Sep 01, 2014, 03:21 PM
hello,
is there a solution ?
Pascal
Sep 01, 2014, 03:22 PM
Originally Posted by keithsuth
Hi Martin, yes im setup for PPM and the PPM outputs to the servos are working fine.
Would appreciate any assistance you can provide.
hello,
Pascal
Mar 09, 2015, 07:32 AM
I have a Frsky FASST TFR8-SB receiver and a Eagle Tree OSDpro which I would like to get RSSI from. Now, as the TFR8-SB's RSSI out is FASST digital and the OSD is analog, how and what do I need to connect these two?
Mar 27, 2015, 08:16 AM
Trying to figure out if the OSD Pro can be connected directly to a FrSky LR9. It has an analog RSSI port. There seems to be talk of a converter required on some receivers. Thanks for any help.
Mar 27, 2015, 08:56 AM
OSD pro requires an analog input.
Mar 27, 2015, 05:31 PM
So the FrSky LR9 should work just as it is? Thanks
Mar 28, 2015, 01:44 AM
I would guess so, have no idea. Wish the TFR8 also had analog out.....
Aug 27, 2016, 06:19 PM
Success fanatic
Rssi
Bill,
I have your latest receiver in my plane and is working fine.
I am using Eagle tree's Elogger V4 also.
I am trying to get the RSSI to work, but have a problem. I am using analog RSSI 8th pin on the reciever and I am connecting that to temp #1 on the E logger. When I do...it draws a lot of current on the battery in the plane...and no RSSI.
WHAT am I doing wrong ??????????????
Never Mind...I discovered that I only need a single wire from the reciever
Mini-HowTo Monitoring multiple battery voltages with OSD Pro billpa FPV Equipment 94 Jan 21, 2015 08:01 AM
Discussion Help with my ET OSD Pro & RangeVideo Tx harness Cralis FPV Talk 122 Sep 11, 2009 10:35 AM
Need help with Acro Pro motor mount drone Sport Planes 11 Jun 09, 2003 04:41 PM
