Jan 26, 2010, 07:55 AM
tallflyer's Avatar
Data
slofly22
Ok I will be doing a complete Slofly22 build this week
Here are the free plans That I converted from the original Sloper Steve files from his old web site slofly.com using google sketchup and the free Gimp program and a program called PosteRazor that converts files into PDF
the plane will be made out of 1.3# 9mm epp foam
1. Bluewonder 1300 kv motor
3 bluebird 306 servos
a Spektrum Receiver
1. 10 amp brushless esc
gws prop
1. battery pack 360 mah 7.4 volt lipo
1. GWS 9050 prop
Update for the receiver orange 2.4ghz micro receiver
1. motor mount
Download the free plans below.
Jan 26, 2010, 08:45 PM
tallflyer's Avatar
Plans printed to paper :)
The file takes 8 sheets of 8 1/2 x 11 to print
Here is a picture of all the pages printed taped together.
Latest blog entry: Yunnec Typhoon H Review
Jan 28, 2010, 04:07 PM
6mm Depron?
I really want to build one of these. I just wiped out my old
plane with a 8mm bearing tube CDROM motor on it and
have most of the electronics. Do you think it must be built out
of 9mm depron? I have a bunch of 6mm. I also have some
3mm and I suppose I could glue them together.
Thanks for posting all this info.
Jon
Jan 28, 2010, 04:11 PM
tallflyer's Avatar
jumpinj
This Plane was designed around 9mm epp foam as the foam can take a crash tha twould destroy other planes made out of Depron.
"You can build most planes like this out of FF,Bluecore,Pinkfoam,Depron and they will fly it's just not going to bounce back from a crash like EPP does.
Jan 28, 2010, 04:12 PM
aileron servos
Also, how is the aileron servo attached to the one servo?
Jon
Jan 28, 2010, 05:47 PM
tallflyer's Avatar
Jumpinj
After looking at The picture in the build thread Great question!
Lets take a look for a different angle and this will explain it better
The Aileron Servo arm can be seen in the photo below works both Ailerons
I shot a first hover video Will post in a minute stay tunned.
Jan 28, 2010, 05:59 PM
tallflyer's Avatar
A few Video Stills
Ok so She hover good Need to get her outside now! Need the wind to stop
Jan 28, 2010, 06:38 PM
3D wannabe
smokejohnson's Avatar
I like the soldering iron idea. I have been borrowing my friends Dremel with a router attachment...too cheap to buy one for myself .
Plane looks great
Jan 28, 2010, 06:44 PM
tallflyer's Avatar
Plane looks great
Funny after all this time this was the first time I tried the method of Printing out the plans, and then attaching them to the foam using a light spray of 3mm77 and then just cutting out the parts! "WOW so much faster and cleaner
and the lines come out better" who says a old dog cant learn a new trick, for those of you who still hand cut this has to be the best method,
I call this method!
PRINT
PASTE
CUT
Just make sure yo have a new #11 x-acto blade a good ruler and some 3mm77 spray and your good.
Jan 28, 2010, 08:00 PM
3D wannabe
Have you tried 3M-45? Half the cost and works just as good if not better for what we use it for.
http://www.castlewholesalers.com/3M-...ve-16-Oz-.html
Jan 28, 2010, 08:46 PM
tallflyer's Avatar
Another Great find.
I will have to look for it as your right the 3m77 is like $12.00 a can the 3m 45 is like so cheap.
Great find
Jan 31, 2010, 12:53 PM
EPP Source?
Thanks for the info on the aileron servo. I should have know that.
I decided not to use Depron for the fuse. I already have a set of wings
the right size left over from another planethat are
an EPP airfoil and I'll probably use these with a 9mm
EPP fuse.
Where did you get your sheet of 9mm Depron?
Jon
