Dec 14, 2009, 03:52 PM
AJ750's Avatar
Build Log
M.V. Pics, Plans, Build Log
Here are the pics, plans, and build log for the M.V. that I built. It uses a wood boom for the tail (but CF would be better), which has turned out to be very strong and resilient to hard landings. The fuselage is built using the “monobloc” technique made popular by the Blu-Baby. The monobloc is made with a piece of 1 ” thick pink foam, and the sides and tail feathers are fanfold. The airfoil is wire cut out of a block of foam made in 2, 24” halves. WS: 48” Chord: 5”. Dihedral: 4” on both sides.
Motor/Battery Combo I used:
Great Planes Rimfire 28-26-1300kv motor
910mAh 3s battery
AUW as tested is just over 13oz., however, im sure it can be made lighter.
**Note: I am using a heavy 8 ch. Rx. If using lighter equipment, the wing may need to be moved back on the fuse to achieve proper balance.
Also, these are the first plans I’ve ever made, so please bare with me.
Dec 14, 2009, 04:16 PM
AJ750's Avatar
and the finished product
Dec 14, 2009, 06:28 PM
My plans are in my blog
Rusty-Gunn's Avatar
A decent looking flyer. I bet its fun to fly.
Dec 14, 2009, 06:37 PM
AJ750's Avatar
hey thx. its a lot of fun. sorta rough at first, but after making some improvments, she flys great!
Discussion Scratch built Depron Ki-61 Hien "Tony" plans and build log Low Pass Foamies (Scratchbuilt) 68 Mar 28, 2010 01:56 AM
Discussion Schuetze build log? TugFan Scale Boats 1 Dec 02, 2009 01:18 PM
Discussion Gee-Bee/Corsair/V-tail mixed bird(finally with *ok* untiled plans and build pics pg6) GreenAce92 Foamies (Scratchbuilt) 108 Dec 08, 2008 07:36 PM
