View Poll Results: If you are reading this thread are you an IOM owner
Yes 26 49.06%
No 27 50.94%
Voters: 53. You may not vote on this poll
Sep 27, 2013, 02:03 PM
Boomboom124
Originally Posted by Dick L.
Suggestion: put a small piece of tape, or paint a white stripe on the top of the drum so one can visually see speed for multiple turns. Video of drum turning isn't good in detail and can't tell if drum is even turning.
for what it's worth
There is another video of our winch working in a Lintel MMX on our website
http://www.titan-winches.com/video/4570036094
Sep 27, 2013, 05:32 PM
8387mike's Avatar
Originally Posted by Radsail
I am just starting to build A,B and C rigs for my new IOM. What are typical weights for the Jib Counterbalances?
The most common one I sell is the 23g but some prefer the 18 to keep the rig weight done
Hope this helps
Sep 27, 2013, 06:08 PM
BAJAN SAIL 51's Avatar
Originally Posted by boomboom124
there is another video of our winch working in a lintel mmx on our website
what size drum did you use on the lintel
Sep 27, 2013, 06:19 PM
Hope this helps
Thanks Mike
Sep 28, 2013, 02:32 AM
noclue's Avatar
Hi David
Just read your interview in the Seattle IOM Mag. Brilliant!
When you design a new boat, do you draw the design or do you take some foam and start to shape, as a starting point.
Many thanks Peter
Sep 28, 2013, 12:47 PM
David Cook Victoria, BC Canada
Originally Posted by noclue
Hi David
Many thanks Peter
Peter who?
Thanks for the kind word. My last 4 designs have been done using an old CAD program called Hullform. It's free if anyone wants to try at designing their own boat. search Hullform Bluepeter. I hire someone to do the CNC milling. In my early design/build days, I used paper and pencil, then progressed to pencil and drafting (frosted) mylar to lay one plan over another to compare the differences.
The joy and self-satisfaction I get some sailing my own designs far exceeds sailing someone else's. I encourage others to do the same.
Sep 29, 2013, 04:46 AM
Boomboom124
This was a 26mm drum on the MMX.
We also do a 32mm drum for IOM's for those
who like a little more sheet speed although we are
pleased with the 26mm drum.
It works very well for fast gybe.
Orders are now being taken for the Titan.
Gordon
Sep 29, 2013, 11:37 AM
Dick L.'s Avatar
Gordon - for multihull use, what is the largest diameter drum one can purchase (special order) ??? And obviously, what torque numbers would be applicable to the larger drums?
Sep 30, 2013, 11:48 AM
Boomboom124
Hi Dick,
If your are looking for a custom drum then we could supply one.
What size drum do you have in mind?
Obviously torque would decrease and speed will increase with a large diameter drum.
We have tested the torque in the Titan that is in the spec. as we find this gives a true measurement rather than extrapolating and not being accurate.
Thanks.
Gordon
Sep 30, 2013, 08:23 PM
Dick L.'s Avatar
Gordon, sent you a PM
Dick
Oct 01, 2013, 09:03 AM
8387mike's Avatar
Advertising on Boats
Would a large logo on the sails get passed
Oct 01, 2013, 02:33 PM
Probably won't get past. If the logo was prominent enough to get noticed, it is likely too big and will get tossed. Normal sailmaker size logos in the corners are expected...
Oct 01, 2013, 02:50 PM
ToniGe23's Avatar
interesting question the answer is 'No' the makers logo has to be inside a 2 inch radius
There is a ruling about how many logo's permitted on sails as I recently found out on my Power Sails which failed because of 2 makers logos on the main sail and jib. Powersails have a logo in the corner of there sails but also a very small emblem on the luff these were not allowed so I had to remove them to comply if any of you guys are using Gerry's sails I would remove the luff logo he has been informed of the error.
Oct 01, 2013, 04:02 PM
ISAF Code 20 Rule:
Table 2 – Manufacturer’s and Sailmaker’s Marks
Allowed marks - see regulation 20.7.1
Hull Spars and Equipment Sails and Kites
Boat Type or Size
On each side of the
hull, and may include
the name or mark of
the designer or builder
On each side of spars
and on each side of
other equipment
On each side of sails
and kites
Boat less than
2.5m hull length
(1)
One mark to fit within a
rectangle measuring
15% of hull length x
150mm
Boat 2.5m or
greater hull length
(1)
rectangle measuring
500mm x 150mm
One mark not
exceeding 300mm
length
Oct 01, 2013, 10:58 PM
Dick L.'s Avatar
Not sure if he was talking about a sailmaker's logo ---- or ---- some other logo or decoration ????? I don't think ISAF 20 covers anything "other" than a sailmaker's mark. Maybe I'm too liberal in that opinion - I could be wrong?
Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion tend2it Multirotor Drone Talk 2529 Apr 26, 2008 07:45 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 10 Jan 12, 2008 11:33 PM
Discussion Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 32 Jan 03, 2008 03:02 PM
Discussion General Discussion Inflexo Australia 172 Nov 27, 2006 10:26 PM
General Discussion / Training Area zax Site Chat 0 Oct 03, 2001 01:48 PM
