May 08, 2019, 02:08 PM
Epilepsy Awareness
Flying High Mike's Avatar
Originally Posted by ChickenDrumstick
400 feet, unless you have Eagle vision I doubt most people could tell what direction a 20" plane is facing at that distance with the naked eye. Almost to the extent that I don't believe it. I feel sorry that you lost the plane, although it is clearly 100% pilot error and somewhat irresponsible. But still.
I can remember when I first started flying. 100' seemed like 1,000'
Just a rookie observation. He probably lost control at 100'/150'...even that is stretching it
May 08, 2019, 05:37 PM
Dinosaur
condor12's Avatar
Thanks CD. Weather lately is catching me out. Next day I put my 3m Fox up on a test flight for the RTH stab, and at around 500ft it entered cloud which I thought was much higher. The RTH test proved itself, as it re-emerged heading home on descent to its default 50m RTH altitude. Yep, not easy to see, but can be done. Fortunately, I still have 20/20 vision (probably not for much longer!) On the clear sky day Champ went MIA, I put my Mavic (a smaller dark grey quad) up to 150meters out at about the same distance and could passably see it - enough to control it. I agree, it was pilot error in that I didn't get a wind check at height (it was basically calm at ground level). As I said I have done this kind of flight many times before without mishap. I enjoy gliding him down with birds flying around him. I'll put the new one up on a similar flight if I consider the conditions allow it - but I will dive him if I see evidence of wind shear . Problem around home is that I have to fly him above 50 meters because of surrounding big trees., which requires higher flight due LOS constraints. Landing is in only one direction. I accept full responsibility for any mishaps
May 08, 2019, 05:48 PM
Dinosaur
condor12's Avatar
You're right Mike. That was about the height I lost him behind the trees on descent. Height wasn't the problem - it was the range by then! You'd be surprised how far and high you can see on a clear day. I'm used to flying at reasonable ranges (verified when flying my GPS equipped quads). Our highest gumtree in our yard is 40m high and I have no trouble seeing the top leaves But... enough said - got to go fly!
May 12, 2019, 10:05 PM
After a long winter ...and an as yet absent springtime...I finally got flying weather. The first since last Sept! So of course I broke out the little Champ! My thumbs lost they're coordination and as a whole my skills got very rusty! That's why I started over with something simple! Got in two flights before dark and all went well considering the first flight was a bit gusty. Two good landings. Couple loops on flight two. I think it's coming back to me after the long layoff!
May 13, 2019, 10:04 PM
Glad to hear you got some stick time in!! Wish spring would get here too...
May 14, 2019, 06:20 PM
Epilepsy Awareness
Ob, do you have you TX dialed in to get rudder command on the left stick as well as holding the right stick as command also?
It's a nice platform going into 4 Channel flight.
Oh, what kind of TX do you have?
May 14, 2019, 07:28 PM
Naw..I just right thumb it. I don't have much trouble transitioning to 4 channel. That' what I usually fly after a few spring warms ups with the Champ! Last night I got a couple flights in with my Sport Cub. I do have a tendency to forget to use my rudder on landings though.......ailerons for final steering low and slow is not the best idea! . I just use the DX4E that came with my Super Cub a coupleyears ago. Just started flying in 2016......a little late in life! Something I always wanted to do but couldn't afford when i was a kid!
Jul 23, 2019, 06:02 PM
Philippians 4:13
I haven't had to buy any batteries for my Champ for several years. what's the best deal out there now?
Jul 23, 2019, 10:39 PM
I use 200 ma/45c E-flights.
Sep 01, 2019, 09:40 PM
Elfi Flyer
Doug Sipprell's Avatar
I have had a HZ UM Champ in my micro fleet for years. Working with Champ #2 presently, and Champ #3 (given to me by another pilot) get occasional exercise. Presently using 210mAh 1S Nano lipos, also discovered a 250mAh 1S that works great. My favorite was the Hyperion 240 1S Lipo that gave great performance and flight times. Not sure if that 1S cell is still available.
I discovered the ParkZone PKZ3616 brushed motor, originally supplied with the UM P-51 Mustang, makes a great replacement motor for the Champ. Fits the Champ gearbox, gives good performance. Too bad Hobby Zone didn't follow-up with a 2S brushless powered Champ, as did E-flite with the UMX P-51 Mustang. Would have made a great micro. Just MHO.
RD
Sep 04, 2019, 04:41 PM
double post
Sep 04, 2019, 04:44 PM
RD
they did, the Champ S+, nearly 700mm wingspan though so basically a chubby UMX timber without flaps and lights.
HobbyZone Champ S+ RTF & BNF Overview (3 min 1 sec)
Discussion What plane is this? Debolt Livewire Champ-w/short video reacher10 The Builders Workshop 48 Mar 29, 2011 03:20 PM
Discussion Super Champ Restoration x-craft Off-road Cars 48 May 25, 2010 07:48 PM
For Sale Champ (1/8th scale, electric) Maggie Han Aircraft - Electric - Airplanes (FS/W) 12 Mar 19, 2010 08:31 PM
For Sale 2x Ni-Mh batts will fit PKZ or HBZ planes gazza1 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 07, 2009 09:46 AM
Question digital camera for hbz extreme bluescoobydoo Aerial Photography 0 Jul 31, 2005 11:25 AM
