Dec 12, 2009, 07:27 PM
Fisticuffs!'s Avatar
MINI profile pusher jets: Mirage 2000, Mirage F1, F-18C ~ 14 in WS
Over thanksgiving break I wanted something to fly over my street so drew up some plans for pusher jet fighters, including a Mirage 2000, Mirage F1 and F-18C. They all have a wingspan of around 14 inches and are made from 3mm depron or similar foam. The propeller slot is 3.2 inches wide to accommodate a GWS 3x2 or 3x3 prop.
I plan to use a mid-mounted Feigao 1208436L or similar inrunner motor with these propellers or to use a tail mounted C10 or similar outrunner with a GWS 4x2.5.
And coming soon: Eurofighter 2000, X-29, F-18E, others
STATS
Mirage 2000
Wingspan: 14 in
Length: 21.5 in
Height: 6.0 in
Prop Slot: 3.2 in
PDF size: 24 x 24 in
The missiles/reinforcement are all optional, however reinforcing the prop slot is recommended
Mirage F1
Wingspan: 14 in
Length: 24.7 in
Height: 6.4 in
Prop Slot: 3.2 in
PDF size: 28 x 20 in
Can also use a tail mounted motor easily
F-18C
Wingspan: 14 in
Length: 21.7 in
Height: 6.4 in
Prop Slot: 3.8 in
PDF size: 24 x 18 in
Wing area is very small (exact outline copied). This should be built as light as possible
Here are the PDFs of the three planes. I should be able to post the dxf files soon, which can be opened by AutoCAD and sketchup
Dec 12, 2009, 07:29 PM
Here are some pictures of the Mirage 2000, with reinforcement to the prop slot, and without missles.
Built from 3mm Cellfoam 88 and has a 3 mm x 1 mm CF rod as a spar. The motor is a Feigao 1208436L with a 3x2 prop.
Currently has 2 2.5 g Blue Arrow servos installed and will use a 250 - 350 mAh lipo
Jan 12, 2010, 10:43 PM
Unfortunately after building the Mirage 2000, I had a little testing accident (prop/finger strike).
I moved onto the F-18C. I redesigned the original plans to mount the motor at the rear and to have a closed bottom fuselage. The updated plans are in the original post. The wingspan and other dimensions have not changed.
After cutting out the foam, I couldn't help but start building. Construction went pretty smoothly.
I wanted to experiment with full flying stabilitors on this model, so incorporated them. I used 0.042 push rods as the torque rods with the plastic sleeve as the bearing.
I am using 3.6g servos from hobbyking - http://hobbyking.com/hobbycity/store...idProduct=3715
Jan 12, 2010, 10:51 PM
Next I moved on to The fuselage parts and vertical stabilitors.
All went together with ease. I made a small motor mount and attached the C-10 motor, with the thrust line slightly above the wing surface.
Next is missile rails. These will either be from balsa or leftover plastic push rods sleeves.
I also want to experiment with a KFM2 airfoil on the F-18 after I maiden it.
Jan 13, 2010, 07:51 AM
boerie roll
vleisie's Avatar
F-18 looks good. Looking forward to seeing the F1.
Build Log Mini/Micro 15" F22 Pusher Profile Bowerz Scratchbuilt Indoor and Micro Models 11 Dec 12, 2009 04:14 PM
Discussion Biltz RC F/A 18c Help w/ wires (new to jets( WestMeadowBob Foamy EDFs 7 Dec 12, 2009 03:06 PM
Build Log Mirage 2000, Mirage F1, F-18C Profile Pusher Jets -14 in WS Fisticuffs! Scratchbuilt Indoor and Micro Models 3 Dec 12, 2009 01:24 PM
Build Log Mirage F1 18" WS Fisticuffs! Pusher Prop Jet Models 3 Sep 18, 2009 02:59 PM
Discussion Mini F-14 Tomcat Pusher Jets Back In Stock! LBMiller5 Pusher Prop Jet Models 0 Sep 18, 2006 09:07 PM
