I have a problem where my frsky module doesn't beep when its on range mode, I've launched more than a few times with it still on and had a few crashes
This is the latest, new bixler and all. RTL didn't engage or failed. Not happy at all, luckily damage is surprisingly minimal.
Matty 12 is it a v8fr2 reciever in the plane ?
Might be an issue with them after all. Mind glitched on me last week for the second time and i nearly lost it too. I have gone back to the older v8fr and not had a problem since. Mine also did not follow the failsafe i had programed in it either
Hello Im from NZ and am trying to cut down on shipping costs. I wanted to know if there are any venders that ship to NZ. I am trying to get a hold of some lawmate 1.2 GHz 500mW vtx. Thanks
Hobbyking... would cost a couple o' bucks to post.
The only time I had a FRsky module not go to failsafe correctly was when my TX battery went flat, when I switched off my tx failsafe kicked in.
I also check the antenna connection with all my Frsky RX before I fly them, had a couple that were not seated properly. Matty what RTL were you using? |
All part of the service
Sorry, don't know anything about V2 HP. Do you mean "How did you check the connections to your aerials?" |
It had worked ok for a few weeks out to 1.5k . but as in the vid ,it glitched less than 200m away, so i binned it (dont want to risk it) Cheers Patrick |
I'm using the APM 2.5 Gimmer.
Turns out it was the old inverted elevator trick. I had my elevator on the autopilot inverted so it was trying to pull up but only getting lower! Stupid me, I thought I checked the control surfaces in FBW mode but I didn't check carefully enough. Oh well, 2 mistakes in the one flight that I should have picked up in my preflight checks, I'm lucky to only have some dings in the wings! Might be time to get out the laminated checklists again. Patrick, Have you heard of problems with other V8 V2 units? I'll keep an eye on this one but I think it actually failsafed correctly but that I hadn't set up my autopilot correctly. |
no i havent heard of others yet , might just have been a bad one i had then.
Will keep an eye out . Glad you found the issue , fix it and post up a great flight vid for us !!! |
[QUOTE=Aus;25361578]
If your lucky if ust your plane you lose, Louis was close to losing his car one time!!! Last time I got a plane from the drink I had to swim out 100m and got my arse stung by dozens of jellyfish! |
Thread Tools | |
Similar Threads | |||||
Discussion | FPV Car and Other Fun FPV Projects Thread: | Crash9 | FPV Talk | 15566 | Feb 26, 2024 06:01 PM |
Discussion | FPV Beginners Reference Mega Thread... | rc_ron | FPV Talk | 169 | Sep 05, 2016 10:47 AM |
Build Log | Easy Fly Glider ST330 (Easy Glider Clone) FPV Build Thread | SoMoney | FPV Talk | 493 | Nov 12, 2012 04:08 PM |
Cool | Aussie XBOX Live thread | ozzi supercub | Australia | 7 | Oct 22, 2009 01:42 PM |
Discussion | FPV WARS (Thread for FPV "B" Movies) | ch1 | FPV Talk | 8 | Sep 16, 2009 05:37 PM |
