Powerlab on Car Battery
Hey Guys,
Plan on using this on my car battery for first time tomorrow, whats the most amps I should try with that setup? Wasn't planning on needing more than 10-15 amps, but its for a 6S 5000 mah lipo battery. Can my car battery handle that? Thanks, BK |
Yes, but not for long. . . . http://www.windsun.com/Batteries/Battery_FAQ.htm . I killed two truck batteries last year. They don't die until the coldest day of the winter. . . . YMMV . |
BK
Both of the above post gave you sound advise. To charge a 6S 5000 will required approx. 10 AH from your auto battery which is designed to supply perhaps 2Ah at most between charges. Only way I would use a regular auto starting battery to charge such a relatively large LiPoly would be with the engine running and then I would start the engine before connecting the charger and leave it running during the charge. Charles |
But at least they died in a crowded parking lot, behind the security gate at work, and temps were 15F with blowing snow . . . So I had THAT going for me!! . . . . 2 X F-250 diesel truck batteries (installed) - $476.00 . 1 X El-Cheapo 1500 Watt Generator from Tractor Supply $199.00 + tax . . Who said that education was cheap?!?!? . |
Hopefully an automotive professional can back me up here, but I believe you can also damage the alternator on your car if you draw too many amps from it. One thing I AM sure of is that the PL8 is capable of drawing alot of juice if it wants it . . . . You're using a 12 volt system to charge a 21 volt (5S x 4.2V) battery, so to charge at 5 amps (1C), the PL8 must step up that voltage from 12V to 21V. Since energy doesn't come from nowhere, the PL8 must draw much more than 5 amps on the 12 volt input side to create the 21 volts at 5 amps on the output side to charge your 5S-5000 battery. Now if you're charging at the Auto 3.0C rate (and Parallel charging!!), you can see that the PL8 can start demanding an exponential amount of amperage (in the 1.21 GigaWatt range . . do you drive a DeLorian?) from your poor little alternator that was only designed to top off your auto battery after each start and keep your radio working. . That is why you will see guys charging the smaller (<12V) LiPo's from their car batteries all day long with no consequences. Their chargers are charging a 2200 Mah LiPo at 2.2 amps, but drawing less than that from their car. However, when you go to a charger that needs to step up the voltage, it must also step up the amperage. . . What do the car guys say: "Cheap, Fast, Reliable - Pick Two"? . Man, I am just the bearer of good news today, ain't I? . If you don't want to lug a generator around, another good solution is to get one or two Marine Deep Cycle batteries, then go to a local RV dealer and have them set you up with a charging system that uses your car's alternator to slowly charge the deep cycles but won't allow them to discharge your automotive battery or draw too much off of your alternator except while charging. You can run the deep cycles down to 50% without damage, where your car battery needs to remain at 98% depth of charge. . . |
My setup which has been posted and linked to numerious times is in fact two each 125 Ah flooded cells deep cycles mounted to a rack I build that is attached to the towing receptacal and yes they are connected thru a relay to the charging system and can be charged at 30 amps while engine is running. https://www.rcgroups.com/forums/show...4#post15515324 https://www.rcgroups.com/forums/show...&postcount=847 Charles |
One thing I AM sure of is you can limit the maximum current that the PL8 will draw from the supply source. You can also set low voltage limit as well so that you don't kill your car battery by draining too low.
Problem is that limiting the max. amp that PL8 can draw IMO makes the likely hood of doing permanate damage to a starting Pb battery worse not better. The slower the Pb is discharged to X voltage the deeper it is discharged percentage wise of total capacity.
Run your car battery down with the starter (high amps. ) and the lights will still work , run it down with the lights and the starter will not even turn over. The site linked to in post 3107 happens to be one I have linked to many times over the years. There is a very good chart there showing percentage of discharge versus no load voltage . Kind of a fuel % table for a Pb battery. That chart shows that a Pb at 12.42 V no load is discharged approx. 20% . I bet many are driving vechiles with batteries that are this low after setting ovenight. A short drive to the field applies a surface charge and any charging from it will drop the remaining charge to a really damaging level. Set the PL8 to stop pulling juice at even 11.5 volts and the battery is still being over discharged and any charging at all will trigger the low voltage input limit. Simple answer was given in post above. Yes, but not for long. . . . http://www.windsun.com/Batteries/Battery_FAQ.htm Snipfrom the linked to battery facts site.: Quote:
Yes Standard USB to Mini same as used with numerious other chargers, digital camers,external HDs ,you name it. There are like 6 laying around on / connected to my computers..
I'm not getting an internal resistance measurement any longer (parallel charge)...I did in the past...I've tried it only once with lipo generic high power...I'll try it with others later.
Did a single pack with generic Lipo faster charge and the resistance measurement worked no problem. Anyone else? |
My SW can now start/stop, choose preset, and monitor the battery. Those who wish to see the progress can see it here: http://code.google.com/p/pl8c/ Moving right along.... The tech docs don't cover a lot of things - like reading and setting presets, charger options etc... Can we get a description of those? |
Thread Tools | |
Similar Threads | |||||
Discussion | Sneak Peek! 2, 1:8 scale scratchbuilts | ooby | Scale Boats | 34 | May 22, 2015 10:41 PM |
Discussion | Proposed schemes for 2010 season RAF BAe Hawk display-sneak peek! | Matt Halton | Electric Ducted Fan Jet Talk | 3 | Dec 20, 2009 04:11 AM |
Discussion | Sneak Peek at the New Creation Museum | Miami Mike | Life, The Universe, and Politics | 38 | May 30, 2007 05:01 PM |
Hey Mr. Lin, how about a sneak peek at the Hellcat? | splatman | Vendor Talk | 1 | Jul 05, 2003 04:43 AM |
