Jun 03, 2010, 08:57 PM
Here is a pic of a removed arbor with chuck attached. The arbor is the tapered part and the chuck is screwed on the end. This assembly is what will come out of the drill press but you must apply downward pressure to the back of the chuck somehow to get it out.
Added: I just looked at your diagram you posted and you will have to find out whether your chuck just comes off a taper like you picture or whether it has the tapered arbor on the back of it like I show in the picture.
Originally Posted by thanhTran
Thanks Pug!
The chuck is not screwed in. When I installed it, I just push it in, and tap the nose of the chuck a little and it just stayed there. There was a pdf link I posted last night of that same machine. When I looked into the chuck with a mirror, it's just a flat end of the shaft.
I'm afraid I would break the bearings if I give it a good whack. No???
Thanh
Jun 03, 2010, 09:18 PM
Just went trough your parts manual and you appear to have a tapered back chuck not like the one in my pic. You still have to find a way to apply sharp downward pressure on the back of the chuck but the chuck is the only thing that will come off.
One thing you will need to know is the size of Jacobs taper it has. It should be marked on the chuck somewhere 1Jt,2JT,33JT so on. You can also order the wedges to seperate it if you know the size. My catalog list the wedges for about $8 a set.
Jun 03, 2010, 10:59 PM
Aircraft re-kitter
ergocentric's Avatar
Jacobs has a page on removal
http://www.jacobschuck.com/drill-chuck-install.asp
now back to the quadcopter
Jun 03, 2010, 11:43 PM
Multicopter Addict
braindead4554's Avatar
What kind and what size is everyone making there arms out of? Workin on prototype number two
Jun 04, 2010, 01:31 AM
Future-proof EVERYTHING
DarkHeli's Avatar
Circuit completed!!!!
Quick question: With the atmega disconnected from the circuit, If I check the + and - of the servo bus I get a small voltage ( cap c7 ) but when I connect the unprogrammed atmega, I get what looks like a short between the pos and neg servo bus terminals. Is this normal?
Jun 04, 2010, 05:11 AM
Servo bus?
You mean that if you number the servo lines as 1 - GND 2- VCC 3-signal, then you measure on the PCB without anything else connected a voltage between VCC and GND (pin 1 and 2)?
That sounds a bit weird, but if you put the meter into continuity-check / diode test, you should measure something between 400 and 1600 mV. Especially if you put in the atmega. Remember: polarity matters!
Your measurement could be explained by some voltage being still on the capacitor (you'd see the voltage slowly decaying), and the atmega using enough current that it drains the capacitor almost completely almost immediately.
Jun 04, 2010, 12:29 PM
DarkHeli's Avatar
Sorry, I meant Gnd and vcc, and that I have the meter in continuity check. The current decays with no atmega connected. Polarity does matter, one way it does not even charge the cap. Before I program the chip and fire the sucker up, are there any critical continuity checks that I can look before connecting power to make sure I don't smoke the chip?
Jun 04, 2010, 01:01 PM
km28104's Avatar
1.2" square Aluminum Tube.
onlinemetalstore.com
Jun 04, 2010, 01:32 PM
Carbon Fiber Tube (hollow) D6.0×Ф5.0×1m
Jun 04, 2010, 01:49 PM
That tree again!!!!
thanhTran's Avatar
Just check to make sure you don't power the chip with higher voltage than what says in the spec, and that don't power it in reverse. These chips are pretty resilient. We don't deal with high voltage here, and other chip stuff on board uses same voltage level, so no worry...
Jun 04, 2010, 07:16 PM
Aircraft re-kitter
Looking for a couple more CF golf clubs at stores like Goodwill, Salvation Army and Value Village, I bought two for $8, are they ever strong!
Jun 04, 2010, 07:19 PM
Its Flying!!
Done!!!
Video:
Zotfidjy: Quadcopter con controladora Kapteinkuk (Araxiñas) (6 min 18 sec)
Thanks!!!!
Jun 04, 2010, 07:48 PM
bob4432's Avatar
Originally Posted by zotfidjy
Done!!!
Video:
http://www.vimeo.com/12307035
Thanks!!!!
nice
are you the guy using kite "inter-locks" for the landing gear? could you post some pics of that? looks like a nice skid setup.
Jun 04, 2010, 08:49 PM
Friend is a 4 letter word...
JussiH's Avatar
Most recent quad was made with 10mm OD, 8mm ID alu tubing @ 82 grams per meter. Cheap and strong stuff from the local DIY store...
Have also used 10*10 square alu tube @ 90 grams a meter on tricopter.
Hexa will be made with 12 mm HK450 booms (alu) at about 51 grams per meter.
Am also working a MicroTri that will use 6 mm booms from Gaui 200 or 5 mm carbon tubing.
Many people uses Wood. Daddes impressive FPV videos is made with a tricopter with wooden arms, as far as I remember!
Ken, are you serious about the 1.2" square alu tube - it sounds quite heavy to me.....
Jun 04, 2010, 09:20 PM
Thanks for the information. I am building a quad. Would you recommend the same size tube (1.2") for this? It seems a little big, but I have not built one before.
Thanks!
Discussion Quadrotor brushless controller airbotix Multirotor Drone Talk 63 Aug 06, 2010 11:15 AM
Discussion ALPO -Aerobatic Low Parts count Original design. Brian Courtice Foamies (Scratchbuilt) 8 Sep 21, 2009 03:57 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 07:53 AM
Help! Need help with Low-cost QuadRotor Hero.sl Coaxial Helicopters 5 Jun 28, 2009 02:26 AM
Question Searching Simple Controller for Free Flight flymax Electric Power Systems 8 Jan 07, 2006 11:07 AM
