Jul 03, 2018, 12:23 PM
good
Originally Posted by nevenelestate
Finally got the StratoSurfer in the air, more video to come.
https://youtu.be/vt5-Y__08EI
Since the successful double drop on Friday I went in and modified my electronics so I will be able to drop each wing load individually. I fly with the Taranis x9D+ and since my switches are all pretty much used for other functions I setup the left and right rotating levers on sides of the radio to drop the appropriate load. I am flying this plane with the Matek F405 Wing flight controller and have them setup for servo channels 7 and 8.
it is like wild hawk from reelly, good job
Yves
Jul 29, 2019, 10:46 AM
casual park flyer
52Sabre's Avatar
Adam bomb mods: https://www.rcgroups.com/forums/show...&postcount=872
Will be doing the same to my Quanum's. Then drop from Dynam 1270mm Corsair.
Jul 29, 2019, 11:08 AM
casual park flyer
52Sabre's Avatar
Originally Posted by Bruce Ardern
Sorry to appear thick, but Tx manual does not explain how to assign a particular switch on the Tx to a channel on the Rx. Can you direct me to instructions, preferably not in Chinglish, that explain the procedure?
cheers, Bruce
9XR Pro here and v.204 of Ersky9x. Should be similar to your 9x. I am using the spring loaded trainer switch (TRN) to release mine. I also have plugged into ch. 7. On the mixer page (5/13) scroll down to CH7. Press MENU. Then EDIT. Change source to FULL, Weight 45, Switch TRN. Leave the reat alone. Bombs away!
Isn't it nice getting a prompt answer to your four year old question? Ha! Have a good day.
Discussion Bomb Drop whiro Flight Accessories 2 Jan 24, 2010 09:34 AM
Discussion Easy Plug n' Play Power System Slow Stick 400 AirVenture Beginner Training Area (Aircraft-Electric) 6 Nov 29, 2009 11:44 PM
Discussion Need Plug n' Play Power System for Slow Stick 400 AirVenture Power Systems 2 Nov 24, 2009 09:07 PM
