Jul 01, 2011, 02:17 AM
This tripod
http://www.amazon.com/Pyle-Pro-PSTND...9504431&sr=8-2
and this mount
http://www.amazon.com/Odyssey-LATSA1...ef=pd_sim_MI_2
I use that tripod and a similar mount (just a different brand I found locally) and it works great. The tripod is incredibly strong and I don't have to worry about loading it up with a 20 lb wooden box. Only downside to the tripod is that you cannot sit down and fly because it's minimum height is pretty tall.
- Jeff
Jul 01, 2011, 02:43 PM
crash_1958's Avatar
It's still a work in progress and I would welcome some suggestions.
What is the best way to power up everything gel cell or lipo?
Is it best to fuse everything or would one fuse be enough.
I usually fly with goggles the screen is just in case I have a problem, is a sun screen necessary?
Guy
Jul 01, 2011, 03:09 PM
Crash... what type of case is that and where did you get it?
THanks!
Jul 01, 2011, 03:30 PM
crash_1958's Avatar
I fished it out of a dumpster but I think it was a storage case for wood working tools.
THanks!
Jul 01, 2011, 04:13 PM
hugy's Avatar
I'm part of my groundstation. But it works great.
Jul 01, 2011, 04:41 PM
Fly FPV, sleep; repeat
twinturbostang's Avatar
Such a strange breed, we are.
Jul 01, 2011, 04:46 PM
Air Crash Expert
sawman's Avatar
I bet you'll end up with a neck like the Incredible Hulk...except not green !
hugy's Avatar
Haha, no shame never have had it. Normally I have a dvr recorder on top of the receiver. This gives it the added sky scraper effect.
Jul 01, 2011, 05:51 PM
The Flying Circus
ommadawn's Avatar
Guy
Lipos work fine for me. Less weight. I always incorporate a single 5a circuit breaker. And a Watts Up monitor in line. The C/B doubles as a handy on off switch.
Jul 01, 2011, 10:11 PM
Gravity - It's the law
Yabba's Avatar
Alum case for GS
I just picked up an Alum case at Harbor Freight for $22.49 plus they have a coupon for an additional 20% off in the Sunday newspaper more often then not.
Egg carton foam in the top section, a serrated (remove the serrations to fit the component) 2 inch foam in the bottom section, both of which can be removed.
Also has dividers that can be customized, double locks and a carrying strap.
Pretty good price and much better then the WallyWorld guncases.
edit: should have mentioned, it does NOT have a 1/4-20 mount in the bottom. If you want to mount it on a tripod you'll have to come up with your own mounting system.
Yabba
Jul 02, 2011, 08:23 AM
Sirach 6:7-16
CN I Dawg's Avatar
Guy
Hey that's a cool case, the way it opens it acts as it's own sun screen. I see you found it in a dumpster, no other markings to id manufacturer? Nice ground rig too.
Jul 04, 2011, 01:41 PM
crash_1958's Avatar
Sticker on the inside of the case says Job-Mate
Jul 04, 2011, 07:47 PM
benderfly's Avatar
My new ground station
Well I have been lurking here for a year... first actual post...
Started researching a year ago, got my ham license last fall, spent the winter building and comprehending. Started flying in May and now am out 2700ft with a reliable connection. Decided to consilidate ground items into a box to simplify at field connections and reduce wire clutter. Here it is...
Thanks to all the help from those blazing the trail before me.
Jul 04, 2011, 08:06 PM
FPV junkie
m_beeson's Avatar
benderfly,
I did a lot of searching, and studying, and I still had questions that I needed to ask, and get answers too.
You're a better man than I am.
It looks good.
Jul 05, 2011, 10:30 AM
benderfly's Avatar
Originally Posted by m_beeson View Post
benderfly,
It looks good.
Thanks Mike. I still have a long way to go. I have been flying RC aircraft (fixed and rotary wing) for 10+ years so it is not about piloting as much as it is about electronics, RF, and acclimation...
Discussion Show us your FPV / RVP ground Base set up in action Trackercal FPV Talk 94 Nov 05, 2010 10:21 AM
Discussion Show Us Your FPV Helo Set Up Trackercal FPV Talk 2 May 11, 2009 11:05 PM
Gallery Show us your Ground equipment setup a9amg FPV Talk 2 Dec 03, 2008 03:47 PM
go on show us your avatars mudlark Life, The Universe, and Politics 105 Dec 19, 2007 08:23 PM
Show us your choppers! sneu Electric Heli Talk 23 Dec 30, 2001 11:50 AM
