hey guy's just a quick question regarding Failsafe. I was doing ground testing today and went full throttle with the control sticks in the neutral position. Then, I turned on Autopilot and set the failsafe on my Dragonlink. I guess what I'm trying to get at is, will the throttle automatically adjust itself up to and including full throttle if failsafe were to occur? I have selected the option where DOSD controls throttle.But I just want to make sure that this will not take my throttle to being at full all the time when engaged in AP, but rather will use throttle up to full to maintain speed and altitude.
So I tried searching for the solution to turning off the master warning and I couldn't find it. I initially tried entering the menu screen and exiting out... and this didn't get rid of it. Then, I tried using the SW button and had no luck with that either. I've tried to look through the forums/threads but I haven't found a solution. Maybe there is a solution and I'm just not seeing it. Anyone have some further suggestions?
Many thanks |
Well, basically what I'm trying to achieve is turning off the master warning that shows up in the middle of my screen. It usually comes on with my Voltage 1 or 2 battery drops below a predetermined value. So what's happening in my case is that when the master warning comes on, I can't seem to turn it off by entering menu or using the SW button. Those are the only to options listed in the manual and so I'm trying to figure out why it's not working for me.
when you hit the momitary button, (I assigned mine to my trainer button). do you see a little pop menu just above the Voltage2 menu? Sorry if i missed you saying you do.
According to the manual, once it triggers the low voltage alarm, and if you were to turn it off using the above mentioned methods, the low voltage alarm should not re-trigger whats it's been turned off. Only the RSSI value will re-trigger.
I have had times when the master Warning wouldn't clear before. I don't rightly recall what the trigger was now. I didn't consider it a game changer as I could fly just fine with the Warning flashing. Most times a simple SW switch or in and out of the Menu takes care of the Warning. |
I know some are flying with a KK 2.0 board with OpenAero, but the question (which I know involves some MCU soldering) is:
Can a HK KK 2.0 board be used as an IMU? It can perform stabilization and auto-leveling, but I'd like to see an artificial horizon in the DOSD screen. Is it possible? |
What version f/w do you have installed? Try a different version to see if it continues...or just reload the firmware you currently have installed. It could just be a firmware glitch. Normally my Warnings do clear, but there are times when it hasn't...I hasn't been enough of an issue for me to really dig into what causes the Warning to not clear.
Thread Tools | |
Similar Threads | |||||
Discussion | Dragon OSD | Level Flight | FPV Talk | 22 | Dec 31, 2013 09:08 PM |
For Sale | New Intelligent Flight Dragon OSD | bfischer | Aircraft - General - Miscellaneous (FS/W) | 7 | Jul 19, 2010 11:56 AM |
Discussion | FS Ready to fly Intelligent Flight Dragon OSD | bfischer | FPV Talk | 0 | Mar 03, 2010 06:57 AM |
Discussion | RV OSD or Dragon OSD | djdaveq | FPV Talk | 1 | Feb 06, 2009 01:18 AM |
Discussion | RV OSD and Dragon OSD - so near to being Really good! | magnetman | FPV Talk | 8 | Nov 11, 2008 06:13 AM |
