Thread Tools |
This thread is privately moderated by chuck George, who may elect to delete unwanted replies. |
Trader Rating: 15
Sold
Free Shipping SAPAC Jas-39 and T-45 RR Foam
NEW SAPAC JAS-39 Silver Can Motor output: 1100W@72Ah $115.00 FREE Shipping Conus Specifications:
NEW SAPAC T-45 FOAM RECEIVER READY $170.00 FREE SHIPPING CONUS Specifications: Length: 39.3" Wingspan: 37.4" Wing Area: 1.937sq.ft Wing Loading: 1.27oz/sq ft Flying Weight: 21.8oz Servo: 8g servo ESC: 30 Amp brushless Motor: 2830 Brushless Outrunner 4000KV Battery: 11.1V 3S 2200MAH 15c Li-polymer battery Charger: 12.6V Li Charger Fan: 6 paddles 64MM Color Box Dimension: 39" X 13" X 9" Transmitter: 4 channels (Aileron, Elevator, Throttle, Taxi) (Not included.) Receiver: Mini 6 channels (Not Included.) NEW Fly It Yourself SU-47 Twin EDF Receiver Ready $160.00 FREE SHIPPING CONUS Specification: ARF KIT Receiver Ready Length: 1024mm /40.31" Wingspan: 750mm / 29.52" Flying Weight: 700g / 24 oz. Power System: twin EDF55 with brushless motor Battery: 2200mAh3s 15c Servo: 9g Servo 3pics Electronic Speed Controller: twin 18A ESC Feature: Forward swept wing configuration and canard layout Auto inlet door Steerble nose wheel and ailevator mix control High efficient EDF system Haoye SU-27 Twin 68mm Ducted Fans or Pusher $80.00 FREE SHIPPING CONS The SU-27 is designed as a high performance fighter with a fly-by-wire control system. Its high maneuverability makes the Su-27 one of the most imposing fighters ever built. The development of the Su-27 fighter plane was completed in the early 1980s, and the plane subsequently set more than 40 world records of altitude and take-off-speed. You will need Two (2) ESC Speed controls and Two (2) EDF Motors or Pusher Setup This is where you can Taylor the Power System for the Type of Flying you want from Stock Setup to All Out Performances....It's all up to YOU. The Included Twin Fans are Haoye 68mm Units ...Nice Ones...5 blade ducted fan unit. Specifications: Length: 900mm/35.4 In Wing Span: 670mm/26.4 In Wing Area: 12dm² Height: 320mm/12.6 In Weight: 230g/ 8.11 (plane only) AUW: 730g/ 25.7 ARF version: Includes 2 @ Fan units without Motors! 5 blade ducted fan unit For use with Haoye SU-27 68 dia x 58mm (H) Landing Gear English Manual This model can be flown with pusher power or ducted fan power system comes with both Prop or TWIN 68mm Fans...Really Good Fans...Not the Usual, Haoye Fans Ø68 4 Spoke/ 5 Blade Brush Ducted Fan HY003-00105-5B ***Nice Ones***. The manual is based on instruction for pusher power system or ducted fan system. Comes with glue, pushrods and control horns. This model can be flown with pusher power or ducted fan power system. Package contents: Assembly instructions in English, painted foam fuselage, foam wings, tail plane and fin, small items, linkage hardware pack Including nylon control horns, Haoye EDF 2@ Fan 68mm and Landing Gear included. Includes SU-27 Undercarriage non retractable 1 nose gear 2 main gear and 2 Haoye Ducted Fan 68mm W/O Motor - Ø68 4 Spoke/ 5 Blade Brush Ducted Fan HY003-00105-5B ***Nice Ones***. Includes SU-27 Undercarriage non retractable (steerable) Front Nose Wheel: L38×W51×H120mm, D36×8mm back main gear: L40×W25×H100mm, D45/50×18.5mm Items not included: - 4-8 Channel and above Remote Control - Servos x3 - 4-8 Receiver - Push Power System - Brushless Motor 28-47-09C - 11.1V Li-Po Battery -Brushless Motor x2 -11.1V Li-Po Battery x2 Haoye BAE Hawk 90mm EDF $85.00 FREE SHIPPING CONS Product Information: Red Arrows BAE Hawk painted version of the Hawk is the perfect EDF Jet for EDF first timers. Made out of foam, the plane comes mostly assembled. The red and white painted fuselage allows modeler a faster build and is scale like of the Red Arrows BAE Hawk. Suitable for EDF and push prop power. This model can be flown with push power or pull power or ducted fan power system, can be upgraded. The manual that comes along consists of instruction of push power system or ducted fan system only. Pack contents: Assembly instructions in English, white foam fuselage, foam wings, tail plane and fin, small items, linkage hardware pack including nylon control horns, Haoye EDF Fan 90mm and Landing Gear included. Includes BAE Hawk Undercarriage non retractable 1 nose gear 2 main gear and 1 Haoye Ducted Fan 90mm W/O Motor - Ø89 6 Spoke/ 5 Brush Duct. RC functions: - Ailerons - Elevator - Rudder / Nose steering - Throttle Specifications: Wing Span.....................: 960mm (37.8'') Wing area......................: 16.9sq.dm Weight (empty)..............: 350 grams Length...........................: 1030mm (40.6'') Items required (not included): - 4-8 channel remote control - Servos x 3pcs - Speed Control 60A for Brushless Motor - 4-8 Channel Receiver - Push Power System: - Outrunner Brushless Motor - 14.8V 4000mAh 15C Li-Po Battery - 11x4.7" Propeller Electric Ducted Fan Power System: - Brushless Motor PM Me... Chuck |
Trader Rating: 12
hi what is included with the NEW SAPAC JAS-39 t.you
Trader Rating: 13
Jas -39
FYI - The silver "can" motor works great on this plane...I love my 39.
Trader Rating: 15
New sapac jas-39 |
Thread Tools | |
Similar Threads | |||||
Sold | Free Shipping SAPAC Jas-39 and T-45 RR Foam | chuck George | Aircraft - Electric - Jets (FS/W) | 5 | Jan 04, 2010 02:15 PM |
Sold | NIB Sapac JAS-39 Gripen W/ Motor and Fan **Price lowered** | AndyTheLegend | Aircraft - Electric - Jets (FS/W) | 4 | Oct 14, 2009 08:25 PM |
Found | 64MM FAN for Sapac Foam T-45 or GWS Fox Hawk | Lithonion | Aircraft - Electric - Jets (FS/W) | 2 | Sep 01, 2009 11:29 AM |
Cool | Sapac Jas 39 " if ain't foam go home" test flight with crash | java8297 | Foamy EDFs | 0 | Aug 07, 2009 08:34 PM |
Sold | SAPAC JAS-39 NIB Free Shipping | ScaleBrad | Aircraft - Electric - Jets (FS/W) | 3 | Aug 25, 2008 07:23 AM |
