Jan 24, 2014, 06:54 PM
flyin' fool
goldguy's Avatar
So, it runs OK without any prop mounted. Try the smaller prop on 2S to see what happens. If the doesn't work, then check for a broken wire from the motor to the ESC and the ESC's timing. If you can lower the timing, then try that.
Jan 27, 2014, 02:48 AM
Thank goldguy so much
The prop GWS6035 is run smoothly now, but Im afraid of small prop is not enough power to lift plan. WS is 600mm and RTF 190mg with 3s battery, 150mg with 2s battery.
It will be first fly soon.
Thank goldguy again.
Jan 27, 2014, 04:38 PM
flyin' fool
goldguy's Avatar
The motor doesn't like the bigger prop and throws off the motor's timing.
Feb 11, 2014, 07:56 AM
Hi!
I'm building it too
AUW will be 130gr with 2s 850mah lipo and 2500Kv motor...
Yours flying time?
bye!
Feb 26, 2014, 09:23 AM
Tested!
135gr AUW flight time about 22mins
Aug 22, 2014, 07:47 AM
Originally Posted by Jvan83
Tested!
Hi Jvan,
Could you give me the list of electronic stuff you used for your DD?
I want to build it but I am a newbie....
Ps: where do U buy the electronic stuff?
Many thanks
May 26, 2015, 10:07 AM
Volhout's Avatar
New holiday plans, new DepDart
Just for change a DepDart "light". With 10 gram motor and 20 gram 2S350mA lipo. This morning with good weather floated around for 20 mins, and the battery is not even empty.....
May 27, 2015, 03:20 AM
Reap the wild wind
headlessagain's Avatar
Looks like that might work indoors in a sports hall. What's the speed like?
Also looks like a good planform for a pure sloper, maybe at 1m span
Andy
Nov 25, 2015, 05:32 AM
The Depdart, lot of pics & Free Plans !
I have DD ... I think it is hard to flight indoor. It is very nervous and very speed.. the motor have to be always rev up...
The original span is about 60cm
