Roswell Flyer - RC Groups
This thread is privately moderated by Greasetattoo, who may elect to delete unwanted replies.
Feb 28, 2010, 07:37 PM
The tattoo guy
Greasetattoo's Avatar
Build Log
Roswell Flyer
Hey all,
Starting a new build..
I thought I would bring back the old Roswell Flyer.
And do it up right.
Mikrokopter style...
I am building the flyer from oak and ash wood.
It will be pretty much a standard flyer.
No frills.
See next post....
Feb 28, 2010, 07:43 PM
The tattoo guy
The Bus
Well, I had to figure a way to build my wire bus for the Roswell.
Here is what I came up with.
This is just a prototype.
I will be doing it in black delrin.
It will be thinner too!
It will hold up to 16 wire on top (positive) and bottom. (negative).
I will be getting a nylon wingnut, too!
Of course, I will not be using all the wires.
Just use what I need.
Onto the next step...
Feb 28, 2010, 07:45 PM
The tattoo guy
Top Plate
This is the top plate.
Still needs finishing.
Will probably use some tung oil on it!
Onto the next step....
Feb 28, 2010, 07:46 PM
The tattoo guy
Top plate with bus
Here is the top plate, still unfinished, with the bus attached.
Feb 28, 2010, 07:47 PM
The tattoo guy
Bottom plate
Here is the bottom plate, again it is made from oak with ash inlay....
Unfinished.
Feb 28, 2010, 07:50 PM
The tattoo guy
Motor mounts
Here are the motor mounts.
Oak and unfinished.
Feb 28, 2010, 07:51 PM
The tattoo guy
Arms
I have yet to make the arms.
Will be made from Ash.
Probably this week..
Stay tuned!
Mar 05, 2010, 12:11 PM
The tattoo guy
Well, I made the 4 arms.
They are made from ash.
Everything is going together, good.
Now, I have to get the electronics together.
Finish and sand all the wood.
I will do it in a tung oil.
Hopefully, I should have the electronics done by next week.
Watch for updates.
Mar 05, 2010, 08:37 PM
1.21 Gigawatts!
Steph280's Avatar
Wow this brings back memories. I still have one of those original foam frame in the box. Do you plan to sell your frame, or is this a personal project of yours? I'd love to update mine as well.
Mar 05, 2010, 08:45 PM
The tattoo guy
Steph280,
https://www.rcgroups.com/forums/show....php?t=1202041
I have one of the goofy vertibird things too!
Dragancopter, I believe.
Just finished my landing gear.
Will post pictures tomorrow.
This is kinda just a hobby I do.
Keep watching my blog, I will try to update as I go.
I have to put a Finish on the frame now..
tung oil.
That will probably take a week or so.
Then the motors, electronics, and should
be ready to fly.
Thanks for stopping by.
Mar 05, 2010, 09:22 PM
The tattoo guy
Landing gear added.
Now the not so fun part.
Putting the finish on it.
We'll see you in about a week. : )
Mar 06, 2010, 11:56 AM
The tattoo guy
1st coat of Bush oil.
I will coat it with about 2 more coats, then glue it all together.
After it is glued and coated a few more times, I will proceed onto the electronics.
Stay tuned.....
Mar 09, 2010, 12:08 PM
The tattoo guy
Here is the final wire harness bus.
It is skinnier then the white one.
I think it should work good.
Still waiting for the Oil finish on the frame to dry.
Will put about 4 coats on.
Maybe more...
Mar 24, 2010, 09:24 AM
The tattoo guy
Been awhile..
I was going to use a plastic top from a Icee cup for the cover/dome of my quad.
Well, that did not look just quite right, so I decided to make a wooden one.
I made this one from Oak, Ash and the red stripe is Pauduk.
I designed the dome in a 3D program and cut it out with my CNC machine.
The dome is made from 10 layers of wood.
I think it will work just fine..
To be continued....
roswell flyer aerodragon Electric Heli Talk 32 Jul 20, 2007 08:51 PM
FS: Roswell Flyer w/ Carbon Fiber Frame $300.00 Frankenator Aircraft - Electric - Airplanes (FS/W) 2 Aug 05, 2002 12:23 PM
Roswell Flyer on Ebay, ends 3-17-02 13brv3 Aircraft - Electric - Airplanes (FS/W) 1 Mar 16, 2002 05:37 PM
Wanted - Roswell Flyer Allan Wright Aircraft - Electric - Airplanes (FS/W) 1 Sep 21, 2001 12:17 PM
do they still sell the roswell flyer? BeechSkipperDude Electric Heli Talk 4 May 10, 2001 01:22 AM
