Question
Can a car battery charger be used as a 12V power supply?
I have an old Sears 6/12V 6A car battery charger, it outputs @14.4 V DC. When I hook up my Multiplex LN-5014 charger to it, the charger gives an input voltage error, though the manual lists the input voltage at 11-15V. Curiously, my GWS-MC2002 nimh/nicad charger works fine with it, what's up with that? I've even tried powering the Multiplex from the GWS and I get the same error, (the Multiplex works fine from a 12V battery or car accessory adapter). Obviously I'm missing something here. I'm getting tired having to charge everything in the car, and I want to avoid having to buy an all new AC/DC charger or a power supply, (probably the cheapest option), or a heavy deep cycle battery. I have a separate balancer/watt meter for balancing. Any ideas or sage "don't ever do that!!" wisdom? Thanks,
Sonny |
Car battery chargers have a tendency to put out really dirty DC and there have been reports of damaged chargers as a result of this. Some are better than others in this regard and you may use a 12V battery as a buffer to smooth out the power form. Even an old battery removed from a car usually suffices.
In the long run you'll likely be far better served in obtaining a power supply or deep cycle battery. Mark |
I just picked up one of the harbor freight car battery chargers. Is it OK to run this charger on a car battery and charger at the same time? I have an old car battery that I can use.
i use a computer power supply pushes 12 volts at 7 amps dose great with my b-6 that only needs 5 amps i can run my charger and a buddys of mine at the same time its awsome if you would like to see it i could post some pics of it tommorrow. it has an off and on switch. it works great. and very easy to make.
Sonny *Here's a link to the Radio Shack Power Supply I have: http://www.radioshack.com/product/in...ductId=2284639 . Should I try & use this? |
Reason: Link to Radio Shack Power Supply
i use a real old one with a ten amp charge. i just use a car battery as a balist.
i used my micro orbit,HC gt a8's and my new 208b with it. the 208b gets a little paulsy at higher charge rates. the gt a8 has ferrit thing on the input wires the 208 does not, |
Sonny |
Even though you measured (or it specifies) 14.4v output, the voltage will typically drop as soon as you apply any load. How far it drops depends on the charger and on how many amps the load is. Your Multiplex may be more sensitive than your GWS so far as input voltage is concerned, or it may simply be taking more amps so that the car charger voltage is dropping further.
I used to use a car charger connected to a smallish car battery as my 12v source for my plane charger. But when charging a large battery I would eventually get an "input voltage error" message as the car battery ran down and the car charger was unable to keep up with it. I also got an "input voltage error" message sometimes if I was taking too few amps and the car charger/battery voltage got too high. My solution was to buy a ProPeak stabilised 20A supply unit http://www.modelsport.co.uk/?CallFun...n&ItemID=23410 . Its voltage will not vary significantly whatever amps you ask it to deliver (within its limit). |
Sonny PS: BTW: How can a power supply rated at a regulated output of 12V DC, charge up a 3S Lipo pack to a full 12.6V? Seems like a PC supply would regulate 12V to maintain exactly 12V, so where is that extra .6V coming from? Again, am I missing something here? |
Reason: Another question BTW:
Sonny |
Hi Sonny!
A PC power supply is not made to power chargers, as well. ![]() You might want to read my little write-up concerning power supplies: https://www.rcgroups.com/forums/show....php?t=1082910 |
For instance my NiCd/NiMh charger works from 12v and that can charge up to 24 cells, which needs around 34v .............. |
![]() Quote:
![]() ![]() Quote:
Thread Tools | |
Similar Threads | |||||
For Sale | Triton Charger with Caddy and 12V Power Supply | Sled Driver | Aircraft - Sailplanes (FS/W) | 2 | Nov 09, 2009 09:50 PM |
Discussion | Car battery charger as power supply? | Evan Byrne | Batteries and Chargers | 4 | Jan 09, 2008 10:07 AM |
Car battery charger as 12V power source | Squeezer | Batteries and Chargers | 3 | Jul 24, 2004 05:57 AM | |
Battery car charger used as a power supply?? | Sylvain | Batteries and Chargers | 7 | Feb 19, 2003 10:17 AM | |
battery charger as 12v power supply | sandman | Power Systems | 6 | May 09, 2001 03:15 AM |
