Mar 11, 2010, 12:56 AM
boerie roll
vleisie's Avatar
V2 Design Complete
I had some very successful water flights yesterday with the new floats. I got some video, but youtube blocked the soundtrack so I'll redo it tonight.
I'm happy with the design right now and don't plan any changes soon. The final v2 plans are now in the first post. I'll update the control throws and the build pics tonight.
Marcel
Mar 11, 2010, 11:02 AM
Crazy Foamie Builder
JettaManDan's Avatar
rain for the next 5 days where i am...figures
can't wait to see the video Marcel!
Mar 11, 2010, 01:53 PM
boerie roll
vleisie's Avatar
V2
Video is up.
Seadart v2 (1 min 35 sec)
Mar 11, 2010, 02:09 PM
Retired CAD guy
birdofplay's Avatar
That Looks terrific !
Nice and stable !
Marcel, Do I have the latest drawings ?
Bob
Mar 11, 2010, 10:25 PM
Airborne whenever I can.
PAT-T's Avatar
Great design
Like to build it, only have a E-flite 400 920kV / castle 35 ESC and 910mA 3S lipo or 1650mA 3S lipo setup available. Will the 100% fly on that?
PAT
Mar 11, 2010, 10:57 PM
If it flies, I will crash it
mxspode's Avatar
You will probably want a slightly higher KV motor, the design of the plane limits you to a fairly small prop. The motor you have is designed to spin a large prop slowly. We are looking for a small prop fast here. I would think something in the 2200 KV range to start with. You could run more then that but that would seem a good starting point. Others will probably chime in with some other options as well.
Rob...
Mar 11, 2010, 11:16 PM
PAT-T's Avatar
E-flite Park 400 Outrunner Brushless, 920Kv
E-flite now brings you a small lightweight outrunner motors that are perfect replacements for Speed 280 and Speed 370 applications for small 3D and scale park flyers 10oz to 20oz. Their great performance and small size make them perfect for small 3D and other park flyer models. The external rotor design eliminates the need for a gearbox, saving you valuable weight to get the maximum performance out of the model.
Requires:
10 to20A Brushless ESC
9x7 to 11x4.7 Prop
7.4V or 11.1V 860-1320mAh Li-Po
Features:
Slotted 12-pole outrunner design
Prop Adapter and gold-plated connectors included
Excellent motor for small 3D and scale park flyers 10 oz to 20 oz (280 g to 560 g)
Motor Mount included
Replacement for Speed 370 and Speed 400 applications
Quiet operation/Low noise compared to gearbox systems
Specifications:
Type: brushless
Size: Replacement for 370/400
Bearings or Bushings: Bearings
Recommended Prop Range: 9x7 to11x4.7
RPM/Volt (Kv): 920 (RPM per volt)
Resistance (Ri): 0.1 Ohms
Idle Current (Io): 0.7 @ 10V (no load current)
Shaft Diameter: 3.17 mm (1/8")
Weight: 2 oz (56g)
Diameter: 1.1 in (28mm)
Continuous Current: 10A
Maximum Burst Current: 13A
Cells: 6-10 NiCd/NiMh or 2- to3-cell LiPo
Speed Control: 10 - 20 Amp Brushless
Mar 11, 2010, 11:19 PM
PAT-T's Avatar
Think this should deliver enough power to push the SEADART, problen might be the prop diameter.
PAT
Mar 11, 2010, 11:37 PM
PAT-T's Avatar
Thanks Rob
Was afraid for that too, also have an ALIGN 400LF, but the biggest recommended prop would be 4.5 x 4 or 5 x 3 delivering between 450 and 515 Thrush, but as you know that motor was designed for a 400 heli.
PAT
Mar 11, 2010, 11:55 PM
boerie roll
vleisie's Avatar
Nice and stable !
Bob
Hi Bob, plans are in the first post. Here is a drawing with the changes from the proto plans marked.
Marcel
Mar 12, 2010, 12:01 AM
boerie roll
vleisie's Avatar
Originally Posted by P. Thieleman
Thanks Rob
PAT
Hi Pat, like Rob said, this plane was specifically designed for a 6x4 prop. The slot is the limiting factor. Also, even if you could run your big prop it looks like your motor can deliver about 140W while I think the 2212-06 gives about 250W.
Marcel
Mar 12, 2010, 12:31 AM
PAT-T's Avatar
Thanks Marcel
Did not have the exact specs of your motor. M Align 400LF 2800kV delivers 290W with a 5 x 3 prop on 3S Lipo, might work for the 66% SEADART. Seems I need another motor for the 100% version.
PAT
Mar 12, 2010, 12:52 AM
boerie roll
vleisie's Avatar
Thanks Marcel
PAT
That might even work for the 100%?
Marcel
Mar 12, 2010, 01:09 AM
PAT-T's Avatar
Great
I will try that combo, the Align has an internal cooling fan and my Tenergy 1600 is 20C rated. As soon I get home, I will start with the V2 Seadart. My building time at home is limited, but I can prepare the parts at home and do the rest in my truck, exept for the paint job of course. Will take a while before I get this ready. Just think that 1600 mA going to be on the low side for the job.
PAT
Mar 12, 2010, 01:12 AM
PAT-T's Avatar
Where do i find a good program to find the best motor setup, without cooking my brains?
PAT
Build Log Prop in slot Saab Draken - Plans (6mmFlyRC) vleisie Pusher Prop Jet Models 776 Jan 05, 2021 03:30 AM
Build Log Prop in slot Kfir / Mirage 6mm depron Blueangels4 Pusher Prop Jet Models 4 Oct 23, 2013 04:28 PM
Video Prop in slot noise test leadfeather Electric Plane Talk 5 Nov 07, 2008 07:41 PM
Discussion Slot design for "prop in slot" leadfeather Foamies (Scratchbuilt) 32 Oct 17, 2008 09:45 PM
Discussion Plan for "Prop in a slot" profile Epp jet model ? dekan Pusher Prop Jet Models 0 Jul 11, 2007 01:36 PM
