Sep 27, 2012, 04:25 AM
Found 16v 3300uf......no change.
No worries, steve
Sep 27, 2012, 08:38 AM
Flying like an Angel.
BlueAngel2000's Avatar
Originally Posted by RENATOA
Ok, due to your complain (and others) I did the movie below for a sample how should behave RSSI when using this firmware.
In the second part of the movie, after I place radio in range check mode, and walked in other room, you should hear how beeps changes and see voltage swing.
If your receiver don't behave like this, on a voltmeter, without any filter, then is a case for replacement I think...
http://www.youtube.com/watch?v=IHjJ1QHV32Y
nice it did work with your receiver, maybe the firmware is different.
Didn't work (with and without RC filter) with my two D8R-II (12-2011) and one D8R-II Plus (05-2012) receivers.
Sep 27, 2012, 09:46 AM
Youtube Johnbrum26
He is running the XP fw on his D8R II
I ordered a new D8R-XP from aloft so as soon as it gets here ill try it out. I hope it works like his does cause that's what ive needed this whole time. I've built buffers, ordered boards, made an RC filter and nothing has worked, like that at all.
So we shall see.
Sep 27, 2012, 10:14 AM
So we shall see.
Yes, i know about the XP firmware, thats what is running on my 3 receivers too.
but maybe he has a newer xp-firmware or the firmware from the actual D8R-XP is different to the one posted here.
Sep 27, 2012, 11:43 AM
Rotozuk's Avatar
The XP firmware posted here should be removed, it was a sample beta release, and I understand has been updated. I don't think that beta copy was ever supposed to be released to the public.
-Wayne
Sep 27, 2012, 12:03 PM
-Wayne
ah okay.
maybe we can get the new (actual) XP firmware, since the PPM and RSSI feature is just great, like on the D4FR-II.
So i don't need to sell my old D8R receivers and buy new ones, when a firmware update can solve this problem.
Sep 27, 2012, 02:45 PM
D4fr ii
Is it possible to attach the vario sensor directly into the D4FR II?
Sep 27, 2012, 03:13 PM
Chuck 'Em and Chase 'Em
Fly2High's Avatar
I do not think so. It needs the hub
Sep 27, 2012, 03:16 PM
Rotozuk's Avatar
Not just yet... hint hint..
Sep 27, 2012, 06:02 PM
ancora imparo
jj604's Avatar
Wayne, can you get them to shield and decouple it a bit better while they are redesigning it?
There is no reason why it should fluctuate so much. PLMS proved that with a bit of attention to signal quality it was stable.
John
Sep 27, 2012, 06:06 PM
James not bond
jy0933's Avatar
does anyone know if i can hook amp sensor directly on d4r-II?
Sep 27, 2012, 06:38 PM
Rotozuk's Avatar
John
I made that suggestion to them long ago.
-Wayne
Sep 27, 2012, 07:52 PM
devIAtion..one TX to bind them
Hexperience's Avatar
I wish we could get rssi out without cppm mode.... I want it for a fpv plane with no cppm controller board
Sep 27, 2012, 08:45 PM
Balsa addiction since age 3
ScottSails's Avatar
If you need altitude? What about
http://wingedshadow.com/howhigh.html
I use it with my 8 channel without hub...
ER9x and Open9x support it
Scott
Sep 28, 2012, 01:11 AM
Yes, you must adapt somewhat the big servo type plug from FAS-100 to the tiny white plug of D4.
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 02:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 07:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 01:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 07:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 01:25 AM
