wrst that can happn?
AdamChicago's Avatar
Can someone tell me where the Skywalker CG is supposed to be?
Sep 09, 2010, 11:15 AM
ashdec87's Avatar
check the parkflyer thread
Sep 09, 2010, 11:17 AM
rsowder's Avatar
At a flying weight of 1920 grams, mine balances perfectly with the CG 5mm aft of the aileron servo wires. I simply applied a bead of hot glue at this location on each wing to easily determine the CG.
Sep 09, 2010, 11:27 AM
how do you dedicate a switch on the RC TX for OSD autopilot?
I have a Hitec Optic 6 tx...6 channel.
For my skywalker I'm using channels 1-5 for ailerons, elevator, rudder and throttle...no flaps and no camera pan/tilt. That leaves channel 6 but hitec dedicates it to flaps or flaperons. There is no "auxiliary" that I'm aware of.
Thank you.
Sep 09, 2010, 12:19 PM
Building my skywalker Mk2
1 Does anyone have photo of how they have mounted there UHF Ariel I have a Dragon Link and I am thinking of mounting it on a wing so the ariel is up and the ground plane is down , but this will be a right pain when I take the wings off to transport it . Are there any better solutions ?
2 I am using a 1500mw vid transmitter on the rear boom flat spot, should I use coaxe cable to take the vid from camera to OSD and OSD to transmitter ?
3 Given the power of the transmitter should I shield the servo wires ( they are twisted )
and lastly do you think the gps reciver will be ok in the under wing gap , this is from a rfi point of view.
and yes i know the transmitter is too powerful but as I own it I might as well use it ( also got 500mw and a 800mw )
any tips or points gratefully received
tks
Nick
Sep 09, 2010, 12:21 PM
Balsa addict
Kev.au's Avatar
I put my DL rx on the flat spot on the boom.
Cheers, Kev.
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 04:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 11:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
