Feb 19, 2010, 03:16 PM
Help!
power supplies...making one w/x360 ps?
hey guys,
i have a computer power supply that i made into an AC/toDC for my turnigy 6..
now id like something that doesnt give me input V error..
has anyone used or know if an Xbox360 ps can be used?
its specs are
input AC 100-127V-5A , 47-63hz
output DC 203W, 12V---16.5A, 5Vsb---1A
if anybody has any ideas........
thanks
Feb 20, 2010, 07:41 AM
ggcrandall1's Avatar
Possible with the Xbox ps (based on the specs you give).
But why are you getting an error from your converted PC power supply. If you did the conversion correctly you should be getting 12 volts from it. Are you attempting to pull too much current. Have you measured the current and voltage (easy to do with a wattmeter)?
Glen
Feb 20, 2010, 08:49 AM
Memopad's Avatar
You have to put a load on the 3 or 5v side (someone help me i forgot) to get steady voltage from the 12v leads. I've always used a car tailight bulb and never had a problem. Ignore if you've taken care of this already.
Feb 20, 2010, 07:42 PM
i havent put a taillight bulb...i just mad the graound and positive side to a bolt so its like a car batt also w/an on and off switch
so i should just check the output with my multimeter and see how much V im getting..
im not good with electrics at all im selftought and its a bit hard for me t get but im trying...
with the x360 i use the multimeter to find the 12V supply and ground then id use whichever conn id like...???
if anybody knows of something easier...
thanks
Discussion Using two power supplies for higher voltage/capacity chargers: safety issues jj604 Batteries and Chargers 655 Aug 16, 2019 07:00 PM
Discussion BAE Hawk w/PS $137 Shipped, Sukhoi $80 Shipped typhoonmaster Hot Online Deals 3 Feb 08, 2010 02:58 PM
3 PC PS's to One 15V DC Power Supply FR0D0 DIY Electronics 29 Jun 06, 2005 09:47 AM
FS: 2 Corsel power supplies: one slighty modded, the other isn't almies Aircraft - Electric - Airplanes (FS/W) 13 Jun 12, 2004 01:58 PM
