Feb 25, 2010, 11:25 PM
Martin - AKA mr.sneezy
PLMS's Avatar
FrSky 2.4ghz - Telemetry protocol discussions
I felt it will pay to branch out now to this thread for talking about the nuts and bolts of the FrSky Two Way systems telemetry protocol, and how to best use it.
The two PDF documents from FrSky are attached.
Martin
The originating thread is here
https://www.rcgroups.com/forums/show....php?t=1176328
Feb 26, 2010, 05:11 AM
Dan Thompson (MP8K developer)
Iflyj3's Avatar
Thanks for the docs. They do help. Now, I am waiting on the availablilty of the system.
Dan
Feb 26, 2010, 05:24 AM
Proud to eat Kraut ;-)
Julez's Avatar
Way to go!
This will be a very cool hack project.
Feb 26, 2010, 06:36 AM
PLMS's Avatar
Originally Posted by Julez
Way to go!
Yep, I think FrSky may be very clever to build the telemetry into their modules AND make the protocol public. I imagine a lot of interesting DIY projects can be sporned from this bit of gear, and of course sell more modules for them.
We should try coordinate effort a bit, but I know everyone will have a different pet project.
KISS (keep it simple stupid) is the way to go initially for me.
My first thought is to build a local-end display using a 16x2 Hitachi LCD and a 18 pin PIC. I like the PIC16F819's at the moment, but could use others if there is a better and easy to get suggestion.
The second thought is then to add buttons and serial commands to program the alarm points in the TX module without a PC.
Then go to the remote end and make an interface for the EagleTree E-logger to 4800b serial, to be sent over the serial link.
Each stage builds on the last.
That's just my quick thoughts, you guys must have many more. Hit the thread with them.
I'll knock up a serial cable tomorrow and have a look at the TX modules output. I suspect I'll need to use something HEX friendly like VBHexterm rather than Hyperterm though.
http://www.synthmodules.com/vbhexterm.htm
Feb 26, 2010, 07:09 AM
Way to go!
Bye, bye, Hitec... you missed a great opportunity to be the first...
Guys,
May I suggest to use a very common microchip such as PIC16F628 and a simple 2x16 LCD as display, so that every RC Modeller can easily purchase the CHIPS and LCD Display...........another even cheaper display is to use a simple 4 Digit 7 Segment LED Display......... hope you can also share its source code.
I guess, the finished products will just look like a simple terminal a 2 x 16 LCD display with 4 Button , this is very common Display terminal used by Mini TURBINE Engine use in RC JET Plane.
Feb 26, 2010, 01:19 PM
DJI Supporter
Sid3ways's Avatar
Subscribing. Someone get Melikh to design some hardware we can buy thats PNP.
Feb 26, 2010, 02:02 PM
MelihK's Avatar
Hehhee I'm Here
Actually i designed new LRS with XBee modules. And it's on production now
You can control plane by PC or remote from 45 km with Xbee Pro modules
Reveiver module including voltage controls and extra 6 channel analog sensor input to telemetry.
PCBs on production now , i will receive them in 2 weeks
Feb 26, 2010, 07:00 PM
PLMS's Avatar
Originally Posted by lazy-b
Guys,
OK, I have PIC16F628's in my parts box, so I'll use that one.
I'll go with 16x2 LCD myself, they are so cheap now and I have lots I've scrounged from old hardware.
Yes, the source WILL be shared. But keep in mind that I'm a Hardware guy that dabbles in Software, so don't expect too much finesse...
Melihk, whats LRS stand for ?
Feb 26, 2010, 07:03 PM
hi, Melihk,
I can not believe my eyes. could it range for 45 km?
Feb 26, 2010, 07:51 PM
DJI Supporter
Sid3ways's Avatar
Melihk is my hero and this is just in time. I've been shopping for a telemetry system that would give me a range out warning (Hitec fell short, Jeti Duplex not available in US) and this FrSky system looks to have some potential. But I guess I won't need much of a range out warning if I have a signal 30 miles out. I know the XBee modules are great and many quad flyers use them. It sounds like an all in one solution, let's get it done Melihk. I'm your 1st customer.
Feb 26, 2010, 08:57 PM
here is the setting software by FRSky.
http://www.frsky-rc.com/download/fdd...al-version.rar
Feb 27, 2010, 12:14 AM
MelihK's Avatar
Originally Posted by RobertWing
hi, Melihk,
Yes this is maximum range of XBees.
I'm planning to sell only RC reveiver and transmitter boards(you dont need that if you want to use PC) and customers will buy XBees from sellers like Sparkfun.
It is best option for everyone because;
- XBees selectable to 433Mhz-868Mhz-2.4Ghz
- Ranges selectable in 30 meter to 45km
@Sid3ways
Thank you very much for this compliments
Feb 27, 2010, 08:11 PM
PLMS's Avatar
A quick play on the bench with serial output.
I have had a busy weekend with little time for FrSky fun. However I have got some HEX dumps of the serial stream from the TX module to post up.
If you don't have a HEX EDITOR to open the LOG files with you will see just rubbish on screen (notepad etc will try display hex in ascii characters).
To see the raw hex output open the log in something like this.
http://wwwwww.mitec.cz/hex.html
If you don't want to do that, then look at the PDF's, but they are not the whole file, just a page.
Frames start with FF FE, there are 10 bytes total. Signal level can be seen varing on the 5th byte of the second log file. I attenuated the signal with a piece of steel pipe over the TX's antenna to vary the level.
00h seems to be the value for strong signal/low errors, the value goes up as errors go up (signal going down).
The 'Range Out' warning beeper in the TX module started beeping, so it was really cutting the signal down. The RX end was also around the other side of my house BTW, my shed door was shut too. The system seems quite sensitive based on testing other brands the same way.
Martin
Feb 27, 2010, 08:36 PM
PLMS's Avatar
VB app programmers ?
Any VB guy's listening on the thread ?
We could do with a VB Hex term appy that will look for the FF FE header and display the frame in a box, with each new frame over-writing it. This will make setting up sensors etc on the RX easier to do, as it's MUCH easier to see where that byte you're interested in is changing if it's in the same place on screen each frame.
The app could actually have multiple 10 byte boxes down the screen and grab each different header and it's data and display in their own 10 byte box.
Looks like there's 8 possible headers (e.g. FF FE........ FF FA........ etc).
Also good later would be a VB app to send the alarm setting commands...
Can anyone do this, or know of an existing app ?
Mini-Review FrSky 2.4ghz - looking good so far! BrumBob Radios 13426 Aug 31, 2018 03:17 PM
Cool TWIN 2.4GHz new RFHSS system from CZ, with or w/o Telemetry alex.guzun Radios 6 Jul 31, 2016 10:41 AM
Discussion New Audio Modem Protocol For FPV Telemetry MelihK FPV Talk 138 Dec 31, 2011 10:24 AM
New Product FrSky 2.4GHz radio system jonathan-FrSky Australia 70 Apr 28, 2011 04:22 PM
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 02:18 AM
