The other MCX2 thread wasn't even in the coax forum until recently. Try to remember where to even look for that one!! If you see a thread you are interested in, even if you don't post to it but just want to linger for information, all you have to do is put in a posting that says "Subscribe" and you will automatically have that thread on your RCGroups button. At one point I asked the admin guys to give the 3 channel owners their own thread, but it never happened and it gets hard to find where you want to go without that RCGroups button.
My master settings automatically subscribe me to every thread I post in.
I figure this would be a good place to ask this question re: charging the mCX2 batteries.
I bought one of those parallel changing cables so i can charge 6 batteries at a time. I was told they have to be around the same charge to do that, but how can you check the voltage on these micro batteries? I have the tester for 2S , and any battery with a balance wire, but these have nothing. Any suggestions out there? thanks (going to use the Hyperion version) |
this is actually my favorite one (even though I bought it in a different place, but cant remember where) http://www.helibuy.com/tools-others-...6s-p-1557.html |
Latest blog entry: Random Pictures ...
Got one of those 808 Keychain Cams from MassiveRC today...thought I'd check out how the video is in my living room with just a floor lamp on...not too bad and it is HD.
(the part with the white plug is from HobbyKing: https://www.hobbyking.com/hobbyking/s...dProduct=18867 ) and the side that connects to the checker I crimped on the female part of the servo connector (and covered in heat shrink) |
For the white battery connector, your LHS (if you have one) should/might have several products that will work. For example..
Parkzone PKZ3052 Battery Connector/Wire http://www.greathobbies.com/producti...rod_id=PKZ3052 E-flite EFLA614 Ext 6" (2) Universal Light http://www.greathobbies.com/producti...rod_id=EFLA613 EFLA614 Ext 12" (2) Universal Light http://www.greathobbies.com/producti...rod_id=EFLA614 there are 3 other (longer) versions of that as well RC Funlab has similar ones but much cheaper Mini Li-Po Plug Extension http://store.rcfunlab.com/Mini_Li_Po...-ext-lpext.htm (RC Funlab site is acting up right now, try later) |
more...
For the lipo checker pins you can just buy any balance connector and wire up just the 2 of the 3 leads to something like I posted above...
JST-XH 2S Balance Lead Extension http://www.greathobbies.com/producti...od_id=TGHX1010 I'll make one later today... I have a bunch of these checkers and could use a 1S harness. By the way, you can get those lipo checkers all over eBay for under $2 with free shipping |
$5 Like mentioned in the video erdnuckel2 posted, it'll only work on the checkers that specifically say 1S to "whatever".... my non-alarmed ones I bought from RC Funlab are the older 2S - 6S that can't check a 1S lipo. EDIT: any 0.1" (2.5mm or 2.54mm) pitch connector will do. ... |
By the way, standard Futaba style servo connectors used in cars, planes helis etc. also fit the voltage checker pins. Some of these things even come with only two leads.
http://www.greathobbies.com/producti...d_id=SPMSP3007 |
Thread Tools | |
Similar Threads | |||||
Sold | Eflite Blade MSR Plus 2.4ghz Eflite Transmitter | soaringcam | Aircraft - Electric - Helis (FS/W) | 4 | Apr 07, 2010 10:27 AM |
Sold | EFLITE BLADE MSR+BLADE 400+DX6i | dhmojo | Aircraft - Electric - Helis (FS/W) | 7 | Mar 29, 2010 10:38 PM |
Sold | Blade MCX2 LNIB | mgroves | Aircraft - Electric - Helis (FS/W) | 1 | Mar 23, 2010 11:17 AM |
For Sale | Trade, eflite blades for eflite blades....Sell Blade CP Pro NIB with extras. | kdill2160 | Aircraft - Electric - Helis (FS/W) | 1 | Sep 02, 2006 09:28 AM |
Alert | Eflite Blade CX - 2nd Eflite heli | jschenck | Coaxial Helicopters | 26 | Oct 24, 2005 01:48 AM |
