Mar 23, 2010, 12:00 PM
Winging it “>
leadfeather's Avatar
Quick Stick, EPP Sport flyer, **PLANS**, Video
Outdoor season is on my mind now, so Ive been thinking about outdoor planes. One plane I thought was a pretty good sport flyer and windy day flyer is the Mini Ultra Stick. I decided to build something similar but out of EPP. The result is the "Quick Stick".
I really enjoy slow and close flying so the Quick Stick has some design features I'm hoping will make it behave nicely at the low end, especially the large control surfaces. I also lined up the thrust line and the wing and stab center lines as on a 3D plane. With the full airfoil wing and the full fuse I hope it has reasonably good high speed too.
From the photos below you can see I've kinda played with some canopy designs for different looks. I think I like the racer look the best.
I should be able to maiden this plane this evening.
PLANS provided by motorhead
Guts:
motor Tower Pro 2409-18T
or for more speed but runs hotter/draws more amps;
Towerpro 2409-12T
esc HKSS30
4 servos HXT900
Battery Rhino 3s 1050 mAh 20c
Connector for battery XT60
Connectors for motor/esc 3.5mm bullet
Wheels
Mar 23, 2010, 12:04 PM
Why yes, I am an R/C addict!
flyrcehelis's Avatar
Looks good!
Mar 23, 2010, 12:17 PM
John 3:16
Daddy-O's Avatar
I like this a lot. Looks like a fun plane. How did you get your LE sanded down so nice? Is that 1.3 or 1.9lb epp? I bet it's 1.9, because I can get the 1.3 to look that nice. Maybe I'm doing something wrong? Did you taper your elevons also?
Daddy-O
Mar 23, 2010, 01:16 PM
My plans are in my blog
Rusty-Gunn's Avatar
I favor the racer most. Canopies look cool way back.
Mar 23, 2010, 01:23 PM
I like the Edg-ish and Racer canopies.
Mar 23, 2010, 02:32 PM
Old Prop Buster
Sir Dumb Thumb's Avatar
I like the racer canopy. I already have two planes in line to build, so it looks like I may have a third.
Thanks Leadfeather
Mar 23, 2010, 03:34 PM
CMelton
cmelton11's Avatar
Will you be posting plans Leadfeather this is a cool plane and I too like slow and close flying also
Mar 23, 2010, 04:49 PM
Winging it “>
Daddy-O, The wing was hot wire cut by a flying buddy who has a cnc hot wire cutter. The entire plane is made from 1.3# epp. Except for the wing, the rest of the plane; including the canopies; came easily from a single 18" x 36" sheet of 9mm epp.
cmelton11, If the Quick Stick proves worthy there will be plans.
The forecast looks good for flying this evening!
Mar 23, 2010, 05:27 PM
dan i don't have a source for epp what is the difference between it and midwest cellfoam
Mar 23, 2010, 06:03 PM
Winging it “>
Midwest's Cellfoam is a polystyrene (Styrofoam) type product. It is in the same family as Depron and Buecor and Protection Board and Dow Pink foam.
EPP is much more durable, but more flexible than the polystyrene foams. Reinforced correctly, epp makes a pretty good airframe that can take a lot of abuse.
Mar 23, 2010, 06:26 PM
thanks i guess i'll need to find a find a epp mail order source
need to get those apache blades right
Mar 23, 2010, 06:40 PM
Old Prop Buster
deisel1
Here is where I get mine. They are not the only supplier.
http://www.rcfoam.com/
Mar 24, 2010, 07:48 AM
Vertical approach specialist
potshot's Avatar
Originally Posted by leadfeather
...If the Quick Stick proves worthy there will be plans.
Worthy? From lead? But of course! We'll just wait patiently for the plans.
Mar 24, 2010, 07:55 AM
Winging it “>
maiden flight and crash
The good: The Quick Stick flew very well. Good speed range and very good control, just what I was hoping for.
The bad: The elevator servo arm came off. I was about 40 or 50 feet up. I had just gone to full throttle and it nosed over and dove in really hard. It happened so quickly I barely pulled off the throttle before it hit.
The good: In spite of the hard "nose in", there wasn't a lot of damage. The epp near the nose cracked and the landing gear popped off. It is already fixed and ready to fly again. I think a balsa or Depron plane would have had extensive damage.
Here is a video of the maiden flight including the "pile driver" crash landing.
http://s715.photobucket.com/albums/w...n.flv&newest=1
Mar 24, 2010, 09:21 AM
Winging it “>
Update: Flew the Quick Stick this AM. Conditions weren't so nice but it flew like a champ.
Time for some paint.
For Sale Hobby People Sport Flyers Quick-1 EP Jet, ARF porcia83 Aircraft - Electric - Airplanes (FS/W) 6 Mar 18, 2010 12:38 PM
Poll To Expo on Mini Ultra Stick or not Intermediate Flyer Rob1962 Electric Plane Talk 10 Mar 15, 2010 11:38 AM
Discussion what is a park flyer and what is a sport flyer fla_larry Beginner Training Area (Aircraft-Electric) 18 Nov 19, 2009 01:33 PM
Wanted sport flyer I.e. Mini Ultra stick, T28, Ultra Stick 25 etc... Rockin G Aircraft - Electric - Airplanes (FS/W) 0 Jul 18, 2009 11:54 PM
