Mfpage |
I have a bass wood deck inside mine that the Velcro attaches to.
The trick I found for Velcro onto foam, is to rough up the foam and poke small tooth pick sized holes into the area. Then use your glue of choice. I use 5 min epoxy. I use this method for Velcro straps. Blu |
Dick |
Dick |
From my quick research the problem is amplified y harness causing a voltage drop as they heat up. This can result in a brown out. I got my fun cub second hand and have been less than pleased with the "stock" motor. 13x4 does not have the vertical I hoped for. I am using an 3s E flight 30c 2200 pack. My first flight were way nose heavy as I did not read the cg location. Gave it a quick finger balance and flew it. The lack of elevator authority on approach was lacking but it flew fine. Ripped the gear off as the landing gear plate was not glued in the best, plus I clipped some corn stubble. I used some ca and made some baking soda fillets around the outside. I am looking at the articulated gear. I am curious as to how they perform and if they are worth the added weight? They are pricey as well.
I am hoping I can just mix the other flap servo for now. I intend to pick up a 7 Chanel receiver so I can have full length aileron, flaperon, flaps. Crow would be fun to but it seems to not work well with th DX7 as it requires to many mixes. I am not much of a programming guru but I am going to try to make this work for now. |
Funcub Whacks Tree
Here you go. Nothing but the takeoff and then the crash, again, and again. Enjoy. It's all repaired.
Latest blog entry: Eagletree Guardian vs. Eagletree Vector
LMAO! Great vid sorry about the crash though.
Made me smile for sure. Hopefully the wind is more mellow tomorrow. It was a bit gusty today. I had a crash just like that in a smaller area with my UMX carbon cub. It came out unscathed though. Looking forward to trying out the flaps tomorrow,
Thread Tools | |
Similar Threads | |||||
Discussion | Fun Cub | sinowace | Hitec/Multiplex USA | 14 | Oct 09, 2011 04:43 PM |
Discussion | Multiplex Fun Jet at the lake | bah7566 | FPV Talk | 31 | Jan 03, 2010 10:19 AM |
For Sale | Multiplex Fun Jet -- PRICE DROP | Toby W | Aircraft - Electric - Airplanes (FS/W) | 2 | Dec 28, 2009 10:51 AM |
Video | Multiplex Fun Jet FPV set up test | bah7566 | Electric Plane Talk | 0 | Dec 25, 2009 11:05 PM |
Wanted | multiplex fun-jet or trade! | heli123 | Aircraft - Electric - Jets (FS/W) | 0 | Nov 14, 2009 12:02 PM |
