May 26, 2003, 09:17 AM
Tempest's Avatar
Motor suggestions needed for a Wemotec Minifan 480?
I'm sure this has probably been covered in numerous other threads, but after a few unsuccessful searches I figured I would risk asking it again.
I just purchased an RBC Huckebein and Wemotec Minifan 480.
I have read Bob P's thread on his Huckebein powered by a Model Motors MV 2020/20. (It's a beautiful plane Bob, and probably the catalyst for my deciding to build one.)
I am curious if there are any other suggestions in terms of the best motor and battery pack for this aircraft and fan combination. I know the MV 2020/20 is brushed. Are there any brushless motors that can provide even better performance or duration?
Any thoughts would be greatly appreciated.
Thanks!
Paul
May 26, 2003, 09:49 AM
Hi Tempest,
I also ordered the Huckebein, the Blohm&Voss and the Yak23 Flora from Rob Bulk.
I will try the KONTRONIK Fun 480-37 or the FUN 400-36 with 8-10 cells. First I will try some 1700 SANYO or later if possible the HR-4/5FAUP SANYO.
Heiner
May 26, 2003, 10:02 AM
EDF Head
Haldor's Avatar
For 10cells you'll be best of with a motor with a kv=3500-4000. Using that you'll be able to use the fairly inexpensive 40A ESC's
My favourite 10cell combo is the Kontronik Fun400-36/Smile40-6-12 ESC. The Hacker B40-11S is very close in performance though its heavier than the fun400 series. (110g vs 125g)
Heiner mention the 480-37, if you're staying on 10cells max choose the 400-36 as its lighter and comfortable with the powerlevel (<420W) - and therefore better suited. However if you decide you want more power (450+W) the 480 series has an edge.
Get the HR4/5 1950mAh FAUP cells
Jun 11, 2003, 09:22 PM
Tempest's Avatar
Thanks Haldor and Heiner for the replies!
I was browsing the ICare site this evening with the intent of buying the 480-37. If I may run 10-12 cells, which controller should I purchase? I see that they also carry the BEAT controller in addition to the SMILE.
Any thoughts are well appreciated.
Regards!
Paul
Jun 12, 2003, 12:42 AM
Paul,
it is said, that the BEAT controller is better, if you are not going full throttle all the way.
Heiner
Jun 12, 2003, 12:43 AM
Lithium Member
Herb's Avatar
The Huckebein seems a rather light (and not very strong - as it's entirely made out of balsa) model. Go with a lighter setup, Hacker B40-11S or Kontronic Fun 400-36 or Mega ACn 16/15/2 or /3 on 8-12 (depending on winds) CP 1700 or CP 1300 or FAUP cells ...
Jun 12, 2003, 01:50 AM
EDF Head
Haldor's Avatar
The 480-37 will cope with 13-14cells and will be around 50A at that count. 10cells a 40A ESC is enough but at that count the 400-36 is better in terms of lightness and enough for the job.
Jun 12, 2003, 07:37 AM
Tempest's Avatar
I also have a Steve Neill ME P 1101 on order. Based on your collective suggestions in this posting, and Herb's posting in the ME P 1101 threads, it sounds like a 400-36 for the RBC Huckebein and a 480-37 for Steve Neill's Me P 1101 are the appropriate size motors to use.
I have not seen many references to AVEOX motors in these threads. Why is that? Are the KV's not high enough?
Thanks everyone for your help!
Paul
Jun 12, 2003, 08:07 AM
EDF Head
Haldor's Avatar
Tempest - for up to 400-450W the Fun400 range and hacker B40-S will do, above this you need the larger motor such as fun480 and Hacker B40L. In the <400W range a 40A ESC is sufficient.
Powerwise there is little difference between the 400-36 and 480-37, the diff is only that the 480 will take two more cells with ease.
For Steve's ME1101 I'd think the Fun480-42 or the Hacker B40L equivalent on 10CP1700's will haul butt, you'll need a 60A ESC though
Jun 12, 2003, 09:39 AM
Tempest's Avatar
Thanks Haldor!
For the higher amperage applications what controller would you suggest? In perusing Kontronik's product line the only BEC enabled controller I see at that amperage is the BEAT 70-6-12. Would you suggest using a non BEC controller?
Can I use other manufacturer's controllers (i.e. JETI)?
Thanks again and sorry about all of the questions.
Paul
Jun 12, 2003, 11:04 AM
Ohe
Ohe
My Huck fly well with B40 13s (3300kv) climbing at 60° without slowing down , very large loops,... for 4 minutes with 10 Rc1600.
So the fun 400-36 will do faster
A good choice!
Olivier
Jun 12, 2003, 12:08 PM
EDF Head
Haldor's Avatar
At 50+A draw most ESC mfgrs advice against BEC use.
Jun 13, 2003, 01:14 AM
Paul,
my FUN 400-36 and the FUN 480-37 are running fine with a BEAT 55 opto and also with the 70 A Jeti. But I would suggest use always opto controllers when drawing high A.
Heiner
Jun 13, 2003, 07:43 AM
Tempest's Avatar
Thanks Heiner!
What cell count are you running ?
Paul
Jun 13, 2003, 02:57 PM
Paul,
400-36 up to 10 cells, 480-37 up to 11 cells. It depends if I am using them in an EDF or just with prop.
Heiner
