Jul 11, 2019, 11:00 AM
Abdullah Radwan's Avatar
Another approach is to use to GWS 10x3.8 prop (I asked a store and they have it). That should give ~600g (1.2 thrust to weight ratio). I think that should work with standard SE.
The problem with 10x3.8 prop is it has really a high amperage draw. That isn't good with a 1000mAh battery. The expected full-throttle time is ~4 minutes (It's 10 minutes with 8x3.8 prop).
I prefer 8x3.8 prop on 10x3.8 prop to have almost double flying time. But if 8x3.8 won't work well, I can get the 10x3.8 prop.
IMO ( In My Opinion ) →
balsa or carbon's Avatar
Originally Posted by Abdullah Radwan
The foam board size in Egypt is 100cm x 70cm, or 39.5" x 27.5". It's the same as Elmer's brand foam board (just longer). The major difference between it and DT foam board is it is much heavier and its paper is hard to remove, as detailed in FliteTest article.
My previous calculations were made by scaling the plane up to my foam board size, that why it was too heavy. I've redone my calculations using 20" x 30" standard size and this is the result:
The weight is ~500g. Wing loading is ~13 g/dm2 (4.3 oz/ft2). Thrust to weight ratio is 0.72.
If I scaled the plane 75%, the weight is ~370g. The wing loading is 17 g/dm2 (5.6 oz/ft2). Thrust to weight ratio is 1.
What is better for my situation?
If you are now building a Super Easy , why don't we move this discussion to the SE thread :
https://www.rcgroups.com/forums/show...E-instructions
Jul 11, 2019, 11:05 AM
Do you no longer have a 9 inch prop ?
If possible , get a 3S battery .
Jul 11, 2019, 11:08 AM
Posted in Super Easy. Please post this replay there.
Discussion 3D Batix Extra 330 Free plans Great plane Ben-Rod 3D Flying 982 Mar 26, 2019 11:28 AM
Discussion Telemaster 400 - Great trainer from free plans! cam777cam Beginner Training Area (Aircraft-Electric) 13 May 16, 2016 12:29 AM
For Sale Christmas gift,Trainer Hobbico Electristar RTF + Free Gift, Great Value !!! the-cat007 Aircraft - Electric - Airplanes (FS/W) 0 Dec 11, 2009 12:24 AM
For Sale Christmas gift,Trainer Hobbico Electristar RTF + Free Gift, Great Value !!! the-cat007 Aircraft - Electric - Airplanes (FS/W) 10 Dec 08, 2009 05:13 PM
Discussion Free Plans for 60" ish plane mt_100 Electric Plane Talk 11 Sep 14, 2009 08:28 AM
