Mar 22, 2010, 06:03 PM
Team Swallow
Jonas M.'s Avatar
Build Log
New DLG project: One-piece, oval fuse, Edge-foiled - show AND tell!
I'd like to share with you the build of my new DLG.
It will have:
- a one-piece fuselage with oval cross section
- a bagged wing,
- Gerald's Edge-foils, 4P planform
If there's interest, I'll try to show you a relatively easy way how to make oval fuselages and bagging a wing in one piece.
Mar 22, 2010, 06:49 PM
BillHones's Avatar
looks very sexy!
Mar 22, 2010, 07:47 PM
Kyle Clayton
Wave Glider's Avatar
Originally Posted by BillHones
looks very sexy!
+1
keep us updated please!
Latest blog entry: Helios and XXLite DLG
Mar 22, 2010, 08:03 PM
solastagia
kcaldwel's Avatar
Relatively easy, oval - do tell please!
Kevin
Mar 22, 2010, 08:46 PM
KAMAX-T's Avatar
New to dlg's , but as Bill said ......sexy
Mar 22, 2010, 10:33 PM
Barney Fife, Vigilante
tom43004's Avatar
Always interest in learning Jonas...
Looks good. What are you using to model, Catia?
Mar 23, 2010, 04:47 AM
G_T
G_T
Looking forward to it!
Gerald
Mar 23, 2010, 05:06 AM
Team Swallow
Jonas M.'s Avatar
OK, people, here we go:
I made the design in Rhino (same as you, Tom).
I made me some templates for the fusepod, top and side view.
Glued some layers of MDF together and cut them to shape.
It's actually the first time I use MDF to make the plug. So far I'm really happy with it.
Rounding off the edges.
Mar 23, 2010, 05:19 AM
Team Swallow
Jonas M.'s Avatar
Now for the oval boom. Unfortunately I haven't taken any pictures of the process, so I made some renderings in Rhino.
First of all I took a standard round boom. I used one of my first test booms.
Then I cut me two tapered pieces of 2 mm balsa. If the round tailboom has let's say 16 mm outer diameter and the oval should be 21 mm in width, I had to cut a triangular piece of balsa with 2.5 mm on the big end an zero at the rear.
These long thin balsa strips are then glued to the sides of the boom.
They provide a guidance for sanding the bondo to shape.
The bondo is put in the corners between boom and the balsa.
Next comes what we all love most on our hobby: sanding, sanding, sanding...
Mar 23, 2010, 06:53 AM
Is the oval boom a plug, or simply a very heavy oval boom?
Mar 23, 2010, 07:17 AM
Team Swallow
Jonas M.'s Avatar
It's part of the plug.
I attached it to the roughly shaped MDF plug.
Now I can sand the MDF to the final shape.
When done, I brushed thin epoxy on the plug, just the front part and the balsa strips on the boom.
After curing I sanded the plug in stages up to 600 grit.
Mar 23, 2010, 07:35 AM
Jeff Carr
Jonas
Very cool and keep the pics coming. I was wondering if the horizontal tail will be elevated above the fuse or lay flat on top of it? I really like the looks of the fuse
Jeff
Mar 23, 2010, 07:42 AM
Team Swallow
Jonas M.'s Avatar
Jeff, it just looks like it lays flat on the boom. I'll use a v-mount with a full flying stab. I just didn't know how I'll do it exactly so I didn't draw it in Rhino.
Glad you like the pod.
Making templates:
Btw: is it OK for everyone if I stick with metric units?
Mar 23, 2010, 07:45 AM
Yes. OK with me. Force the basta..... uhm.... guys to learn metric.
Mar 23, 2010, 07:46 AM
tom43004's Avatar
Please do use metric units Jonas. I was just about to complete my conversion to metric when I finished the CNC and ONE piece of CAM software doesn't support metric!?!?!
Nothing sucks more than converting drawings and machine code back and forth from mm to inches to mm to inches to mm........ AAAARGH!
Sold One Piece Molded DLG Fuse tom43004 Aircraft - Sailplanes (FS/W) 2 Feb 17, 2010 09:48 AM
Discussion New DLG fuse design/ Oval Boom Pt 2 The_Builder Composites Fabrication 20 Feb 10, 2010 03:44 PM
Build Log Homebuild - one piece fuse pyrsly Hand Launch 15 Jan 14, 2010 06:01 PM
Discussion Extra 330S full fuse foame-new project:30% bigger one from depron Pinci 3D Foamies 63 Jan 10, 2010 07:48 PM
Dare Jenny project so far (show and tell) sky guy Scale Kit/Scratch Built 44 Apr 06, 2003 12:02 PM
