Build Log
Birdie's attempt at a Micro Yak 54
Howdy! I decided that I would attempt to scale down some plans from Foamy Factory's Yak 54 to try and make me some tiny indoor 3D planes for the upcoming indoor "season" .
I had the plans from Tim several years ago, and have been building the 32" Yak's and loving them..They are some of the best flyers there are! Tim Hart did an outstanding job to say the least, on top of that he is one of the coolest mofo's around! This is my first attempt. What I did was try and use acrobat to scale down the full size sheet plans until the slots for the tabs and stuff were 2mm wide, so that I could use 2mm depron to make the airframes from. I just kind of got lucky, and I have had to do very little sanding, even with my very poor knife skills..just another testament to Tim's hard work and perfection that it has made this way easy so far! I got a couple of the 10G outrunners from HC here, and am thinking that some little bluebird 303's would work for surfaces, and so far, this is what I have... |
Here it is, RTF..! :)
I do not have an accurate scale, but it is for sure well over 1 ounce..so EPIC FAIL on that one..
I used hyperion 2S 120's with t-bird 9, and 3 of the little 2.5's and managed 75 degrees plus on the throw!! ![]() Here is what it looked like flying tonite.. ImagesView all Images in thread |
Am working on VIDEO..!
hold again..maybe for vids of me crashing!
and yet maybe a 3rd place holder..
More to come as I get some help in the micro department from some locals that are REALLY good at this sort of thing..
Same thing here Noah..but now the little bitty HC outrunners and stuff are sooo frreeaking cheap..
I got my buddy that owns the LHS to order me some 2S and 3S Hyperion 240's for this little thing! IT IS GONNE BE AWESOME!!! I am working on lightening the servos and ESC..I called Bernie @ Castle and he said I couldn't solder direct to the board, but that I could make the wires as short as I needed to on the t-bird esc, and I am going to solder the servos direct to the receiver to get rid of the weight of the plugs, but the little CF rods I got are too flexible..I need to find some tiny rod that is actually pretty stiff..this stuff is worse than spaghetti noodles..hell, those noodles would probably be better than what I got so far.. ![]() |
I don't know about the t-birds, but I've resoldered all of the wires on a phoenix 10 to lighten it. If I remember, by going to very light wires, I was able to get it down to 2 grams with the servo plug still on it.
I've seen some guys use magnet wire on them to get them even lighter. I'm sure soldering on the board probably voids the warranty, but then again, if they saw the way I fly, no one would ever honor a warranty after I flew their product... ![]() The new Hobby City stuff is super cheap, and really makes it easy, and don't forget about the Parkzone stuff as well. Jerry Combs cut an Edge for me that uses the gear from a PZ sukhoi, and it can be upgraded to brushless. I think I might try that out this season. |
OOOOhhhh..!! I just found out he has one of the little spektrum receivers that has the servos built on..!! I could use them for the tail and then a 303 for the ailerons!! EWWW...I can't believe I am getting excited about this! hahahah
you know as bad as I fly that it won't last long! hahahah |
hahahahaha you fly like a bad ass and you know it!!! That little Edge sounds awesome!! I was thinking about that as well, about stealing the guts out of a PZ Sukhoi..but i figured I would try this first.. |
Good Grief..that really would be perfect..! Thanks Auger! I will get my buddy to check into that and see if/when it will be available...
Thanks, Glenn |
Thread Tools | |
Similar Threads | |||||
Article | QuiQue's Aircraft Company 49" Yak-54 Review with AXI Power | sun.flyer | 3D Flying | 21 | Dec 28, 2016 03:13 PM |
Discussion | Micro Yak-54 from Hobby Lobby | Whirly-Girl | Indoor Pattern/F3P | 110 | May 24, 2008 06:12 PM |
Discussion | Hobby Lobby Micro YAk 54 Motor? | nitroracer20 | Foamies (Kits) | 1 | Feb 10, 2008 06:41 PM |
First attempt at a micro indoor model. | arclite5 | Scratchbuilt Indoor and Micro Models | 14 | Dec 06, 2005 03:42 AM |
