Feb 09, 2011, 08:29 PM
Thermal Wrangler
DrFragnasty's Avatar
Supra Bits
Thanks Marcus.
Ideally I'd use the Nexor Pro pod/boom and V-tail combo further down the track.
In the meantime however it gets the Supra bits I got from Big Al.
Should have more done over the next few days. Waiting on 2mm carbon rod for pushrods then it's fit-out and fly.
How's Machine #6? going?
Chris.
Feb 10, 2011, 02:06 AM
Hey Back Off Machineman! You lookin' for a good Rogerin' ??
They sound like war wordz....
Feb 10, 2011, 03:56 AM
mmmmm....BEER
Did someone mention Rogerin'........
Timmy, you da rogerin' man!
Feb 10, 2011, 06:11 AM
Thermal Wrangler
Team Machine Mascot
Ladies please!
Feb 11, 2011, 06:44 AM
Thermal Wrangler
Hinges
First for me was cutting wiper slots and abrading the hinge underneath.
Semi-successful.
Wiper slot was a breeze but took several light strokes with the router so the bit wouldn't build up heat and melt rather than cut.
The semi bit was how the hinge line had to be shifted towards the TE so it wouldn't clash with the sub-spar. This meant the hinge sat plumb on an area where the balsa wasn't chamfered. This made the hinge hard to bend.
Remedied by relieving some of the balsa from the inside once I could get in there and sand some away.
The peel-ply (Abresegwebe sp?) seems ok and the hinge is solid. Having the hinge so close to the sub spar does that. There's ony 7 mm from hinge to sub spar.
Hints on abrading the hinge from underneath; don't bother laying down masking tape, just cut into the paint. The Dremel disc works well.
  • 20 strokes it'll go through the paint and 3/4 oz 'glass
  • 20 more strokes and you're through the carbon.
  • Stop when it goes a lighter shade and the pitch of the cutting action goes up. That's when it's hit the peel-ply.
Next up; do the other 3 surfaces then wipers.
Chris.
Feb 11, 2011, 04:04 PM
Chris
The fibre glass shop have 2mm glass rod by the metre.
I normally by 10 - 15 metres at a time
Feb 11, 2011, 04:29 PM
Thermal Wrangler
Thanks Mike,
Cooincidentally ordered 10x 1.5m last week from them!
The locals just stock 1m lengths.
Bought any new toys lately ;0) ?
Chris.
Feb 12, 2011, 12:48 AM
Thermal Wrangler
Wip
Other flap done.
Previous recommnedation to ignore masking tape while scribing hinge is wrong.
Use it.
Peel it off once you're past the paint and veil layer though. The remove the guide alum angle and go freehand so you can better "feel" when you hit the peel ply.
Junior Saw from Bunnings was $5 well spent. Hint: prime the cut first with scalpel so the saw doesn't wander.
Next up; beer o'clock!
Chris.
Feb 13, 2011, 08:24 AM
Thermal Wrangler
Slots done
All slots done.
Resorted to ball router bit because the wing depth tapers to a very thin profile and the other bit would have gone straight through.
Finish sanding slots and working the hinge then servo bays next.
Chris.
Feb 13, 2011, 10:04 AM
Detail Freak
target's Avatar
Tape wipers?
Feb 13, 2011, 08:13 PM
Thermal Wrangler
Bog Wipers
No. Bog mix. It'll be a 1st for me.
I'll be relying on Steve's expertise (he's the bog wiper master) on this one.
hang on...bog wiper master just sounds plain wrong ;0)
Chris.
Last edited by DrFragnasty; Feb 13, 2011 at 09:23 PM. Reason: spelling is plane rong
Feb 13, 2011, 09:29 PM
mmmmm....BEER
'Bog wiper master'!!!!
Dude, I don't know how to respond to that.
Maybe just dignified silence
Feb 14, 2011, 12:10 AM
Detail Freak
target's Avatar
Does that mean 'Boagy' is also 'Boggy'??
I'm looking forward to seeing the wiper process. I think I kn ow how it's done, but I will reserve any questions or comments until the pics are posted.
The plane looks great so far.
R,
Target
Feb 14, 2011, 02:05 AM
Thermal Wrangler
It only just occured to me after looking at the photo of the Junior Saw ploughing its way through the wing; it might be a better idea to use the dremel cut-off disc to scribe the line THEN use the Junior Saw. That way any chance of paint flaking is minimised.
Boggy has a ring to it, you could be onto something...
Chris.
ps. re: The picture of the sweaty gent with the gun...there IS a connection to the thread's evolution you know...1st one to get it gets an extra special nickname.
Last edited by DrFragnasty; Feb 14, 2011 at 02:16 AM. Reason: frogs have opposable thumbs
Feb 14, 2011, 03:22 AM
mmmmm....BEER
Boggy! HUH!
Dignified silence.
Discussion Building RC Helicopter from Scratch hidavi Electric Heli Talk 19 Mar 12, 2010 07:07 PM
Discussion workshop for scratch building skyguy04 The Builders Workshop 5 Sep 21, 2009 07:43 PM
Discussion Scratch building F-18 D - Styrofoam Impy Foamies (Scratchbuilt) 2 Sep 07, 2009 07:57 PM
Discussion First scratch building project Impy Foamy EDFs 3 Sep 04, 2009 08:56 AM
Discussion Scratch building with the wild hawk daveyedgar Beginner Training Area (Aircraft-Electric) 0 Aug 30, 2009 09:03 PM
