Windrider 60 inch Scout Bee - RC Groups
Mar 23, 2010, 12:05 AM
Ming's Avatar
This 60 inch molded EPP Flying Wings is now avialable on Windrider website:
http://www.windrider.com.hk/product.asp?id=165
Same airfoil of Beevolution but scale up to 60 inch, it fly much faster than 48 inch and good for DS!
Ming Lou
Mar 23, 2010, 12:39 AM
Registered DSer
Kahnx's Avatar
Ming
The "Description' Link on the page goes to the 48" BeeII/volution
Can you provide details of tip/root chords, wing loadings, and AUW? What about kit contents?
Cheers
Roger.
Mar 23, 2010, 01:08 AM
Ming's Avatar
Roger
Thank you, I will upload the update description ASAP.
Wingspan: 1.54 meter
Weight: 0.850 kg(included 50 grams ballast on the nose)
Wing area: 0.518 sq.meter.
Wing loading: 1.641 kg/sq.meter.
Lenght of chords: 39.5cm
Lenght of tip: 21cm
Remark: Each side of wing pre-molded 6mm X 4mm X 24 inch carbon rod
Two pcs of 1 X 4mm X 65cm carbon ribbon included
One 6mm X 4mm X 24 inch carbon rod as wing join
Ming Lou
Mar 23, 2010, 03:09 AM
by ZIPPER
ZIPPER's Avatar
Smile Ming, it's your new baby.
Mar 23, 2010, 03:16 AM
Ming's Avatar
Yes, another new member of Windrider Bee family.
I am designing the logo.
Ming Lou
Mar 23, 2010, 04:28 AM
Good Times
You should Design a EPP Seagull that looks as real as poss ,
But your BEE is nice and i may have to get 1
Cheers Ming
Bobbyr
Mar 23, 2010, 04:39 AM
Ming's Avatar
We have many difference size of flying wings for your choice:
Bee 48 inch
Mini Bee 34.5 inch
Micro Bee 24.5 inch
Ele-Bee 48 inch
Bat 52 inch
Beevoluation 48 inch
Ele-Beevolution 48 inch
Bee2 48 inch
Souct Bee 60 inch
Queen Bee 100 inch
Ming Lou
Mar 24, 2010, 05:27 AM
quick question about scout bee 60"
I just got my new 60" bee in the mail and I was wondering what the cg should be for the new wing...
Mar 24, 2010, 11:38 AM
Objects in mirror are losing
1000MPH's Avatar
10" from the nose according to this post...my guess is it is more likely at the rear spar slot.
I see one of these in my future but I already see that the servos will have to move outboard for any real speed. I like the spar arrangement. Similar to my go fast wings. I see Ming has fully embraced the arched spar layout.
Latest blog entry: Kinetic 2 Meter - K2mDP
Mar 24, 2010, 01:01 PM
Daemon's Avatar
10" is just behind the ribbon spar. The rear spar is only a couple inches in front of the TE.
The ribbon spar slots are now pre-molded so installing the ribbon is a 10 second operation.
Good job Ming, getting the slots molded in accurately.
The ribbons are bigger than the ones that come on the regular 48" Bee.
The winglets are 3mm thick and larger than standard Bee winglets, (about
the same size as the oversized winglets I make for my own 48" Bees)
The battery bay will take either a standard 4xAAA flat pack in the center, or a long 3S
Lipo crosswise for the powered version. Just cut the molded insert to fill the
remaining space.
ian
Mar 24, 2010, 01:37 PM
Ming's Avatar
All suggestion is welcome, we can amend the tooling on next patch of production.
Designing the logo, how about this?
Ming Lou
Mar 24, 2010, 02:16 PM
1000MPH's Avatar
remaining space.
ian
Sounds great. I'm digging those molded inserts on the Bee2. So you've had your hands on one? Is the thickness of the foil scaled up from the Bee?
Logo looks good Ming. I wouldn't know where to move the servos and still have the balance accurate. Probably better to leave them where they are and leave the experimenting up to the individual.
Mar 24, 2010, 03:35 PM
Daemon's Avatar
Existing or future? My Bee2 doesn't have molded ribbon spar inserts, but I'd love to see em.
Unfortunately for me, it's a scaled up Beevo foil. I picked up the Scout to use as a
new powered FPV platform which means it'll be overweight and I'd much prefer the Bee/Bee2
foil for its more versatile speed range with good low speed handling, over the Beevo which is fast, but
can tip stall when flown slowly. A scaled up Bee airfoil would also be thicker, to carry more FPV gear.
My Scout is liable to be pretty much unrecognizable when I'm done with it.
ian
Mar 24, 2010, 04:28 PM
1000MPH's Avatar
The pre-molded spar slot sounds great but I meant the inserts/covers for the radio gear. I like them far better than coro.
ian
Looking forward to your Franken Bee. I have a flying buddy with a powered Queen Bee that carries a payload, probably a little too big for your needs.
I'll be happy with the BeEvo foil but I was hoping it was going to be a bit thinned.
Mar 24, 2010, 04:38 PM
Daemon's Avatar
Thinner? The Beevo is already the thinnest wing on the market.
The Scout's foil is 1 1/2" at the thickest part of the root and 3/4" at the tip.
That's thinner than a 48" WW Raider. Make it much thinner and it gets pitchy
and doesn't turn very well.
ian
What size to do of Windrider Scout Bee? Ming Flying Wings 18 May 22, 2015 08:57 PM
25 inch molded Micro Bee by Windrider Ming Flying Wings 20 Dec 14, 2010 04:07 AM
Discussion Whos got the fastest 60 inch racer ? keone m. Slope 41 Jul 30, 2010 10:12 AM
Discussion Windrider 60 inch Scout Bee Ming Slope 11 Dec 26, 2009 01:49 AM
For Sale Big Bee ARF,NIB 60 inch wing ,hard to find,Clancy nick601 Aircraft - Fuel - Airplanes (FS/W) 1 May 09, 2008 07:57 PM
