Jan 07, 2010, 01:53 PM
The Conrad 450 ARF Quadrocopter
After seeing Importonís video on a different thread which he took using the Conrad 450 quadrocopter I decided to investigate further..
The quad is avialable from here http://www.conrad-international.com/,choose your country or the 'all other countries' for international english.
*note the german site has all the spares listed
Brief Specifications:
Motors:
* Operating voltage: 6 to 10 cells NiMH, 2 to 3 cell LiPo
* 22 turns
* 924 KV
* 104 mOhm internal resistance
* Maximum Efficiency 75%
* Maximum current 7 to 14 A
* Short-term maximum power (15 s) 19 A
* Motor Shaft ō 3 mm
* Motor Shaft Length 14.5 mm.
* Power consumption per engine approximately 3-9A
* Maximum power per engine. 14A
* Thrust per engine max. 700g with epp10x45 props
Escs:
2 pairs, 12c 15amp? ( need to confirm)
FCB
Atmega 128
3 x peizo gyros
1 x 3 axis accelerometer
board has expansion slots etc
The image in the attachments to this post (below) showing the connections on the FCB is from Gunter's Flying Robot Blog http://www.pccon.de/blog/?page_id=164
Frame
plastic 'space frame' centre foldable alloy arms, plastic motor mounts and body mounts.
RX
comes with a 35mhz ppm reciever
Optional Configuration Software
(the software manual is at the bottom of this post)
3 flight modes
beginner, expert or user configured via optional computer interface.
English manual here - https://www.rcgroups.com/forums/show...4&d=1270284725
Whilst waiting for my quad to arrive I did a bit of reading, most info is in german ( including the user manual) It appears the V1 was buggy and this put people off however the v2 seems a much better craft.
Some setup help
Teaching the Quad what level is
User Bearded Flyer pointed out an error in the manual, this is the correct way
1) Turn on the transmitter
2) Set GAS to zero and all the other levers and trims to neutral
3) Set the Quadrotor on a horizontal, flat surface!
4) Connect the battery to the Quadrotor
5) The red LED on the Quadrocopter must be OFF and the green ON
6) Move throttle stick to full scale and full scale on the RIGHT
7) The green LED flashes to confirm the Quadrocopter and the neutral position is
stored
Using a 2.4ghz radio with the Conrad
to use a 2.4ghz radio you need a ppm converter. I have tested 3. Quadroppm, RecEnc and Diydrones Paparazzi Encoder.
The RecEnc did not work, The Quadroppm works after a resistor is bypassed but is occasionally glitchy and requires some smd assembly.
The Diydrones encoder comes ready assembled with the latest firmware and best of all it works great.
To get power to the RX side from the ppm side bridge J1 with solder.
I bought it from here:
http://store.diydrones.com/ProductDe...ctCode=BR-PPME
I have attached an image below describing how to wire up the Paparazzi encoder. Some knowledge of soldering is assumed
Jan 07, 2010, 02:31 PM
Running the Conrad with a 2.4ghz Spektrum radio
EDIT see post 1 or https://www.rcgroups.com/forums/show...&postcount=179 for latest on a better ppm converter
From my attempted reading of the german forums its seemed like the conrad fcb would not arm when using a ppm converter such as RecEnc. I also tried with a recenc and a quadroppm ppm converter but with no luck.... at first.
I decided to run the RecEnc, the quadroppm and the original rx through my pc oscilloscope to see if I could see any differences. (*note the pc scope may not be entirely accurate but it does give comparitive data which is what i needed) I noticed the conrad rx output about 1.4v but the RecEnc output was only 1.07v. the quadroppm output was 1.2v on my scope. I thought the conrad may need to see a higher Ve in order to arm. The RecEnc is basicly just a chip and nothing else so increasing the output on that would maybe involve making a circuit or something... I noticed the quadroppm has a resistor on the signal output side so I decided to bypass it. Guess what it worked! Next step is further testing and flying in X mode via radio mixing
Conrad Quadrocopter 1st test using 2.4ghz Spektrum Radio (0 min 56 sec)
the ppm converter I used for this test is the quadroppm from mikrokopter.com
you have to solder the smd resistors and led on which is a bit tricky! For a 6 channel rx like mine you join channel 6,7 and 8 together on the board. For this to work with the Conrad quadrocopter you have to bypass R11 ( so the signal comes from the right pad of R11 when looking at the board as in this picture)
Jan 07, 2010, 02:46 PM
It flew...nearly!
Impressive performance stability-wise. Wonder what payload it can carry...
matthew
Jan 07, 2010, 02:53 PM
Hi I expect payload is comparable to that of a quad mikrokopter with similar size motors and props.
cheers
Josh
matthew
Jan 07, 2010, 04:09 PM
that is impressive. I wonder if you could make a little 2.4 ghz tutorial.
as far as payload. I'm hauling a 3000 lipo, a 250g camera, and a 50g camera mount. can stay in the air for about 10min and is actually much more stable will all the weight.
matthew
Jan 07, 2010, 04:18 PM
the recommended AUW is 1kg but that is because of the risk of the lightweight props which are like epp1045's breaking. I will test with apc1047's soon.
I have added details on the 2.4ghz in my post about it. I want to test a different ppm converter too as I dont really like the quadroppm board.
Jan 07, 2010, 05:33 PM
wow. that's seems too advanced for me. theres alot of big word in there that I don't understand.
http://www.youtube.com/watch?v=DEnApoUyQPw
This is the ppm converter I used for this test, its the quadroppm from mikrokopter.com
Jan 07, 2010, 05:41 PM
lol,, you basicly have to buy a little converter board and solder some wires (and tiny little components in the case of the quadroppm) then connect it together and hope it works
Jan 07, 2010, 05:50 PM
Brushless
cdi3d's Avatar
Joshbb - What are we looking at for a turn key system that runs on a 2.4 ghz dx7 price wise? Comparable to a mikrocopter?
Jan 07, 2010, 06:07 PM
Hi, the conrad comes complete less a radio transmitter and its whatever its costs to buy in your country, (it was £249 with free shipping in the UK)the same goes for buying a dx7 radio although If you have a 35mhz radio you dont need a radio just the crystals. the 2.4ghz ppm converter boards are about £20 from mikrokopter. hope that helps...
cheers
Josh
Jan 07, 2010, 11:38 PM
Agjake01's Avatar
Josh - Pretty cool quad! Does it have an accelerometer built in? What exactly is the PPM converter, is it specific to the Rx or Tx you are using? What do you think of this compared to George's QP board? Nice flying by the way! - Jake
Jan 07, 2010, 11:49 PM
It does have an accelerometer. ppm is the language that the tx rx comunicate in. I think georges board will be far superior once it is mature. the conrad will almost certainly never have features like height hold, camera tilt roll compensation, and gps features.
Jan 07, 2010, 11:55 PM
Agjake01's Avatar
Thanks.. and I assume the DX6i does not recognize PPM thus requiring a converter? Think I'm going to take the plunge and build my first quad based on George's board. Either of you have any experience with the MikroKopter frame? Was thinking of using it...
Jan 08, 2010, 03:19 AM
I am not so sure about that statement, The conrad has an expansion socket and unused serial buses and there is talk on the german forums of a gps height/ location hold addon this year. The 12c escs (as used on the mikrokopter) on the conrad also mean that they have a MUCH faster update rate than standard escs whichs equates to potentially better stability. the Conrad has very similar features to the Mikrokopter v1.3
....... I think georges board will be far superior once it is mature. the conrad will almost certainly never have features like height hold, camera tilt roll compensation, and gps features.
Jan 08, 2010, 04:19 AM
this is why I'm glad we have our own thread now. can you give anymore info about this expansion? please keep us posted on this. it seems like you are far better at getting info on this than i am.
Discussion Conrad Quadrocopter 450 ARF cvlex Multirotor Drone Talk 8 Jan 12, 2010 11:49 AM
Question Telemaster as Multi use medium lift AP platform? RLW Aerial Photography 7 Dec 06, 2009 01:27 PM
Discussion Development of an ARM7 avionics based Quadrocopter AP platform (Q4Arm7) Arthur P. Aerial Photography 20 Mar 26, 2008 04:13 AM
Discussion Development of an ARM7 avionics based Quadrocopter AP platform (Q4Arm7) Arthur P. UAV - Unmanned Aerial Vehicles 0 Jun 30, 2007 04:10 PM
Mizar EPP ARF Trainer as AP platform? Medve Aerial Photography 1 Jul 13, 2005 05:49 PM
