Mar 11, 2010, 02:25 PM
P. Tritle's Avatar
E- The only real difference between the 8, 9, & 10 is the windsheild, so the mod to the earlier model will be a snap.
PAT
Mar 11, 2010, 03:23 PM
Steve Merrill's Avatar
Great thread! Love the Stinson. Mine's just a little bigger
Mar 11, 2010, 05:40 PM
P_J_Glor's Avatar
Great looking model, Steve. How about posting your avatar picture, too!
Pete G.
Mar 13, 2010, 12:19 AM
P. Tritle's Avatar
Wheel Pant Fairings
Like with the upper landing gear fairings, the wheel pants are also done using wedges fore and aft, with an upper and lower paper fairing section. As with the upper LG fairing, the patterns for all the parts will be provided on the plans.
Mar 13, 2010, 12:21 AM
P. Tritle's Avatar
Lower Strut Fairings
The lower strut fairings considt of the base, two wedges, plus the top and bottom paper parts.
Mar 13, 2010, 04:46 PM
Yankeeone's Avatar
Pat, the colors on your Stinson look wounderful!! Diana Cream and Dark Green fit the bill perfectly. Also looks like Gold pinstriping. Beautiful!!! Can't wait to see the "N" numbers in place. Looking forward to hearing about the maiden flight (which will be no problem).
The Yank
Pat, hope you don't mind me posting up a couple pics of my Standard. BTW, my Standard does a fair loop.
Mar 13, 2010, 09:57 PM
I eat glue
Nice Yank, is your Standard, Standard
Mar 14, 2010, 08:34 AM
P. Tritle's Avatar
Yank, Come on in anytime.... AQnd BTW, the Standard looks GREAT in the air!!!
PAT
Mar 14, 2010, 04:00 PM
Any plans to attach the cowl? I made a ring that is fiberglassed to the inside of the cowl, positioned against the firewall. mounting screws go inside.
Mar 14, 2010, 04:55 PM
P. Tritle's Avatar
Mounting the Cowl and Fitting the Windshield
The cowl was mounted using 3, 1/2" sq. 1/4" bass wood blocks glued to the firewall. The cowl was then screwed in place with small servo screws.
The windshield frame turned out to be wrong, so had to move the forward pillar to elininate a bend in the panel that wasn't supposed to be there. Once that was done, the panels were cut to shape, glued in place and trimmed in gold.
Mar 14, 2010, 04:56 PM
P. Tritle's Avatar
Adding the Graphics
As always, Callie did a great job printing the graphics!!!
Mar 14, 2010, 05:02 PM
P. Tritle's Avatar
Adding the Finishing Touches
A bit of paint was used to highlight the radial engine, then the prop was added and the model ballanced. Will start with an APC 12-6E and see what happens.Turns out that the battery heeded to go all the way forward for CG, so a second hatch was added to the fuselage bottom. The original hatch will remain in place for servo and Rx access.
In the end with the 2500 mah 2S battery, the Stinson tips the scales at 27.8 oz. -- a little lighter then I had expected. The only thing left to do now is fly!!!
Mar 14, 2010, 05:05 PM
P. Tritle's Avatar
Sometimes the Weather Man Just Won't Cooperate
Got out Friday morning to try for a test flight or two, but the winds just wouldn't let up. Was able to get a few static ground shots between squalls, but not a chance for flying. Will keep an eye out for a good day and duck out as soon as one happens -- won't be today though, the snow hasn't let up all day. Too warm to stick, but lots of wet and sloppy.
PAT
Mar 14, 2010, 05:09 PM
supercubman's Avatar
Spot on, Mr. Pat!!
Trey
Mar 14, 2010, 05:10 PM
Dan Parson's Avatar
Now this is a heavy plane for you Pat! Most of yours are 15 - 20 oz at the most!
Discussion Stinson Reliant!!! Nekko Brazil 9 Jan 29, 2010 11:40 AM
Wanted WANTED! Top flite Stinson Reliant kit Splix Aircraft - Fuel - Airplanes (FS/W) 2 Jan 07, 2010 09:07 PM
Build Log Stinson Reliant 18" Span 1/28 Scale Rubber Conversion ( ready for another trial) GJ60 Scale Kit/Scratch Built 127 Oct 30, 2009 05:42 PM
Sold Top Flite Stinson Reliant SR-9 NIB cooper998 Aircraft - Fuel - Airplanes (FS/W) 0 Sep 08, 2009 07:17 AM
Question Top Flight Stinson Reliant SR-9 Kit rceagle1a Giant Scale Airplanes 8 Nov 23, 2007 09:41 AM
