Dec 12, 2009, 11:24 AM
"RC ADDICT" in Toronto!
wollins's Avatar
Help!
What glue to use?
I want to glue two pieces of rubber like material onto the back of my radio (where my hands grip) to improve my grip on the radio. The material that the rubber "mat" is being glued to (back of TX) is plastic .. what glue would be best for this job?
This "matting" is perforated so it is quite conceivable that if the glue is not applied in a very thin application it may well seep through the mat. A situation which I would obviously like to avoid.
Ok, let take this one step further ... what would the best glue in the event that I wanted to take this matting off at a later date? Something with the properties of say ... hot glue (sticks well, rubbery and would come of clean at a later date) would be great. The only trouble with hot glue is that it can't be applied as an even, consistant film which is what this application calls for.
Advice?
Thanks!
Colin.
Dec 12, 2009, 01:58 PM
I would use 3M Vinyl/Rubber Spray Adhesive. Here is a link to the information:
http://www.solutions.3m.com/wps/port...E02LECIE204A00
Dec 12, 2009, 02:05 PM
Maybe this link will work better:
http://solutions.3m.com/wps/portal/3...E02LECIE204A00
Dec 12, 2009, 02:11 PM
3M has a neat tool on their spray adhesives page that you imput the material for the 2 surfaces you wish to bond and they select thier recomended product for that application:
http://solutions.3m.com/wps/portal/3...duct-Selector/
Dec 12, 2009, 07:57 PM
papaoften's Avatar
Try contact cement. It will adhere to both surfaces and is easy to remove and you can clean up overages on plastic by rubbing off the excess with your finger. I use it to glue down canopies on warbirds and windshields on other models. I think it would work the same as the spray on adhesives, but with a little more control.
Dec 13, 2009, 11:11 AM
Card Carrying Old Fart
Rickochet's Avatar
Take a look at the various types of adhesives under the "Goop" brands.
Discussion What glue should I use to assemble a BH EDF F-35 Jet stekeye Vendor Talk 3 Nov 13, 2009 06:02 AM
Discussion What glue to use for gluing firewall? flyboy320 Electric Sailplanes 8 Nov 11, 2009 10:21 AM
Discussion What Glue do you use? rimshotcopter Foamies (Scratchbuilt) 19 Nov 06, 2009 09:32 AM
Discussion What glue to use to join plywood and a plastic hinge? BMA04ltng The Builders Workshop 7 Sep 30, 2009 11:47 AM
Discussion what glue to use for edf construction j3tman Electric Ducted Fan Jet Talk 4 Sep 11, 2009 02:22 PM
