Mar 10, 2010, 02:15 PM
Gearmotors for high thrust /1S
Vladimir88's Avatar
Data
Gear brushless micro-motors to achieve maximum thrust with powered only by 1S.
I apologize for my bad English, I use the electronic translator.
This theme is aimed at creating gearbox with brushless motors powered only from 1-Cell (1S).
This theme is for those who are not satisfied with the parametres of motors (even the very best that you can buy today).
[I]I think many people afraid to do their own gearbox.
In my opinion it is much easier that you are able to do.
You only need three main things:
1 - desire to do;
2 - miller Machine;
3 - reamers.
I have the following equipment:
MICRO miller MF 70 - http://www.proxxon.com/en/micromot/27110.php?list
Scroll saw DS 230/E- http://www.proxxon.com/en/micromot/27088.php?list
The quality of my last works after 2019 is determined by the new equipment, which includes an American lathe and milling machine from Sherline.
List of important information located in this topic:
1. List of parts for gearbox- https://www.rcgroups.com/forums/show...9&postcount=56
2. My opinion on the use of propellers- https://www.rcgroups.com/forums/show...&postcount=120
3. Gearbox C05M(3:1)A (mounting system in Mustang P51D).
Weight- 5,4 gr., thrust - 83 gr.(3,7 V; 3,8 A; prop-130x70mm).
The description here after the list.
4. Gearbox HP03S(4:1)A (mounting system in Mustang P51D).
Weight- 4,5 gr., thrust - 72 gr.(3,7 V; 3,3 A; prop-130x70mm).
The description- https://www.rcgroups.com/forums/show...5&postcount=31
5. Installing Gearbox HP03S(4:1)A in Mustang P51-D.
The description- https://www.rcgroups.com/forums/show...5&postcount=38
6. Gearbox HP03S(4:1)B (mounting system with carbon tube).
Weight- 4,4 gr., thrust - 72 gr.(3,7 V; 3,3 A; prop-130x70mm).
The description- https://www.rcgroups.com/forums/show...5&postcount=45
7. Gearbox HP03S(5:1)A (mounting system with carbon tube).
Weight- 4,6 gr., thrust - 80 gr.(3,7 V; 3,0 A; prop-160x70mm).
The description- https://www.rcgroups.com/forums/show...3&postcount=49
8. Gearbox HP03TR(5:1)B (ultra-light design mounting system).
Weight- 3,7 gr., thrust - 80 gr.(3,7 V; 3,0 A; prop-160x70mm).
The description- https://www.rcgroups.com/forums/show...8&postcount=63
9. Installation Gearbox HP03TR(5:1)B on "Ultra micro 4 - Site".
The description- https://www.rcgroups.com/forums/show...6&postcount=67
10. Gearbox HP03TR(4:1)C (mounting system in Su-26).
Weight- 4,1 gr., thrust - 72 gr.(3,7 V; 3,3 A; prop-130x70mm).
The description- https://www.rcgroups.com/forums/show...6&postcount=84
11. Gearbox HP03TR(4:1)D (ultra-light design mounting system in Su-26).
Weight- 3,7 gr., thrust - 72 gr.(3,7 V; 3,3 A; prop-130x70mm).
The description- https://www.rcgroups.com/forums/show...&postcount=101
12. Gearbox HP02TR(4:1)B (ultra-light design mounting system).
Weight- 2,5 gr., thrust - 35 gr.(3,7 V; 1,5 A; prop-140x45mm).
The description- https://www.rcgroups.com/forums/show...&postcount=103
13. Gearbox HP02TR2(6:1)A (ultra-light design mounting system).
Weight- 2,5 gr., thrust - 40 gr.(3,7 V; 1,7 A; prop-140x45mm).
The description- https://www.rcgroups.com/forums/show...&postcount=117
14. Gearbox HP06V2(5:1)A (ultra powerful).
Weight- 7,9 gr., thrust - 140 gr.(3,7 V; 5,7 A; prop-GWS 8 x 4).
The description- https://www.rcgroups.com/forums/show...&postcount=118.
15. Gearbox HP02TR4(6:1)B (ultra-light design mounting system).
Weight- 2,2 gr., thrust - 40 gr.(3,7 V; 1,45 A; prop-140x45mm).
The description- https://www.rcgroups.com/forums/show...&postcount=127
16. Gearbox HP02TR5(6,7:1)C (ultra-light design mounting system).
Weight- 2,5 gr., thrust - 46 gr.(3,7 V; 1,84 A; prop- MCF6030SS).
The description- https://www.rcgroups.com/forums/show...&postcount=130
17. Gearbox HP03TR6(6,7:1)F (with good efficiency).
Weight- 3,6 gr., thrust - 67 gr.(3,7 V; 2,44 A; prop- 130x70mm).
The description- https://www.rcgroups.com/forums/show...&postcount=154
18. Gearbox HP05S1(4:1)E (with very good efficiency and big thrust).
Weight- 5,8 gr., thrust - 100 gr.(3,7 V; 3,28 A; prop- 160x70mm).
The description- https://www.rcgroups.com/forums/show...&postcount=158
19. Gearbox HP03TR7(6,7:1)F & HP03TR8(6,7:1)F (with very good efficiency and reliability of a design).
Weight- 3,70gr.
For mod.TR7- thrust - 60 gr.(3,7 V; 1,94 A; prop- 160x70mm).
For mod.TR8- thrust - 70 gr.(3,7 V; 2,30 A; prop- 160x70mm).
The description- https://www.rcgroups.com/forums/show...&postcount=160
20. Installation gearbox HP03TR7(6,7:1)F on "UMX EXTRA 300 3D".
The description- https://www.rcgroups.com/forums/show...&postcount=163
21. Gearbox C05M(5,3:1)E (with very good efficiency).
Weight- 4,8 gr., thrust - 80 gr. (3,7 V; 2,83A; prop- 130x70mm).
The description- https://www.rcgroups.com/forums/show...&postcount=190
22. Installation gearbox HP03TR8(6,7:1)F on "EXTRA 330 Carbon 3D".
The description- https://www.rcgroups.com/forums/show...&postcount=213
23. Gearbox HP02TR6(6:1)E (with good efficiency).
Weight- 2,6 gr., thrust - 40 gr.(3,5 V; 1,55 A; prop- MCF6030S).
The description- https://www.rcgroups.com/forums/show...&postcount=226
24. Gearbox HP02TR6(7,3:1)F (with good efficiency).
Weight- 2,60 gr., thrust - 39 gr.(3,5 V; 1,39 A; prop- MCF6030S).
The description- https://www.rcgroups.com/forums/show...&postcount=227
25. Gearbox HP03TR10(7,3:1)B (with good efficiency).
Weight- 3,4 gr., thrust - 56 gr.(3,5 V; 1,96 A; prop- MCF6030SS).
The description- https://www.rcgroups.com/forums/show...&postcount=228
26. Installation gearbox HP02TR6 (7,3:1)E on "M-Zone" (Wingspan- 445mm; Weight- 21,0 gr.!).
The description- https://www.rcgroups.com/forums/show...&postcount=229
27. Gearbox HP05S2(4,2:1)Sb for «UMX Sbach 342».
Weight- 6,5 gr., thrust - 102 gr.(3,5 V; 4,11 A; prop- 160x70mm).
The description- https://www.rcgroups.com/forums/show...&postcount=247
28. Gearbox HP02TR6(7,3:1)G with weight – 2,0 gr. and thrust 33 gr. .
The description- https://www.rcgroups.com/forums/show...&postcount=248
29. Gearbox HP02TR9(4:1)0,3SA with weight – 2,4 gr. and thrust 54 gr.(!) for 3D.
The description- https://www.rcgroups.com/forums/show...&postcount=280
30. Gearmotors based on RaceStar micro-motors.
31. Gearbox "GM1103-01(4/1)0,3BA" with weight – 4,1 gr. and thrust 70 gr. with prop. 5"(carbone 3-Blade).
The description- https://www.rcgroups.com/forums/show...&postcount=284
32. Gearmotor "GM1103_08B_3,00_0,3_4,0BA1,5B" with weight – 4,7 gr. and thrust 64...108 gr. with prop. 4...6".
The description- https://www.rcgroups.com/forums/show...&postcount=292
33. Gearmotor "GM1103_09B_3,00_0,3_4,0BB1,5B" with weight – 4,5 gr. and thrust 55...92 gr. with prop. 4...6".
The description- https://www.rcgroups.com/forums/show...&postcount=297
34. Gear Motor "GM0805_07S_3,00_0,3_4,0BB1,5B" with weight – 4,2 gr. and thrust 47...80 gr. with prop. 4...6".
The description- https://www.rcgroups.com/forums/show...&postcount=301
35. Gear Motors "GM1102" with weight – 3,2 gr. and thrust 48...67 gr. with prop. 5...5,5".
The description- https://www.rcgroups.com/forums/show...&postcount=316
36. Gear Motors "GM0803" with weight – 2,6 gr. and thrust 25...67 gr. with prop. 3,5...5,5".
The description- https://www.rcgroups.com/forums/show...&postcount=323
37. Gear Motors "GM0802" with weight – 2,1 gr. and thrust till 60 gr. with prop. 3,2...6,0".
The description- https://www.rcgroups.com/forums/show...&postcount=337
Extremely powerful motor with gear with 83 grams of thrust for the aircraft Mustang P-51D & Su-26m (ParkZone)!
With this motor - gear plane Mustang P-51D has a fantastic flight dynamics, it just simply astonishing.
Middle position handles "gas" of the transmitter is in the 1/3- 1/2.
And on a complete "gas" the plane can go vertically up 100 meters for 3- 5 seconds!
With such a motor-installing the Mustang P-51D there is a possibility fly in the wind 3 - 5 m/sec.
Parameters gearbox C05M(3:1)A :
Motor - C05M-11000- http://www.hobbycity.com/hobbycity/s...runner_11000kv
Total weight of the motor with gear - 5,35 grams.
The total weight of the motor with gear with the regulator, wires and connector is - 7,40 grams.
The static thrust with a propeller of the P-51D Mustang (130x70mm)-
- 75 grams (U = 3,5 V; I mot = 3,4 A; T mot = 45 C; Eff= 6,30 g/W);
- 83 grams (U = 3,7 V; I mot = 3,8 A; T mot = 49 C; Eff= 5,90 g/W);
- 100 grams (U = 4,1 V; I mot = 4,5 A, T mot = 55 C; Eff= 5,42 g/W).
The static thrust with a propeller on the Su-26m (160x70mm)-
- 85 grams (U= 3,5 V; I mot = 4,1 A, T mot = 52 C; Eff= 5,92 g/W);
- 115 grams (U= 4,1V; I mot = 5,3 A, T mot = 67 C; Eff= 5,29 g/W).
Tests were conducted with the Spectrum AR6400 receiver and magnificent the Czech regulator "TMM 0703-3 EXPERT"- http://mgm-compro.com/index.php?tid=...-0703-3-expert
The main problem when designing a new gearbox was the fact that at low gear ratio reducer decreases the diameter of large gears and the main axis of the gear because of this unacceptable approaches to the body of the motor. This problem was solved by installing the shaft in bearings with flanges.
To increase the diameter of holes in the gears I used the scan -
http://www.microflight.com/Online-Ca...amers-Set-of-3
or "tapered reamer set/ 6 pieces: 0.3mm to 1.5mm diameter"-
http://www.homefly.com/products.asp?id=11
To fix the gears with increasing diameters use plywood with a hole.
As a large gear, I used G336 36t (36 teeth) -
http://www.bsdmicrorc.com/index.php?productID=832,
but you can use a from the reducer gear Su-26m or the Mustang.
As a small gear, I used G312 097 12t (12 teeth) -
http://www.bsdmicrorc.com/index.php?productID=831
http://www.homefly.com/products.asp?id=37
Rolling bearings "1.5mm bore ball bearing w/flangewith" bought here - http://www.homefly.com/products.asp?id=9
Fee gear cut from carbon sheet thickness of 1,5 mm (actually 1,75 mm).
(Better use of material other-Fiberglass Sheet (Black) 2,3 mm - http://www.espritmodel.com/index.asp...OD&ProdID=2230 ).
As the main shaft gear I used a shortened 1.5-mm shaft gear Su-26m and Mustang- http://www.horizonhobby.com/Products...ProdID=PKZ3528
Mar 11, 2010, 06:01 AM
Vladimir88's Avatar
I also want to add.
Rolling bearings must be pasted in carbon plate on epoxy resin.
In the photo this not.
Mar 11, 2010, 12:19 PM
Hello Vladimir,
That is a great job! Very nice looking gearbox and over 3:1 thrust to weight is awesome.
Bob
Mar 12, 2010, 12:08 AM
Vladimir88's Avatar
Hello, Bob.
Thank you for the evaluation of my work!
Vladimir.
Mar 12, 2010, 01:42 AM
Vladimir88's Avatar
It must be borne in mind that with such great traction motor and, accordingly, currents through the motor there are increased demands on the output resistance of the regulator.
For example when using the well-known and the cheap ESC XP-7A
(http://www.micronradiocontrol.co.uk/xq_esc.html) maximum thrust falls on 15-20 grams!
Mar 16, 2010, 12:14 PM
Vladimir88's Avatar
The question of selling motor with gear to visitors of this topic
Dear Sirs, perhaps there is a way to sell a set of parts of the gearbox with the motor.
Are you ready to buy it?
It is necessary for a store that could sell you the parts.
Apr 09, 2010, 08:15 PM
Vladimir88's Avatar
Here is video of flight Mustang P51D with the requirement of a brushless motor (C05M-11000) with gearbox (1 : 3).
(5 min 38 sec)
Apr 13, 2010, 02:32 PM
Респект ! Пошел смотреть на rcdesign.ru
Apr 14, 2010, 06:42 PM
Apr 15, 2010, 01:15 AM
Vladimir88's Avatar
Вы не поняли.
У меня нет никакой материальной заинтересованности.
Для меня эти редукторы - хобби.
Я не сотрудник каких- либо магазинов.
Я предлагаю помочь желающим самим повторить редуктор, купив готовый набор комплектующих в магазине.
Но для магазина (а не для меня!) нужен опрос заинтересованности в этом.
Самый вероятный вариант, кто мог бы этим заняться - магазин BSD MICRO RC, владелец - Bob Selman http://www.bsdmicrorc.com/index.php?productID=909
Я об этом писал уже на RC Design - http://forum.rcdesign.ru/f80/thread1...ml#post1777515
Поэтому пишите ему все по адресу - <[email protected]> и есть очень большая вероятность того, что он откликнется!
Всё зависит от ВАС!
You do not understand.
I have no any financial interest.
For me, these gearboxes - a hobby.
I am not member of any shops.
I suggest that help wishing to repeat ourselves gearbox, bought a ready set of components in shops.
But for the store ( and not me!) need a survey of interest in this.
The most likely option, who could do this - shop BSD MICRO RC, owner - Bob Selman http://www.bsdmicrorc.com/index.php?productID=909
I wrote about it already on the RC Design - http://forum.rcdesign.ru/f80/thread1...ml#post1777515
So write to him at all - <[email protected]> and has a very strong likelihood that he will respond!
It all depends on YOU!
Apr 15, 2010, 01:21 PM
Apr 15, 2010, 03:15 PM
Vladimir88's Avatar
Да нет, собственно уже изначально особенно никто и не появлялся, чтобы затем исчезнуть, кроме моего знакомого Boba.
Я не понимаю, неужели никому не интересен этот мотор- редуктор?
No, actually the outset especially, no one appeared, that would then disappear, except for my friend Boba.
I do not understand, surely no one interested in this motor-reducer?
Apr 15, 2010, 03:52 PM
Apr 15, 2010, 03:58 PM
Vladimir88's Avatar
Тогда будем ждать пока они сделают и поделятся уже своими впечатлениями.
Then we will wait until they do, and already share their impressions.
Apr 15, 2010, 04:02 PM
Article Hangar 9 P-51D Mustang Sport 40 ARF with Robart Retracts Review Michael Heer Electric Warbirds 96 Yesterday 09:01 PM
Data Brushless motor with reduction gears for aircraft Su-26m and Mustang P51D (ParkZone) Vladimir88 Scratchbuilt Indoor and Micro Models 7 Apr 09, 2010 09:20 PM
Sold Ultrafly P-51 Mustang w/brushless motor wayneabonga Aircraft - Electric - Airplanes (FS/W) 2 Mar 18, 2010 02:56 AM
Sold ...... Steve H. Aircraft - Electric - Power Systems (FS/W) 1 Mar 10, 2010 09:17 PM
Sold P-51D MUSTANG (ArtTech) W/RETRACTS & GEARBOX PnP Sammy70 Aircraft - Electric - Airplanes (FS/W) 7 Sep 17, 2009 10:52 AM
