Dec 31, 2009, 01:04 PM
out of the western sky...
Skyking213's Avatar
New Product
Quanum RTR Bomb System 1/6 scale Plug-n-Drop from HobbyKing
Does anyone have one of these yet?
Mine has been shipped!
Should be fun!
ScottB
Jan 06, 2010, 12:14 PM
JohnVHRC
JohnVH's Avatar
dont have them, but am going to order them
Latest blog entry: F22!
Jan 08, 2010, 10:21 AM
Skyking213's Avatar
I got mine!
Have not had a chance to try it out....
Working the AMA Expo this weekend, so I'll have to wait until next week to drop test these! Looks like they work and I'm impressed with the quality!
ScottB
I also got some spare bombs, I'm sure they will get lost!
Jan 08, 2010, 09:36 PM
Martin - AKA mr.sneezy
PLMS's Avatar
Lost ? Don't worry about that !
My son tested the Quanum bomb system today. Fitted to a Parkzone Stryker.
The Stryker is a modified EDF version, a regular prop driven one would be better with a low pitch prop I think. With the bomb fitted a bit of skill is needed to just let the model sag while gaining air speed a little before pulling on the elevator.
The bomb release.
In short, it releases very reliably. Easy to setup on any free channel. Middle 'stick' is still locked (by a spring), going full throw releases the bomb.
In actuallity, I opened up the bomb release mechanism and put two washers under the servo mounting lugs, because the servo arm was sometimes binding on the release catch. Easy fix. Noting else required.
I put white painters tape on the base of the release, then PU glued the base of the release into the Strykers belly. I used a loop of nichrome wire to cut a hole big enough to sink it into.
OK the negatives.
The bomb is made of exploding plastic. No joke intended. One drop is the life of one bomb.
My sons landed on soil, here's the result in the photos. Another flyer at our club tried one as well, his shattered after landing in a ploughed paddock ! The weather is warm here, so the plastic is not too cold.
The solution is modify a Nerf Bomb using the supplied spare plate.
No excuse though, the original bomb is not fit for the purpose !
Martin
Jan 08, 2010, 09:40 PM
JohnVHRC
JohnVH's Avatar
Good call on the nerf! Bummer on the bombs though, guess Ill have to glass some or use the origional as a mold.
Jan 08, 2010, 10:04 PM
PLMS's Avatar
Yeah, the cool thing with the Nerf type bombs is that they whistle just like bombs on old war movies !
Really, I don't understand the plastic used, it looks like it would just flex and pop open, but noooo..... Crunch !
Jan 09, 2010, 02:31 AM
rcozstyle's Avatar
Hi Martin
I got one too but only looked at mine so far lol.
Jan 09, 2010, 03:59 AM
jeff boyd 2's Avatar
Martin
The Nerf Bomb suits the Stryker better, anwyay ! !
JB
Jan 10, 2010, 01:38 AM
M.Huerta's Avatar
maybe try boiling the bombs??? I know some heli guys boil their skids to make them more flexible and it really does make a difference.
Jan 12, 2010, 01:13 PM
I got mine today and it seems that there are the same as the Hobby Lobby once, but the drop module includes the servo :-) Going to compare tonight.
Good call on the Nerf Bomb :-)
Jan 14, 2010, 11:14 AM
MAAC SAVED RC!!
vettster's Avatar
PLMS... Did you use the Rubber Nose attachment?
Jan 14, 2010, 11:30 AM
JohnVHRC
JohnVH's Avatar
I ordered two sets of the mechanisms, Ill see about modifying them to not explode.
Jan 14, 2010, 02:12 PM
rcozstyle's Avatar
Hi
I cut the 4 pins shorter so that the bomb pops apart easier and been throw it up and letting it hit the ground and it seems to be ok.
Jan 14, 2010, 02:23 PM
JohnVHRC
JohnVH's Avatar
are the bombs heavy?
Jan 15, 2010, 02:10 PM
rcozstyle's Avatar
They are a 500lb bomb lol , mine weighs 62grams.
Discussion Bomb Drop whiro Flight Accessories 2 Jan 24, 2010 09:34 AM
Discussion Easy Plug n' Play Power System Slow Stick 400 AirVenture Beginner Training Area (Aircraft-Electric) 6 Nov 29, 2009 11:44 PM
Discussion Need Plug n' Play Power System for Slow Stick 400 AirVenture Power Systems 2 Nov 24, 2009 09:07 PM
