I tried mine some today and was having some problems as well. A couple of times the plane tried to dive on me and I barely got out of it. I went back to 1.6 and it is working much better now.
I'll start donating to that!
But honest - I try get support from the other guys, and am often told to basically RTFM. Which is fine, sometimes, but you guys, even the non-DragonLabs guys (So, users, I mean) are so quick to help. I have been ignored soooo many times with the other supplier that I no longer ask questions there and settle with what I have. The DragonLabs threads are just leaking useful and helpful information, which makes frequenting these forums -fun! I haven't flown for a few months now due to a go-live on a large Government project we've been working on for a few years. High stress, and loads of hours. But I have a nice glider ready to be put together.... DOSD+V2 will fly it for me... but battling with planning the wiring. So, I will be on here a lot soon, begging for help. |
Do you have the same issue ? http://www.youtube.com/watch?v=AIUYlL_odSc |
psykokwak,
That's the tuning of the DCM filter in 1.8.1 not being optimized for flight use. All of the default tunings lean too much towards the accelerometers and the result is what you see. If you tweak the weightage you may get better results in turns but slower self corrections. Daniel |
Kris -- I'll attempt to recreate it here in ASCII. This could get ugly. Code:
_BMP085_ 3v3 -------->D1|-----| vin | | | | C1 | | | | | GND -----------------| gnd | SDA -----------------| sda | SCL -----------------| scl | -------- -Andrej |
Thanks for your answer. Could you give me your values for the waightage in your last version ? Using your 1.6x branch version on my ArduImu, I have drift as this video shows http://www.youtube.com/watch?v=64Z0jiyx-8I I don't know why :/ |
Hi,
Installed on my Arduimu the new version 1.8.1, did not work either .... ..good,,, I have no more Drift, ..the bad, the horizon is not parallel and rapid stabilization is not ... I do not understand programming, but something weird is that on the ground responds very well ... but when flying is all wrong ... maybe .. the data used For those who can give a help, I have videos of these tests, if needed ... if someone can just improve the drift in the previous version 1.6,from the last version 1,8.. Hopefully you can solve ... |
Hello guys,
I've been out for a while...what i've lost ? I saw that an airspeed sensor was added,a new baro sensor ?! (From where can i buy the airspeed sensor? ) Big question: does anyone managed to figure the throttle management during autopilot ? (having a specific altitude,speed during autopilot-waypoins) Craig give me your Paypal, I want to send you via paypal the ! from "send Craig a DragonLink!" . You did an awesome job with the PC Commander. |
When I get lock in on my GPS, The servos start twisting. What can cause this? The GPS wire is close to ESC wire, PPM wire from dragonlink reciever to the OSD and RSSI wire from the dragonlink to the DragonOSD. I use ferrite on the GPS, but still it take some time to get a lock in. Maybe the GPS module is broken?
I've not done much with waypoint flights. I've not had much luck in getting it to climb/dive to set altitudes via the Mission Editor program. I also just use manual throttle control. With my Dragon Link system I have no worry about flying outside of control range. I'd lose video way before Tx control so I can just flip my AutoPilot switch on and know the DOSD will bring my plane back home. My DOSD does seem to hold current altitude fine so I just let it RTH at whatever altitude I'm at when I engage AP. |
Thread Tools | |
Similar Threads | |||||
Discussion | Dragon OSD | Level Flight | FPV Talk | 22 | Dec 31, 2013 09:08 PM |
For Sale | New Intelligent Flight Dragon OSD | bfischer | Aircraft - General - Miscellaneous (FS/W) | 7 | Jul 19, 2010 11:56 AM |
Discussion | FS Ready to fly Intelligent Flight Dragon OSD | bfischer | FPV Talk | 0 | Mar 03, 2010 06:57 AM |
Discussion | RV OSD or Dragon OSD | djdaveq | FPV Talk | 1 | Feb 06, 2009 01:18 AM |
Discussion | RV OSD and Dragon OSD - so near to being Really good! | magnetman | FPV Talk | 8 | Nov 11, 2008 06:13 AM |
