PW1211 dlg
Hi folks,
Trying to find out where the PW1211 hinges as a % of chord from the TE. Also, is this foil (in it's natural form) already w/ the reflex typically needed to trim flying wings? Thanks, John |
Dear John
as the airfoil is made for lower Re (smaller planes), the upper side has not such a long laminar flow (to prevent seperation bubbles). On the other hand the laminar flow on the underside of the airfoil is almost always 100%. So there is no "special" flap chord for this airfoil. So the recommendations are rather general: If you have a very slow flying plane, make the flap chord a bit deeper (up to 30%) flying faster og with bigger planes go somethin in between 20 and 25%. Concerning the reflex: Again, because it is made for lower Re applications the reflex is somewhat "bigger" than with fx the PW51. So the experiences with this airfoil show, that you will need just a tad of "up trim" to fly slow. With no flap defelction the plane (airfoil) will go in a flat fast glide,about best gliding angle for planks. All the things metioned above can on the other hand not seen to be totally unconnected with the geometry of the plane....as always. Hope this helps Yours Peter |
Helps heaps. Because of my tendency to cartwheel, I'm wondering if I can cut away the elevons short of full span to prevent the elevon from crumpling. The concern is having the tips at an organic "down" trim if the actual foil requires some up to trim out neutral. (wing's 48", ~3 to 4 oz loading so it'll be reasonably light, slightly forward swept). I know there may not be a clear answer, but this is my dream ship and want to do it right the first go-round. The layup is 1.7 kevlar with CF caps at the tip as well as the root (this being 25lb foam and all). What are your thoughts? Full span on the elevons or would it be OK to leave some carbon out there (which would be my preference) ![]() Can I cut the elevon in the black or better to go full-span? ![]() Thanks, John |
I have a thread in the slope forum...but here's the video of the maiden.
Need a little help with my launch technique ![]()
Thanks for posting - very inspiring! I love your plane - I dreamt about building one like this (in essence a composite Alula). What are the significant parameters (span, weight, wing loading)? It seems to be a nice floater, but it's hard to tell on the slope.
Best, Mihai |
Hi John
Nice plane and great location to fly, thanks for sharing! You seem to have a sturdy transmitter ![]() Reto |
Latest blog entry: thoughts on contest flying
![]() As shown in the vid, I'm at 9 oz, 4.5 oz/sq ft loading (I made the planform w/ 2 sq ft just for loading calcs ![]() The wing is laid up pretty heavy as I don't need a flatland plane, but the "PWP" as I call it handled the sloppy conditions pretty good. I have no doubt that the planform could be AUW 6.5 or so (3.25 oz/sq ft) as PWP's nose is long and tail is balsa, laminated (0.5 oz). The pod is actually dougmontgomery's "curb appeal" pod for 50" DLG. The DLG blade will be installed this weekend. Peter Wick mentioned an increase in camber for better thermal ability at the expense of acro. My foil is the stock PW1211. Reto - the Eclipse7 TX is a brick house! ![]() John |
Excellent!
I would be very interested in still air flight time from a DLG launch. Curtis Montana |
Thread Tools | |
Similar Threads | |||||
Question | PW1211 airfoil properties | RCPC | Hand Launch | 8 | Sep 14, 2017 09:33 PM |
Discussion | why is my plane only thermal under reflex | seaspb | Thermal | 59 | Mar 16, 2010 09:29 PM |
Reflex flight sims. Reflex v Reflex XTR | davereap | Simulators | 0 | Jun 12, 2005 08:22 AM | |
Qs for video-philes ..... | logan5 | Life, The Universe, and Politics | 1 | Nov 08, 2001 10:21 PM | |
V-tail Qs | t-turley | Power Systems | 4 | Oct 13, 2001 02:11 PM |
