Jan 06, 2010, 04:35 PM
400' + is where fun starts.
Martin Y's Avatar
There sample video looks just marvlous http://www.goprocamera.com/hdheropreview/
I must get one.
Jan 07, 2010, 03:49 AM
I have allready get that !LIVE! composit video out
It's a little tricky but you can clearly see that this feature is right there.
All you have to do is:
-Turn on the camera
-Make a short record
-Plug in the tv-out cable, of course it will start the playback of the last record
-Wait till the end of that playback
-Plug in the USB cable
-Enjoy the view
-After this, you can disconnect the USB
That's it. First time my computer didn't recognise the camera, but later it does, so I have to disable it's driver. Anyway, my card reader was mutch faster...
I think that there's a mechanical detection in the plug itself, and a state machine monitors it. If it detect the "plugging" it starts the playback mode, and if it detect the USB connection, it switches to USB mode. Since the USB didn't want to work (for some reason ) the state machine resets and didn't check if the tv-out cable is attached allready.
If my theory is correct, then all we need is a little mod of that plug, but someone have to open the camera housing to confirm this.
I ordered the camera for a friend, who didn't want this feature, so I didn't want to strip down hes brand new toy.
Jan 08, 2010, 09:47 AM
FirstPersonFlyer
MrGlobeFlight's Avatar
Hi,
I have the Go Pro HD here and I am fascinated.
A mount is in contruction, in GFK with Ball bearing for Stronger Servos for smooth movement and a strong construction. Ready for all applications like planes, cars or helicopters.
stay tuned
Sebastian
www.globe-flight.com
Jan 08, 2010, 10:00 AM
Smoke on , go !
zaguruinzasky's Avatar
That's a good news Seb.
Jan 08, 2010, 05:25 PM
Challenging Convention
I've got about 4 designs of pan & tilt's that i manufacture for AP, one of which would be perfect for the GoPro... However, i specialise in the high end market, which although it means the mounts are super lightweight, super strong and the smoothest on the market, the one i've got would also be one of the most expensive, since it's 100% Carbon Fibre, CNC Machined aluminuim and Titanium.
Bearings all round, pan mounted via thurst bearings & 4mm bolt (not servo horn) and tilt has option of digitally controlled dual tilt servo system using modular design, but for the GoPro, one servo would be ample.
Although i'm not running my AP business anymore, i think i've got enough machined plates in stock to build a couple. I'd need to check the dimensions of the GoPro though to see what size custom mount plate i'd have to build. Pan/Tilt will allow for both upright & hang mounting configs.
Cheers
Andy
Jan 08, 2010, 05:30 PM
Hmm, was just thinking, i've got my new Antenna tracker pan/tilt ready for manufacture now too so maybe worth getting some GoPro mount plates cut for that while i'm getting the monster antenna pan/tilt done (which is gonna be good enough to swing 2 x 4Kg Yagi's around, but again, not cheap as the primary tilt arm mounting plates are machined from 4mm thick carbon Fibre (x 4) and again, i've designed it to be completely modular, meaning you have the option of loads of configs to allow Yagi mount, patch mount, diversity setups etc etc...
Let us know if you want more info.
Cheers
Andy
Jan 10, 2010, 12:39 PM
FirstPersonFlyer
Hello guys,
So our GoPro HD Mount is ready to go.
Material: GFK
weight: 27g (without hub)
fits perfect for the GoPro HD and brings the lense in the middle of the pan/tilt unit.
It will be mounted to an aluminium hub for the servo OR a long hub with a ball bearing in a mounting-plate to make it stronger and "hard landing protected"
To protect the GoPro HD we include a sticker set for between the goPro and the GFK.
It is compatible with our canopy groundplate for easystar, twinstar or Easyglider, you just should use a bigger Servo than.
But you can mount it anywhere like we did on our Rubicon Traxxas Summit crawler for the first snowvideo the next days.
available in the next week at www.globe-flight.com
(I will post it here when we have it online)
More Pictures and details in our partner blog
www.video-flieger.de
words are nice but I know you like to see some pictures, right ?
there we go
Jan 10, 2010, 01:19 PM
Smoke on , go !
Seb you're my hero ahahah
I want to buy #2, #1 is your...
Jan 10, 2010, 01:22 PM
Intense Tobac's Avatar
I Want one too!!
Jan 10, 2010, 01:42 PM
sunrider's Avatar
Tobac..... You have to wait....
First at all i got one.... i tell You, it fits perfect for the Gopro.
Itīs lightwight, strong enough and usable for my Planes and Cars.
Good Job Mr. Globeflight
Jan 10, 2010, 01:51 PM
hmmm, very different design to the one i've got here.. just gonna do a quick video of it so you can see, but by looking at MrGlobeFlight's efforts, his will be at least half the price..
although i could take away all the Titanium, that would save a few bucks...
just setting up the camera now..
Cheers
Andy
Jan 10, 2010, 02:11 PM
Originally Posted by MrGlobeFlight
Hello guys,
So what does it weigh with the hub? since i don't imagine it's very usable without it?
Cheers
Andy
Jan 10, 2010, 04:22 PM
V
V
That looks like a nice GoPro HD mount !!!
I'm curious where do you place the FPV cam. on that mount because we all know that GoPro HD doesn't have video out yet ???
Rob
Jan 10, 2010, 09:42 PM
Fly Big, Low and Slow....
Alpina540's Avatar
This will be used as the FPV cam once gopro updates the firware
Jan 11, 2010, 01:20 AM
sunrider's Avatar
letīs wait for the firmware udate
cheers Sunny
Discussion Home made twin motor plane for HD video with Pan and Tilt. pthompson24 Aerial Photography 83 Jan 12, 2010 07:07 PM
Discussion HD pan/tilt camera mod? Martin V FPV Talk 3 Oct 18, 2009 02:53 PM
Discussion Easy Glider Pro Canopy Mod for Pan & Tilt Njoro FPV Talk 11 Sep 13, 2009 06:30 PM
Link Selling - Askman .50 Size AP LG with Pan/Tilt HD Gimbles Aobid Aerial Photography 0 Feb 03, 2009 09:55 AM
Discussion HD Camcorder suitable for Pan & Tilt solars FPV Talk 8 Sep 27, 2008 10:48 AM
