Oct 16, 2009, 11:07 AM
Pitts s2a CAD construction plans
Hello,
I would like to built Pitts S2A airplane (wing span cca 40 inch) from balsa and I wonder if someone has a CAD (or PDF) plans (technical drawing) with all necessary dimensions and building instructions, so I will be able not only to built it but also to fly with it
I found some plans but mostly not detailed enough and I am worried about their aerodynamics. It would be great if someone could help me.
Oct 17, 2009, 07:50 PM
What goes up must come down,
chaps's Avatar
Originally Posted by maja_kozmo
Hello,
i'm in the same boat.need help
Oct 18, 2009, 09:08 AM
If no one can find you CAD plans, you might want to check out the paper plans from RCM http://www.rcmplans.com/index.php?ma...&keyword=pitts
Alan
Oct 18, 2009, 10:24 AM
Hello,
Back in a 1973 edition of American Aircraft Modeler they refer to the Pitts S2-A as the Big Stinker, and the earlier S2 model as the Little Stinker. Was not aware of this. But mention is made that there are numerous plans out on market, and all seem to vary as to accuracy.
So, you may locate a set of copied plans in DWG or TIF format, but they ae only accurate as of that model. Not as of the actual aircraft.
Wm.
Oct 18, 2009, 01:17 PM
-insert witty saying here-
Hemikiller's Avatar
If a Pitts M12 will do, you can get a free PDF copy of the plans here...
http://www.gundersonaerodesign.com/p...rtkits/burton/
As far as an S2A, you should check the "links to free plans" sticky on the scratchbuilding forum on RCUniverse.
http://www.rcuniverse.com/forum/forumid_174/tt.htm
Discussion Pitts Challenger ARF or Plans? arp67 Foamies (Scratchbuilt) 1 Oct 15, 2009 01:34 AM
For Sale Cermark Pitts S2A arf NIB phmx17 Aircraft - Fuel - Airplanes (FS/W) 0 Nov 28, 2005 03:45 PM
cad drawings plans JET POWER Scale Kit/Scratch Built 1 Dec 16, 2004 06:47 PM
Alert P-51 Construction Plans CHRISTOS The Builders Workshop 0 May 21, 2004 10:18 AM
