May 05, 2010, 10:26 AM
j2m2t2's Avatar
RCEFlyer What mah lipo? 3S? I'm building with a slight variation, going with a forward swept wing.
May 05, 2010, 11:43 AM
RCEFlyer's Avatar
Hi,
@Goldguy: thx for this tip I haven't got any problem so far, but i'll keep taht in mind !
I think i did'nt get any toruble cause it's a small plane, you never fly these things far away
@j2m2t2: I'm suing a 3S/610mAh Lipo up to 3S/800mAh. Flying time varies from 6,5 up to 8 minutes.
So, i gues i'm gonna see a lot of depdarts (pics !!!)
Grtz,
Menno
May 05, 2010, 12:03 PM
j2m2t2's Avatar
Thanks RCEFlyer. Here are pics of WIP.
May 05, 2010, 12:17 PM
RCEFlyer's Avatar
Hi,
you're welcome
Looks like a nicebird to me !
I'm looking forward to the report of the maiden-flight ...
Happy flying form the Netherlands.
Grtz,
Menno
May 05, 2010, 07:22 PM
flyin' fool
goldguy's Avatar
Kind of looks Alula-ish.
That gets me wondering, this may make a good simple fun sloper too.
May 05, 2010, 07:38 PM
j2m2t2's Avatar
It kind of is. I scaled down the thumbwing (posted here in scratch) to 27" WS. I tried this before but struggled with the fuse. This seems like a great match.
May 06, 2010, 02:49 PM
Look mom, no hands
Soaring Calvin's Avatar
Hi what would this be like as a second plane?
May 06, 2010, 10:20 PM
flyin' fool
goldguy's Avatar
What's your first?
May 06, 2010, 11:01 PM
Look mom, no hands
A hobbyzone supercub lp
May 07, 2010, 01:52 AM
flyin' fool
goldguy's Avatar
If your fairly proficient with flying it, since it has ailerons, then flying the DepDart shouldn't be too much of a problem. Just remember on the first flights, don't fly it at full tilt until you have it all trimmed out.
It's so simple to build, then repairs should be easy and that will prolong it's life while you learn to fly it.
Elevons on a flying wing work like this...............give right rudder command and the model will roll to the right, not turn, but roll. To get it to turn once you've started it to roll, you have to give some up elevator. In other words, it 'yank n' bank'.
Most important....keep it light.
You'll find a big difference between this and you cub, as the cub is a very heavy model and always though they were not a great trainer because of that.
Just have fun............
May 07, 2010, 12:23 PM
Good morning all,
Thank you RCElFlyer for this plane !
I want to build one to try to improve my flying capacities !
I have a problem with the PDF files : the wingspan of the printed drawing is about 65 cm and not 71 cm, as previously indicated.
As I am not a specialist with the printing systems ... I probably make a mistake !
Could you please check this point and, maybe, post a DXF version for my Autocad software.
Thank you and good fly
May 07, 2010, 04:11 PM
RCEFlyer's Avatar
Hi,
you're welcome. I loved this little plane too
What plan did you use ?
I used the A0 plans (non tiled version, in the tiled version i had the same problem as you mention.
Could you try the A0 plans ?
Let me know !
Grtz,
Menno
May 07, 2010, 04:12 PM
j2m2t2's Avatar
Here it is ready for maiden. Thanks RCEFlyer for the plan and I hope you don't mind that I went with a forward swept wing.
Also if anyone wants the scaled down thumbwing for their DepDart I can post it here.
May 07, 2010, 04:16 PM
RCEFlyer's Avatar
Hi,
no problem j2m2t2
I'm just as curious as you how your plane will do !
Let us know !
Grtz,
Menno
May 07, 2010, 10:04 PM
j2m2t2's Avatar
First flight a success, flies fast and smooth. Not floaty for low ground maneuvers but it will loop and roll with ease, not like a drill, needs a little room.
Im running the 1500kv blue and red wonder with an APC 6x4. 3S pulls less than 8amps WOT and its plenty fast especially at only 27"WS. Ill try and get some video soon.
