Feb 18, 2010, 11:30 AM
2 MANY TOYS :-)
Hoverup's Avatar
Help!
Federal Standard paint purchase
Looking to get paint for my RAF SAR Westland Wessex HC 2 heli. I have the correst Federal Standard 595 code, but can't find a source to buy it from. Any helpful reply welcomed.
Cheers - Boyd
AMA 80393
IRCHA 3355
Major USAF
Retired
Feb 19, 2010, 05:58 AM
you might try www.warbirdcolors.com
Feb 19, 2010, 08:14 AM
ARFs Are Me
TomCrump's Avatar
Bob has your answer.
The colors are accurate. Water clean up.
Good stuff, for sure !!!
Feb 19, 2010, 08:30 AM
2 MANY TOYS :-)
Hoverup's Avatar
Many thanks guys. This was one of those times that Google let me down. I knew some of you pro's here would be helpful.
Cheers - Boyd
Feb 19, 2010, 08:43 AM
ARFs Are Me
TomCrump's Avatar
IF you go with WBC, follw the instructions implicitly. By doing so, you won't have any problems.
WBC sprays differently than most products. That's why you need to follow the instructions for spraying.
I use distlled water for thinning. The viscosity should be the same as milk.
Dark colors take less water than the lighter ones.
Good luck, and have fun !!!
Feb 19, 2010, 08:44 AM
I'm suprised that the RAF would use Fed Standard 595 paint colors.
Federal Standard 595 is a US paint standard, and the UK has it's own British Standard (BS) color system. I would expect RAF aircraft to be painted in colors using the BS system.
What is the source of your color information? Are you using RAF technical documents to reproduce the accurate colors of an aircraft, or using the paint information from a plastic model kit?
A plastic model is more likely to include painting instructions using Fed Standard paint colors, because the colors are similar to the correct colors, and they are available from model paint suppliers. I don't know of anyone supplying British Standard colors in model paints.
Ken
Feb 19, 2010, 08:57 AM
ARFs Are Me
TomCrump's Avatar
There are FS colors for just about everything.
If you have the correct FS number, you color will be correct.
Feb 19, 2010, 08:41 PM
2 MANY TOYS :-)
Hoverup's Avatar
Ken
Like Tom posted, the federal standard color chips are available for many nations other than the USA. They have pages of color chips for period aircraft both fixed and rotary wing for the RAF and RN. They have a chip specific to RAF SAR Helis which is where I got the code from. At a scale comp, I'll have the FS color chip for the judges to hold up to the model to confirm the replication.
Cheers - Boyd
AMA 80393
IRCHA 3355
Major USAF
Retired
Jul 11, 2019, 05:31 PM
Federal Standard Paint By LVP Paints
LVP Paints sells FED-STD-595 paint. If you have the color code you can easily find it on their site. Their is also no minimum order size and it is good on metals & plastics: https://www.lvppaints.com/Federal-St...ray-Paint.html
Discussion California to get $2.25 billion in federal high-speed rail funding 2SMOKINBARRELS Life, The Universe, and Politics 9 Feb 01, 2010 10:31 AM
Question Federal Standard 595 colors or close moose229 Dock Talk 3 Mar 19, 2008 04:42 AM
Question Federal Standard paints Air-Gar Scale Fuel Planes 1 Dec 30, 2005 05:54 PM
Question Federal Standard paints in spray Air-Gar Scale Kit/Scratch Built 2 Dec 30, 2005 03:28 PM
Want to See a Federal Standard Color? EricBjorn Scale Kit/Scratch Built 4 Dec 06, 2002 06:00 PM
