Thread Tools |
This thread is privately moderated by feathermerchant, who may elect to delete unwanted replies. |
Yes you can take 12V from one supply and still use the 24V output. Take the 12V from the grounded power supply. It will save you grief. On my website you will see power supplies wired for 12/24V. |
John61CT -
For the 4010 Duo; Maximum Charge Power 2000W at >34V Input Current 65A So to 'max it out' you'll need about 34V and 65A INPUT Input will be about 2,200W to get 2,000W out. So you will need three 12V power supplies in series or a ~36-48V power supply. I have tried to make 36V and 48V power supplies from 12V power supplies but they don't last very long. My guess is that some component(s) do not like being floated that far from ground. FYI even generators recommend grounding. Read the instructions. I would never recommend running without a ground. I can build a 69A or 75/100A 12/24V supply that will work reliably but not 36V. What are you charging that you need 2,000W? |
Often mobile off-grid, marine, RV, expedition trucks, often will be able to assemble a big enough 36-48V bank to act as source, but not always, and then charger not available for supporting input. 3kW+ gensets are often available, but may be 110V not 240. I want to be able to make full use of 4010Duo when upstream power source is available. Ability to feed concurrently from two separate 110V 15A circuits would really be ideal. I'd really rather not carry multiple different sets of PSUs just to handle both 110/240 inputs. EPS120, 51.4V is going that high, too stressful for 4010Duo longevity? Ground may simply not be available, even a 2m rod into dry desert earth not great. Middle of the Great Lakes dunno, not a sparkie, would rather a design assuming none. |
IBM xSeries x336 PSU, 585W, 48A @12.2V
Chicony OR Acbel 24R2639 API3FS25 24R2640 So two pairs, all series'd ? * 4 = 48.8V 2340W _______ Edit, getting excited, world voltage? Switches between 100-127v input 12.2V/53.3A 200-240V input 12.2/106.5A Also, HP DPS-1200FB 1.5″ x 7.75″ x 3 1/2″ 2lb! 900W at 120V input, 1200W at 220V 12V, adjustable 11.7 - 12.7V pairs, 1800W / 2400 @ 24V 2 pairs well over 3kW available on either mains input |
The DPS 1200FB is what I sell. Not reliable with more than 2X in series.
Most reliable I sell are 12V 69A. Two in series works great and almost no returns ever. Artesyn 7001138 IBM 24R2730 120-240V input. You might want to look at a charger such as the one in the Tesla Model 3. It is 120-300V AC input and about 11kW. The battery pack is about 400V DC. It is digitally controlled and liquid cooled. You may be able to get one from a salvaged car. |
bit overkill for a 2kW need 8-)
Does the max of 2 in series hold for all PSUs do you think? What about using a pair of the HP DPS-1200FB separately powered each from its own circuit or genset? Would using a battery to buffer the input help? How about a DCDC boost converter to get volts up and keep amps below 60? I guess I'd settle for 1800 for just 110AC sources, knowing I'd be able to max out if needed just find a 240AC outlet. |
My opinion is 2 in series is the limit. I don't know why. I've never been able to tell what fails.
You could use a boost converter to get the volts up from 24 to say 40 or so. It would have to be capable of 70A though. If I were you, I'd try the 24V 69A and see how far it takes you. |
This is my current path, to get max use out of the iCharger 4010-Duo
https://www.rcgroups.com/forums/show...Duo&p=40907507 |
New power supply needed...
Good day Feather Merchant,
Well my 24V47A Plug-n-Play Supply that I got from you a few years back gave up the ghost this weekend. I think some water got into one of the units. Anyway, time for a new one. Wanting to power my iCharger 4010 duo and I'm debating between your 24V 69A Supply and your 24V 75/100A Supply. I mostly run it off my Honda 2000 generator. Any thoughts/suggestions/recommendations? Thanks! |
I would say to look up the model of power supply you have and see if anyone has posted about them here.
You might also check with the charger company to see if 36V is really OK. |
Do you have any knowledge if they can be trimmed back? |
Possibly. Which ones are they? I have sold several models.
This may help. I did not read the whole thing.
https://www.rcgroups.com/forums/show...ns&perpage=100 |
Thread Tools | |
Similar Threads | |||||
For Sale | Used PC Power supplies converted for 12V DC chargers | ddierking | Aircraft - Electric - Batteries & Chargers (FS/W) | 3 | Jan 13, 2010 09:14 AM |
Sold | ***POWERFUL*** 12V 30 Amps Power Supply SLIM & LIGHT | MJB9 | Aircraft - Electric - Batteries & Chargers (FS/W) | 3 | Dec 07, 2009 12:39 PM |
For Sale | 12V Power supplies 30A $40 and 42A $50 for your chargers | feathermerchant | Aircraft - Electric - Batteries & Chargers (FS/W) | 1 | Sep 03, 2009 08:07 PM |
Discussion | 2x 12v chargers in series with a 24v Power Supply? | cmacclel | Batteries and Chargers | 3 | Jan 21, 2008 02:39 PM |
Can I put two 12v bench power supplies in series = 24v? | rakm | Batteries and Chargers | 7 | Nov 25, 2003 12:15 AM |
