View Poll Results: If you are reading this thread are you an IOM owner
Yes 26 49.06%
No 27 50.94%
Voters: 53. You may not vote on this poll
Feb 12, 2012, 11:06 AM
Originally Posted by TedFlack View Post
The rule is that the lower band must be 60mm to 100mm from the deck mark. So the height of the rig is pretty much controlled by that rule.
C.7.4 MAST
(a) DIMENSIONS
minimum maximum
Lower point to deck limit mark as defined in D.1.5 ................................................. 60 mm .... 100 mm
And variation between rigs +/- 5 mm.
The deck mark can be on any bit of "deck" adjacent to the mast whether the mast is mounted in a pit or on top of a platform! Possibly no one has got inventive and the rule was written in the days of flat decks.
Jerry
Feb 12, 2012, 12:17 PM
expat,
We went through a debate here in the USA a few years ago and decided that the + or - 5mm was not between rigs but for how much each rig can me moved. The reason we decided that was the idea is because the rule clearly states "each rig" not "between rigs"
From the class rules:
Within these limits, the variation in height of
lower point for each rig .................................................. .. ...... ± 5 mm
The rule for the "Deck Limit Mark" is that it is supposed to be on the hull center-line near the mast, of course "Near" is kind of vague as to location.
This is probably open for debate.
Ted
Feb 12, 2012, 03:04 PM
NORTHLAND NEW ZEALAND
D design's Avatar
Thanks guys.
Sorry if this is a dumb question but what if you built a really high deck. is there a measurement from waterline to deck?
Feb 12, 2012, 03:18 PM
John - In my private capacity
hiljoball's Avatar
Originally Posted by D design View Post
Thanks guys.
No.
One thing that you will quickly learn in sailing an IOM is that the A rig mast is a noodle. The rules limit the things you can do to control the mast, eg no lower shrouds, so a crucial tool to control the mast is the mast ram. To make the ram work needs a raised foredeck and a low mast heel. This allows you to generate the force necessary to control the shape of the lower third of the mast, and it has a marked effect on the control of the main leach and twist too.
Another factor is that the A rig carries a lot of sail area and keeping that area as low as possible helps carry the A rig longer. A high deck raises the rig and would lead to an early switch to the B rig compared to other boats.
John
Feb 12, 2012, 07:45 PM
D design's Avatar
Thank im finding forums very helpful
Feb 13, 2012, 12:30 AM
Although seldom seen, a set of "check stays" are permitted that also do what the
mast ram does (but probably not as well).
Chris B.
Feb 13, 2012, 02:07 AM
8387mike's Avatar
Originally Posted by old dodger View Post
although seldom seen, a set of "check stays" are permitted that also do what the
Chris b.
bg sc4:d
Feb 13, 2012, 05:59 AM
D design's Avatar
anybody tried reverse bows?
Feb 13, 2012, 06:41 AM
How about a "Double Ender" by Dave Creed.
Feb 13, 2012, 04:05 PM
Great name!!
END GAME
Feb 13, 2012, 04:28 PM
Closed Account
Vivacity (M-Class) to Double Ender (IOM)
Guys,
In the mid to late 80's a (Double Ender) Marblehead design called 'Vivacity' was produced by Mr David Creed. 'Vivacity' was sailed to success in numerous Vane (Freesailing) Marblehead Championships by Peter Maskell, Martin Roberts and Walter Jones. Later an updated version of this Marblehead was produced but unfortunately, it wasnt successful as the original 'Vivacity' yacht.
The Double Ender (IOM) is of the same theme as 'Vivacity', that was produced in the 80's. I just wished I had some pictures of the original boat...
JT
Feb 13, 2012, 07:21 PM
D design's Avatar
if you didn't know what I meant, has anybody tried a back-to-front bow on an IOM?
Feb 14, 2012, 02:00 AM
Anybody got any suggestions as far as clip on spreaders to fit my 12.3MM groovy rig from Ludwig rc yachts? Also isn't it a problem, when mast ram pressure is applied, doesn't which I noticed pushes the mast aft in the box that mast goes down into. This box on both my IOM's is longer fore and aft than the mast, which allows the mast to move fore and aft when I put on or take off turns on the mast ram. I put a plastic spacer in the box behind the mast on my Pikanto, but have yet to sail it to see if that allows what I think the mast ram should do which is play a role in how much bend the mast has.
Feb 14, 2012, 04:50 AM
ToniGe23's Avatar
If you cannot find what your looking for in your location PJSails in the UK should sort you out check out part Nr PW14d http://www.pjsails.co.uk/Rigfittings.PDF
Feb 14, 2012, 05:13 AM
D design's Avatar
D1 fineline
Here's a picture of the first RC yacht I designed and built from scratch "fineline".
she had a half of a iom A rig for the main and jib,fibreglass man boom,mast, and carbon fibre jib boom and servo mounts. Made of cedar strip plank glass both sides and the deck is foam core and glass. Had an unusual long fin keel that seems to work...Who knows. Went like a rocket! I'm missing this boat out on the water..
Nathan
Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion tend2it Multirotor Drone Talk 2529 Apr 26, 2008 07:45 PM
Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 10 Jan 13, 2008 12:33 AM
Kong Power Packs Info And General Discussion nitroshark Batteries and Chargers 32 Jan 03, 2008 04:02 PM
Discussion General Discussion Inflexo Australia 172 Nov 27, 2006 11:26 PM
General Discussion / Training Area zax Site Chat 0 Oct 03, 2001 01:48 PM
